Question about Philips 9P6444C 64" Rear Projection Television
GREEN GHOST REST OF COLOR IS FIND JUST HAS A GREEN GHOST HAVE NO CONTROLS ON FRONT OF TV BEHIND SPEAKER COVER
  • 1 more comment
  • John Peace
    John Peace Mar 21, 2008
    PHILIPS MAGNAVOX 9P6444C103 CHASSIS PTV840 WHERE CAN I TURN DOWN THE GREEN OR FOCUS GREEN CROSS HAIRS
  • John Peace
    John Peace Feb 23, 2009
    thanks for your time
  • squink007 May 02, 2009
    green ghost
  • 3 Answers
If you remove the back you will see a block with 6 knobs on it (2 red 2 green and 2 blue) DO NOT ADJUST THE BOTTOM ONES IF THE COLOR BALANCE IS FINE, slowly turn the the top green one and your green color should lose some of its glare. If not then the convergence is probably out, have you tried to adjust it using the convergence option on the menu? if you have then you would probably have to replace the STK 392 - 110 convergence chips (about 20 dollars on ebay)
Posted on Feb 23, 2009
  • 85 Answers
If you want to adjust focus and screen there is a focus block some sets they can be found on the front behind the gril then behind a cut out held in place by screws if not check from the rear. But a ghost like you say sounds like a convergence problem
Posted on Sep 26, 2008
  • Anonymous Feb 24, 2009
    It is also posible there is a bacteria growth in the cooling fluid look down in the green lens while et is on. If there is a haze in the lens then new cooling fluid and cleaning the lens will fix it. If this is the problem removal of the tube assemby and then changing the fluid. DO NOT GET THE FLUID ON ANY CIRCUIT BOARD. The focus block as the other suggest may be the fix also. The fluid is not expensive but when you take the tue assemby out and back in you will have to reconverge the image. Make a mark around the tube to where it meets with the lens and that will help when you put the tube back on the assemby this is not a fun easy job if you have never did it before. I do hope the focus adjustment is the ticket for you but please take apeek at the tube,
SOURCE:
I have a philips HD rear projection TV 60 in. inside there are six adjustment knobs. Three are color the other three are for brightness contrast and hue. Which is which Left to right
If yours is a rear projection TV the adjustment knobs on the focus block inside are screen (red, green, blue) and focus (red, green, blue). The ones you are referring to as color are the screen controls and they adjust the intensity of the color from each tube. The other set adjust the focus of each color. They are also not intended to be adjusted by the user. Unless major components have been changed these controls should not need adjustment. That is why they are inside the TV.
Dec 05, 2009 | Philips 60PP9352 60" Rear Projection...
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
Screen is all Shades of Red....
You need to remove the front tv panel, search for the screws right behind the screen and speaker area on the sides of tv. Should be four of them, carefully remove the lower have/quarter and you will find a control box, 6 knobs. Try adjusting them to clear the problem, each color has its own knob, be sure to mark their original position befor adjusting. When you find the red adjustment knob, you should be able to turn it down enough so that it doesnt overpower the rest of the colors. Good luck.
Jan 28, 2009 | Televison & Video
2002 Taurus stereo
Here are the factory wire colors, please rate this solution to your problem, a note any stereo store that sells auto decks has adapter wiring harnesses to do a direct plug in of your DIN standard radio you are trying to install, no cutting of the factory harness, they are cheap
2000 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Nov 23, 2008 | 2000 Ford Taurus
Older RCA Projection screen, Blue picture!
take the front speaker cover off, then remove the four screws on the cover behind it. you will see a 2"x2" black thing with 6 controls on it 3 on top three on bottom, your looking for "screen". they should also be marked r g and b, try turning the blue down (counterclockwise). it may help a little and prolong the life of your tv
Sep 10, 2008 | RCA P52926 52" Rear Projection Television
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony kp-51w5510 rear projection tv convergence
Lateral red or blue movement is accomplished electronically
via convergence alignment circuitry controlled by STK type IC's
Replace them both for reliability, then adjustments will work..
Nov 26, 2007 | Sony KP-51HW40 51" Rear Projection...
Green hot
Locate green screen control found behind speaker grill cover
and access panel lower front of tv......turn green screen ONLY
CCW a little.................T.
Oct 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
PT47QWX42 Projection TV Panasonic IS GREEN
Yes but sometimes you have to remove a cover behind the grille to get to them.
Sep 14, 2007 | Televison & Video
SEEING TRIPLE
Possible problems: 1. Ghosting is caused by an ingress of off-air signals into the TV through the cable system, or the TV's antenna 2. An F-connector may be loose 3. The cable plant may have a "leak" in the area Solutions: 1. Check and hand tighten the cable fittings to the TV set and VCR. 2. Remove the antenna from the VHF terminals when cable is used. 3. A converter or A/B switch may be needed to correct the problem (A/B switch enables you to bypass the set-top cable box or descrambling cable box and tune all unscrambled channels directly with your TV, antenna, or VCR). good luck!
Jan 02, 2006 | RCA P52929 52" Rear Projection Television
Philips 9P6444C 64" Rear Projection Television Logo
205 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
