Question about Fujitsu Siemens LifeBook P5020 Notebook
SD and CF reader
Does anyone know what the maximum capacity card the P5020 can read? Thanks.
    President:
  • 778 Answers
The PC will see the card as a storage device so should read any capacity Compact Flash, or Secure Digital cards that you put in the readers.
The devices their used in usually have the capacity limitations as to what size cards they will read/write to.
Posted on Mar 21, 2008
It wont read the cards
A: Make sure you're using a supported memory card. See the table below for specifications:
Memory Card Type Maximum Capacity CompactFlash Card
(Type I and Type II--3.3V only) 8GB Microdrive (3.3V only) 4GB SD (Secure Digital) 2GB MultiMediaCard 1GB
If you connect a compatible CompactFlash (CF) adapter that can read 8GB memory cards, you can also use the memory cards listed below (with a capacity up to 8GB):
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick PRO
  • Memory Stick PRO Duo
  • xD-Picture Card
  • SmartMedia Card (3.3V only)
Mar 26, 2014 | Epson PictureMate Photo Printer
How do i insert the 8b memory card in the memory card reader? i've tried it several ways and it does not light up??? i need a visual
The Dynex 5-in-1 Reader may be too old to read high capacity secure digital cards. (HCSD)
An 8 GB SD card is definitely going to be high capacity. Only the relatively newer SD readers can read the HCSDs.
Try putting in a 2 GB or lower size SD card and see if it works. If it does, then your card reader doesn't support higher capacity cards.
Good luck and thanks for using FixYa.
Mar 09, 2011 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
My computer wont read my sdhc card
If you know that your CF card is working (e.g. as in your camera) then the most likely cause is your computer Flash/CF reader either inbuilt or external): older readers (and cameras/phones) will not support High Capacity (xxHC) card and will be limited to a maximum of 2GB. Hope it helps.
Jul 13, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Please can you tell me if an SD card called SD Ultra 11 66X 2GB will be read by a standard SD card reader
Yes, i t should be unless it is a SDHC Card which it should not be as SDHC cards have minimum 4 GB capacity. For more info:
The older SD (secure digital) cards had a maximum capacity of 2GB. The SDHC (secure digital high capacity) cards can go to 32GB. Devices that support SDHC will say so in their specs and they will also read older SD card. Older devices that use SD cards will NOT use SDHC.
"SDHC (Secure Digital High-Capacity) cards are flash memory cards with a minimum capacity of 4GB (gigabytes). SDHC cards provide removable memory for compatible digital devices including cameras, camcorders, PDAs, MP3 players and more.
Dec 14, 2009 | Audio Players & Recorders
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
I have a 4GB HC(?) card,it wont work in my computer
a 4GB card is certainly HC (High Capacity). What type of flash memory is it?
Be aware that some computers have a different boot sequence. Meaning that some will try to boot from the DVD/CD drive before the hard drive, some will try to boot from a USB device before those. The card being present in the drive could be telling the computer to try and boot from that (which I'm 99% sure is the problem there).
Next is the issue with the card being read. Until I know what type of flash memory it is (SD - Secure Digital, CF - CompactFlash, etc..) this is speculation. I know with SD there is standard SD and SDHC (SD High Capacity). Older card readers are only capable of reading standard SD cards and while they will acknowledge the existance of SDHC because it is the same form factor, it won't know how to read it.
Mar 25, 2009 | FUJIFILM LTO Ultrium Storage Media
Panasonic fz 18
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Aug 25, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
May 17, 2008 | Pentax Optio S5n Digital Camera
Maximum memory?
How much I know there are no limits. I have information that with 1GB Card there are no problems. It can be that if you use Card with high memory capacity PDA can read data somewhat more slowly.
Sep 08, 2005 | Toshiba e750 Pocket PC
Open Questions:
The Best Unlimited Online Backup and Cloud Storage Services Since those early days of laptop production, Acer has grown to offer devices in every category. From netbooks to high-powered gaming units, there is likely to be a laptop computer made by Acer to fit the needs of just about any consumer. The handy features along with the cool looks make Acer the world leader among the uprising brands also making them the worthy competitors of a large number of brands. Along with the cool style statement suitable for different age groups of customers, Acer products are available at affordable prices, support acer. Amazing features with attractive looks and affordable price range makes Acer brand one of the best choices for laptop users. Even though Acer has created a successful name in the market due to its high efficiency products, acer computer support might come with its share of difficulties which might be faced after a period of time, becoming a source of a lot of trouble for its users. If you are also facing any kind of issue with Acer laptops then, there is no need to worry because we have a team of skilled professionals who will resolve all your issues perfectly without consuming much of your precious time and they can be contact acer support. Issues faced by Acer customers: • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues • Windows 10 upgrade problems • Computer Tune up issues • BIOS update Our services for Acer users: Our world class services can be guaranteed to customers once they call on our acer customer service number for assistance regarding Acer products. All your query or issue related to Acer laptops that you want to get resolved in the most efficient way possible will be get dealt by some of the greatest minds in this job with highest levels of experience. Contact our acer technical support team for any assistance regarding issues concerning Acer Laptops by Calling on our Acer customer support number. Get all your trouble sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 21, 2018 | Acer Computers & Internet
See all Fujitsu Siemens LifeBook P5020 Notebook Questions
Fujitsu Siemens LifeBook P5020 Notebook Logo
381 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
