Question about Garmin Nuvi 660 GPS Receiver
Garmen nuvi 660
How can i repair the speaker inside gps it sounds,,,,cuts in and out and does not sound clear and loud
  • Anonymous May 27, 2008
    i have no sound on my garmen 660
  • ronniehall Jun 13, 2008
    My speaker made a loud pop noise when I was using it to make a call and now the directions that are spoken are all distorted.
  • Garmin Master
  • 2,130 Answers
If you can hear audio through the headphone jack but not the internal speaker jack, then the speaker is bad.
This is a problem I have seen many times before. I will be posting an article soon on how to replace the internal speaker, however this is not a repair that just anyone can do.
You have to have skills in dissassembly & soldering.
- Jim
Posted on Jun 19, 2008
  • SHARCNET-USA
    SHARCNET-USA Jun 19, 2008
    Also, the speaker is a 1.35" diameter, low profile speaker. The original speaker has a blue & black wire running from the speaker to a 2 position plug, which plugs into the main board. I would salvage the wires from the original speaker to make use of the original plug. I'll be posting a procedure on how to take apart the Nuvi and replace the speaker. Again, this is a procedure for those with dissassembly & soldering skills and units no longer under warranty.
    - Jim
How about just how to take the case off without destroying it? thats all i need to figure out
Posted on Jun 29, 2008
MY NUVI 660 SUDDENLY SOUNDS LIKE IT'S TALKING IN A CAN....VERY TINNY AND IRRITATING.
Most likely the speaker has failed. try plugging in a set of headphones. If the sound is good there, then the speaker has failed and needs to be replaced. If you need more information, you can look here:
http://www.sharc.net/gps_audio_repair.htm
- Jim
Jan 26, 2011 | Garmin Nuvi 660 GPS Receiver
THE SPEAKER ON MY NUVI 660 SUDDENLY SOUNDS LIKE SHE IS TALKING THROUGH A TIN CAN. VERY TINNY.
Most likely a defective speaker. Try using headphones. if the sound is good there, then the speaker is bad and needs replaced. More info on this topic can be found here:
- Jim
I need to update my garmen nuvi 660- How do I do that?
Go o Garmin.com and upload new maps. They run between $60-$99. Ive tried finding drivers to by-pass and get new maps but garmin scrambles the codes. Hope this helps
Nov 06, 2009 | Garmin Nuvi 660 GPS Receiver
INTERNAL SPEAKER NOT WORKING GARMEN 660
The garbled voice has nothing to do with the map update. You internal speaker is defective. Please see this link to see more info on this problem.
- Jim
Sep 04, 2009 | Garmin Nuvi 660 GPS Receiver
No sound
Check the audio output setting on the nuvi. There is a possibility that the FM Transmitter setting has been turned on or that the device has been muted.
To check the audio output setting:
  1. Touch the Speaker icon below the Wrench icon.
  2. At the bottom of the screen, touch Audio Output.
  3. Make sure that the Internal Speaker is selected and touch OK (660, 670, 680, and 5000 models only).
  4. Make sure that the MUTE box does not have a check mark in it. If it does, touch the box to clear the selection.
  5. Make sure the volume level is at a reasonable percent level.
Aug 13, 2009 | Garmin Nuvi 660 GPS Receiver
No sound from Garmin nuvi 760 by any method
Sounds like your speaker went south. Since your fm transmitter is working I'll be your earphone jack is too. So you could always use an earphone. Only other option is a speaker replacement.
Dec 20, 2008 | Garmin Nuvi 660 GPS Receiver
Help
Greetings,
Amazon has a ton of options. I personally like the beanbag mount. It works very well.
Click HERE to see a list.
Take Care,
-WN
Oct 02, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
215 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
