Question about Toshiba TDP-SW80 Multimedia Projector
Low light It has 2000 lumens but the light is low.
  • 563 Answers
Hi there
Try changing the application modes and also check if economy modes is on !
Posted on Apr 02, 2008
6ya staff
SOURCE:
How to charge Coast PX45?
not a rechargable light .put in new batteries
Jul 01, 2016 | Coast PX45 LED Flashlight
Technical data
lumens is a measure of light intensity
the lower the number the duller the light, the higher the number the brighter the light average shops have a level of limens around 750 as this is the safe light level for eyes
Wattage is current flow ( amps) and was used as a measure to show the intensity of the light
12 watt bulb is dull in 240 volts situation where a 500 watt bulb as in ( quartz halogen bulbs) is something that will blind you
You will notice a change in readings from incandescent bulbs-- the old units that had a filament in them--20 watt, 40 watt,60 watt, 100 watt to fluorescent lighting where the power saver bulbs have a rating of 12 watts is equal to 60 watts of the old bulb ( a rough attempt to show the lumens ratings )
this was an attempt to compare the light intensity so that customers could see how bright the new bulb would be
Now that there are LCD units , the wattage is so low that a comparison cannot be made so the shift is to lumens as a measure of light intensity ---in reality the results are the same
for example a torch with 3 X aaa batteries as a low lumen rating as you can see by the brightness of the light and if you compare that with the lumens rating of driving lights that light up the road for miles
the wattage(amps)for the big lumens rated lights will still be low compared to the head light s in current use
Mar 10, 2016 | Televison & Video
When my E2d. Ed defender. 200 lumens flash light is turn on it act like an strob light how to stop it or is it a weak batteries
No, that is a 'feature'. It is for signalling or blinding an attacker.
This is the instructions for the 500 lumen version but it will be the same. Nice light, I run Fenix Tactical. Strobe is usually gained by switching on and then half depressing the button and holding. If this doesn't work, contact Surefire direct.
The E2D LED Defender® Ultra is a compact 500-lumen flashlight featuring dual-output capability and self-defense enhancements. Utilizing a virtually indestructible high-performance LED and a Total Internal Reflection (TIR) lens, the E2DL Ultra is activated with a pushbutton tailcap click switch that also selects output levels: press or click once for a high-intensity 500-lumen white-light beam-ten times the light needed to overwhelm the night-adapted vision of an aggressor. Return to off and press or click again within two seconds for a 5-lumen ultra-long runtime low beam that's suitable for navigating at night or performing close-up tasks for hours. The Defender's crenellated Strike Bezel® provides further defensive options should the need arise. Slender and powerful, the E2DL Ultra is an ideal everyday-carry light.
Jan 08, 2016 | Surefire E2D LED Defender Flashlight Max-...
2010 Veracruz driver side headlight
H11 Low Beam Bulb. you have to take out the whole assembly to replace. look on youtube how to do that
Aug 30, 2014 | 2010 Hyundai Veracruz
How to program the ten-tap" programmable switch.
Hi, I have placed a link to the instructions for the ten-tap programming.
Dec 25, 2013 | Streamlight Protac HL Flashlight, 600...
Don't know how to use the ten-tap programmable switch
The Instructions are here:
http://www.streamlight.com/static/document/product_instructions/protac-hl_op_inst.pdf
How do I use the ten-tap programmable switch
Hi, I have included a link to the instructions for the ten-tap programming.
Time to change bulb??
Check the lamp. It might be faulty. [low light intensity]
May 11, 2012 | Vivitek D732MX DLP Projector, 3200 ANSI...
Proxima DT 5800 works but picture is much brighter with the lights out ,what could cause to be not as bright with lights on?
The Proxima DP5800 projector is a small format low powered projector at only 650 lumens (brightness measurement). It simply doesn't have enough lumens to cut through ambient light and display a clean image. It is best used in a dark room.
Also bulb age will play a factor in overall brightness. The lamps for that projector are only rated for 700 hours, and as they near the life expectancy they can lose up to 50% of their lumens.
Mar 09, 2011 | Office Equipment & Supplies
How much lumens per square foot a garden should get?
Gardens should receive 1000-3000 lumens per square foot. Successful gardens usually are lit at around 2,000 lumens per square foot. During the vegetative stage, plants stretch out when they receive low levels of light. During flowering, the flowers are looser and sparse.
Aug 27, 2008 | Hydrofarm Flco95w Grow Light System
Open Questions:
See all Toshiba TDP-SW80 Multimedia Projector Questions
44 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
