Question about Apple iMac G4 Desktop
IMac OS X Version 10.3.0 800 MHz PCG4 MEMORY256 MBSDRAM
While doing the simplest of commands in a document word processing, moving cursor etc. boot up etc.  the pinwheel (roulette wheel) comes on and I have to sit and wait, takes forever to do business!!
What is wrong!?!
HELP !! STEVE LAT.ENT@ATT.NET
  • 667 Answers
Steve, have you ran the Disk Utilities application to repair disk permissions?
Posted on Mar 21, 2008
Why does my iMAC 4,2 reject blank DVD-Rs but plays burned DVDs?
Your machine has a DVD-rom drive, but not a DVD-burner. There is a difference.
Basically, you can read and play the DVD's, but the drive is not capable of burning them.
Nov 04, 2012 | Apple iMac G5 MA064LL/A Desktop
I have a IDE HDD from my old Medion computer, which I want to install as Master in a newer HP dx5150MT computer. Having installed it; and, having tried and exhaused ALL options within BIOS & CMOS
You have to change the boot information in the MBR (master boot record) on the hard discs. To do this, you need either the install or update CD/DVD for your version of Windows (make sure that the SP matches). Note: if the drive from your original Medion computer has the drivers (motherboard and other hardware) from that computer, you need to reinstall the OS on to that drive. Then fix the boot record as you install the OS. Usually uninstalling the motherboard drivers is recommended before moving a hard drive to a new system.
You need to boot from the optical drive. Either set the BIOS to check the optical drive first or press F12 repeatedly as the computer starts up. (I usually have to restart and try again to access the change boot order menu.) Once you are in the Windows, you need to access the recovery console and the command prompt. You need to have the recovery program identify all the Windows OS options on the discs. If you have XP, first use the map command to identify the discs. Then use the command fixboot (devicename) and fixmbr (devicename) to put a new boot partition on the appropriate drive and then fix the MBR.
With Vista or Win7, the commands are slightly different. Use the Bootrec command. First use Bootrec /ScanOS to identify the versions of Windows on the drives. Next use the /RebuildBCD switch to list the available OS versions. Next use the /fixboot (if you want the Vista or Win7 OS to boot first) and /fixMBR switches.
Any hard drive repair utility CD for Windows will likely have a program to repair the MBR. These may be easier to use with some combinations of OS versions.)
I hope this helps.
(who has fixed the MBR on several machines after mving discs around and grumbled at the issue.)
Jun 13, 2012 | Computers & Internet
What is the function of home
Word
Moves cursor to the beginning of the line.
CTRL+HOME moves the cursor to the beginning of the document.
Excel
Moves to the beginning of a row in a worksheet.
Moves to the cell in the upper-left corner of the window when SCROLL LOCK is turned on.
Selects the first command on the menu when a menu or submenu is visible.
CTRL+HOME moves to the beginning of a worksheet.
CTRL+SHIFT+HOME extends the selection of cells to the beginning of the worksheet.
Jun 16, 2011 | Microsoft Office Professional 2007 Full...
I recently installed iWork on a new IMac (OS 10.6) but the cursor won't display on Pages so I cannot create any documents. The same software on my MacBook Pro works just fine. Any suggestions. ...
Run Software Updates (Apple Menu in top left of screen > Software Update). There is an update that fixes the document canvas now showing anything. You can tell the document is loading because you can copy and paste form it or look in the Inspector and see the word, page, and character counts.
Aug 16, 2010 | Apple iWork 09 Family Pack Full Version...
The iMac G4 17" freezes cursor moves but nothing works.
Could be a lot of things. Try running Disk Utility from your install DVD:
http://support.apple.com/kb/ts1417
After that, if issues persist, try booting in Safe Boot Mode:
http://support.apple.com/kb/ht1455
If the issue is resolved in Safe Boot, try removing third party startup items:
http://www.thexlab.com/faqs/startupitems.html
If the issue persists in Safe Boot mode, try a new user.
http://docs.info.apple.com/article.html?path=Mac/10.5/en/8235.html
If issue is resolved in a new user, then you know it's something just in your user.
Delete the contents of the following, where ~ represents your user's home folder:
~/Library/Launch Agents
~/Library/Launch Daemons
~/Library/Startup Items
~/Library/Caches
This will usually resolve the issue.
If it persists in the new user, then the issue is likely with the operating system itself. At this point you should Archive and Install:
http://support.apple.com/kb/ht1710
May 24, 2010 | Apple iMac G4 Desktop
This is a question from a friend of mine who recently was given a used imac. Any ideas what he can try doing? when I plug it in and turn it on I get a grey screen with a little icon in the middle (looks...
What your friend is seeing, is an indicator that the Mac 333 Mhz, is not able to boot up to recognizable Mac OS volume. This means that Mac OS volume is either damaged or has some how been corrupted.
Apple advises the only fixes for such an issue with this class of their "legacy computer" series is to back up the data on the hard drive if possible and reinstall the Mac OS version is was operating with, or simply go a step further and upgrade to the highest version of the Mac OS X family of operating systems, that this iMac G3 qualifies for.
Here is a link from Apple support for resolving this issue for this legacy mode;
Macintosh starts up to Grey Screen
If your friend is interested in knowing what is the highest version of Mac OS X he can install on his iMac 333,, it would be Mac OS X 10.3 Panther.
This version is the highest upgrade for the iMac 333 because Mac OS X 10.4 Tiger will only work with Macs that have a built-in Firewire port.
Here is the technical specifications link from Apple for this model:
Technical Specifications - iMac 333 Ghz (1999)
This should help.
Regards,
-Mactechtrainer
Jan 30, 2010 | Apple iMac G3 (1999)
''imac g4 does not see dvd drive after Xferring files and setting
when booting in os x after the first boot chime immediately hold down keys <apple,option,o,f> all at the same time and allow computer to boot to open firmware once there type "reset-nvram" exactly like that but without quotation marks and press enter once it returns to command prompt type "reset-all"and press enter (you must have the "-" in between the commands) the computer should restart if not when the command prompt returns type "reboot" and hit enter ..... also you can check the drive status by going to "system profiler" in apple drop down menu--->about this mac-->more info or applications folder-->utilities folder--->system profiler then selct disk burning under hardware in the list on the left
Mar 18, 2009 | Apple iMac G4 Desktop
Booting an iMac g5 for the first time with out the system disc.
There are several reasons why you could be having this problem. You first need to know a little about the various "flavors" of Apple computers and operating systems.
There are two brands of processors: PowerPC (this is what you have) and Intel (what Apple switched to after your model).
There are also different types of system install disks: Specific Version (this is what would have came with the iMac originally and contains only the drivers for that model). Retail Version contains drivers and "Universal" processor code for all of the supported models and both types of processors.
Intel Macs format their drives differently than PowerPC macs. So, if the used drive was formatted for Intel you wouldn't be able to mount it, if the install disk that was used was Specific Model type rather than Retail type when the system was installed on your used disk, you wouldn't be able to mount it either.
The drive you have must be formatted for PowerPC and system installed from either the Specific Version or Retail install disc in order for you to mount it.
Jan 22, 2009 | Apple iMac G5 Desktop
Mac G5 startup problem
Try an archive and install of the OS. This will save your settings and files but reinstall the OS. You can do this by booting to the cd and choosing archive and install instead of erase and install. If it happens again, it could be a slowly failing hard drive developing bad sectors, or the less likely of bad ram.
Apr 06, 2008 | Apple iMac G5 Desktop
Apple iMac G4 Desktop Logo
79 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
