Question about Samsung Cameras
I have a Samsung L730 camera and all of sudden the shutter isn't opening and making a bleeping noise,i haven't dropped it or anything, can you help? thanks
  • petemac01 Sep 08, 2008
    I've the same problem with a L73. It has not (to my knowledge) been dropped, it just completely stopped after taking a picture. The lens is stuck open. When you switch it on, it beeps three times but the lens stays open and the lcd is blank. Does anyone know what the problem might be?
We have 3 in our family and all 3 have stopped working for no reason at all. Light comes on when u hold power button and as soon as u let go it goes out and nothing happens. So if anyone could help us too? thanks
Posted on Aug 29, 2008
  • Anonymous Aug 29, 2008
    oops missed the same problem button sorry.
SOURCE:
SAMSUNG S1070 - When I take pictures, white lines appear on them. They don't appear on the screen when I am not taking a picture, and they do appear when I transfer them to my computer. I have tried...
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 29, 2011 | Samsung S1070 Digital Camera
Stripe appeared when taking picutre with SAMSUNG L730
The shutter is jammed open - in picture mode it overexposes and gives the white stripes, in video the shutter stays open and the camera sets the expsoyre, so appears OK. New lens unit will be required.
Jun 10, 2010 | Samsung L73 Digital Camera
Dropped my L730 digital camera and since then when viewing pictures taken, there are lines across the screen...?
Sounds like the shutter has been damaged and is stuck open, which overexposes photos and gives a 'venition blind' effect - the shutter and/or lens unit would need to be replaced. Probably marginal given low replacement costs.
Jun 02, 2010 | Samsung Digimax L730 Digital Camera
The lens on my L730 digital camera does not open.
Hi, I had exact the same problem with mine Samsung L730. I opened it and took the 2 flatcables from the circuit board (to the lens-unit) out of there connectors. After I put them back in again, the camera worked. I geuss it was a bad electric connection of the lens-unit. Maybe this will solve your problem. If the camera is older than 1 year and has no warrenty, just try this. Good luck.
May 23, 2009 | Samsung Digimax L730 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Samsung L730
You don't need to install anything.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 10, 2008 | Samsung Digimax L730 Digital Camera
Samsung L730 Lense Stuck Open...
Try tapping a corner of the camera on your palm 2-3 times..it usually works..
May 11, 2008 | Samsung Digimax L730 Digital Camera
Cameras Logo
50 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
