Intertherm gas furnace
Does not heat house, ignitor comes on, gas flows burners work for 45 seconds then shut off, process keeps going until turn down thermostat. turn off furnace and restart- works good, intermittant problem.
    Champion:
  • 210 Answers
Need more info. Are you saying that when tstat calls for heat then it short cycles. But if you turn it off then back on it runs ok?
Posted on Mar 23, 2008
SOURCE:
Intertherm furnace ignitor will not kick on
furnace operation= call for heat- inducer blower motor energizes- pressure switch makes- after a few seconds ignitor activates.
If this series of processes is not whats happening the furnace may be going into a code safety. Call to discuss further=913-557-9111
Feb 25, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Ruud Silhouette II Gas Furnace, purges, lights burners and burns until the blower starts and then burner stops and does not really blow very warm air. Once blower shuts off, it starts the process all over...
I would be looking at the heat exchanger. They are designed to have the heat from burnt fuel flow thru them. Cracking or pin holes will let the super heated air into the furnace interior and in there you have some over heating protection some look like buttons, older they look like an external thermostat, and these get the hot gas from the burners and trip then the furnace shuts down. When the furnace comes on again some times the blower will come right on because the sensor says hey this thing is hot when in fact it isn't. This also can and if bad enough will cause carbon monoxide poisoning, please inspect this closely or have a professional look at this. There is no price ever to great to replace a human life.Sorry probably not the answer you wanted but better safe than sorry!
Dec 20, 2010 | Heating & Cooling
I have a ng furnace downstairs that started this a couple of days aga....It comes on like it is suppose to and runs until it shuts off. Once the blower cuts off it stays off for about 1 second and then...
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 06, 2010 | Heating & Cooling
It appears your furnace is a downflow furnace. The sensor will be located near the bottom of the furnace. When you first turn it on, you should see a red glow.....this is the hot surface ignitor. Normally, the Hot Surface Ignitor is located on one end of the burners and the Flame Sensor is located on the oppoosite end of the Burners.
For more detailed information, click HERE.
Apr 15, 2010 | Heating & Cooling
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
I have a intertherm furnace 60000 btu inlet,
Souns like the thermocouple is gatting weak and needs replacing!
Dec 20, 2009 | Heating & Cooling
I have a problem with my heating system. It is about 10 years old and has had the ignitor, combustion blower motor, and programable thermostat replace in it's lifetime. The system worked great last year....
sounds like its not proofing flame. it has a sensor usually like a needle sticks out into the flame that tells the gas valve the flame lit and is burning so its ok to keep sending gas, if its fails to proof flame then burner shuts down, then it tries to relight 3 times then locks out on fail safe. the blower will sometimes run continually once that occurs to highlight a failed condition. every time you reset it will try again 3 times then shut down. lp gas is very dangerous, even i do not work on it as the gas acts like gasoline and lays around. not like natural gas that disperses well. if you see the flame sensor try gently cleaning it with a little emory cloth. also a loose ground can cause this. check tio be sure any green wires are snug , they actually flow volts to ground through the flame on some to proof, thats why no ground no flame. if that fails then the board is most likely problem. change wire for wire , or get generic replacemant and follow directions exactly. good luck.some ignitors act as a flamre proofer as soon as they are done igniting! rarely do they fail to perform both funtions.
Nov 20, 2008 | Heating & Cooling
Heating & Cooling Logo
187 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
