Question about Sony STR-DE475 Receiver
WAT DO I DO WHEN IT SAYS PROTECT - Sony STR-DE475 Receiver
  • 1 more comment
  • Anonymous Jun 04, 2008
    I Have disconnected the speakers and everything else from the receiver and protect still comes on. Brian
  • Deancraw Sep 01, 2008
    My Sony STR-DE 135 received shows the "protect" mode with nothing hooked up to it. No speakers - no other units. What can I do?
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi Roscoe... check all your speaker connections for shorted wires, check the speaker wires for any frayed or chaffed bits. Check your speakers with a meter for the correct impedance.
    If all of these appear ok, then the amp has developed a fault. You can prove the amp or the speaker system one way or the other by disconnecting the amp from the speakers and see if you stil get protect
    regards Graeme
I still have this PROTECT problem. i did everything it said to do and i can't get it to work
Posted on Nov 13, 2008
  • 1,512 Answers
How did you go?
Posted on Mar 21, 2008
I have an amp hooked up in my car.when I tried to connect the two woofers up to amp, the stereo cut off and the deck said protect.now that's all it will do is read protect.Wat do I do?
This is a circuit protection to stop you frying your audio! Could be a short circuit or wired wrong......remove the fault and it should reset! First remove the 2 sub woofers since that was when this happened and test the deck!
May 12, 2015 | Car Audio & Video
I just wat to delete certain pictures from my flash drive and it's not working. What should I do? the flash drive is called ATTACHE.
Hi there
You flash disk is write protected and you cannot delete or add new file from the flash disc. Just click right mouse and choose the program each text. One of those is the tools to unwrite protect the flash disk or if there is pop up software in your computer that use to write protect the flash disc.
I hope it helps you
Feb 20, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Wat anti virus ll really protect ma computers though i use diff kinds of antivirus bt m nt sure of wat????
Here is a link to AVG antivirus for free. Make sure there are no other antivirus programs on the computer because it won't work. Here's the link
http://download.cnet.com/3001-2239_4-10320142.html?spi=f05dfb7b47e04e2afb5f9e1852341c73
Mar 14, 2010 | Lenovo 3000 Y410 Laptop
Need manual casio memory protect 200 watch #1554
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 18, 2010 | Casio Watches
MY Fender Passport P250 went into protect mode. I changed the FUSE at the power supply with a new fuse. Still it is in Protect mode. How to fix this
This needs to go to the repair shop. The protect mode is turned on when either the power supply has a problem or one or both power amplifiers have a problem. These are often blown components.
These units are HARD to work on. To open you have to first remove then front panel before you can remove the back panel that has the power supply and power amps/heat sinks.
Compare repairs of these units to working under an automobile dashboard!
Hint: On startup, use a series 150 wat lamp to limit current while repairing. SInce these use a switching supply operating off the input line, use an isolation transformer for personal safety.
Oct 04, 2009 | Fender Passport Deluxe 500watt Sound...
My sharp Stereo is stuck in '' protect'' mode
Protect mode is not something that a reset will fix. Basically it indicates that there is a problem with the final output stage of the amplifier. Normally this indicates that the output transistors are defective. In most boomboxes, the amplifier is a single IC. If you can post the model number, I can provide you with the required part and cost.
Thanks,
Dan
Mar 25, 2009 | Sharp Audio Players & Recorders
Getting my amplifier out of protect mode
There is a problem with one or both of the audio amplification circuits. The amp is going into "protect mode" to protect your speakers. I'm afraid there is no simple fix. this will need to go to the shop to be repaired...
...unless you have been tinkering with the speaker connections recently. In which case, make sure all connections are sound & there are no wires touching other wires. This causes a short circuit. Leave it disconnected from the mains overnight. There's a slim chance it might spring back to life tomorrow.
Good luck & let me know how you get on.
Jan 10, 2008 | Audio Players & Recorders
My amp wont go past protect mode
Disconnect all speaker wires and signal cables from the amp. If it powers up (no protect light), the wiring needs to be checked. If it still shuts down (goes into protect), the amp likely has blown output transistors.
Dec 01, 2006 | Lanzar Vibe 218 Car Audio Amplifier
Sony STR-DE475 Receiver Logo
174 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
