Question about Western Digital My Book Premium ES Edition WDG1SU5000 500 GB USB 2.0 Hard Drive
Western Digital My Book Premium ES Edition WD5000H1U-00 500 GB USB 2.0
Hello.. i bought this
WD 500 GB Exetrnal Hard disk USB2.0 few days ago.. USB2.0
And im faceing a problem installing it.. it should install by it self when connecting to the PC as they said...
But when i connect it some times says " Uknown Device" Some times "Pritning Support" and im using windows XP.. i had VISTA... but i formated to Windows XP cause they said it will work on XP... i thought that was the problem...
When i get in the BIOS page.. and selecting a boot device.. i can see the
WD Exetrnal Hard disk ...
Any ideas ?..
Best regards
-evo
  • 5 more comments
  • aivulka Mar 21, 2008
    MY PC REQUIRED DRIVER FOR THIS DEVICE, WHERE I CAN GET IT?
  • Anonymous Mar 21, 2008
    You can pick what model you're using and download the driver you want from this Link (Click Here).
    Still looking for a help for my question will be glad if some one helps me out, Been having this device for more than 2 weeks and i didnt success in installing it..
    Best regards
    -evo
  • ms_sunshyne Apr 04, 2008
    I have the same problem - have been trying to find a solution for months now. I've downloaded and re-downloaded all of the drivers (they keep mentioning included software on the website - but no software was included). Now two of the zip files in the driver list will not open - indicating there are errors. I have my 3rd support question into WD, and am hoping to find a solution soon. I'm getting very frustrated!
  • hanen Apr 11, 2008
    I just bought a My Book Essential 500 gbs external drive and after one week it stopped working now i see all over the net 1000s of people complaining about the same thing. I contacted western digital and they told me to replace the case or get some company to do data recovery. I put 5 years worth of work on there and after that it just stopped working. My question is why should i have to buy a new case or pay for data recovery. How can this company get away with this
  • Anonymous Apr 19, 2008
    Well, everything that was described is right for me too. It is really frustrating since all of my stuff is inside this external hard drive and my stuff's worth is huge. The computer keeps telling me that the device is unknown.
    I hope so much that my stuff can be saved.
  • hamdy222222 Oct 08, 2008
    i have a problem also with the same hard disk model , ut's exactly the same model "Western Digital My Book Premium ES Edition WD5000H1U-00 500 GB " , but i don't think it's exactly the same problem you have, i bought it since like five months ago, and it was working so perfect while i'm backing my data on it, but suddenly when i started to get my data back it couldn't be readable for my pc or any of other six pc's, it gives me a "local disk ' name, and "bad file system' message if i tried to access it, i cannot believe i lost all my data for something like this, please HELP.
  • huix0018 Dec 10, 2008
    My "My Book" just recently malfunctioned. I tried opening the drive onmy computer and it froze the window. So I unplugged it and when Iplugged it back in it tried installing the drivers again but froze andnow the two lights stay on and the computer does not recognize it. Itried plugging the My Book into another computer and the same thinghappens. If you could assist me on correcting this problem it would behighly appreciated and could you also direct me to the location for thedrivers for this product because it is not on the "Support >Downloads > My Book Premium ES Edition."
I had this problem. After a year my WD5000H1U-00 just stopped working. Made funny clicking sounds. Would spin up then spin down endlessly. Computer stopped recognizing it altogether. I tried everything. Here is what I finally had to do. The solution isn't pretty but it is effective and probably the only thing you can do really. Open the casing, take out the hard drive. Unscrew and remove the little part that acts as a connecting conduit. There's your problem. Toss it.
Go to a computer parts store and ask for an SATA to USB 2.0 cable. They are about $25.00. Plug that in to your hard drive where you unplugged the power and connectivity conduits. It should power up and work just fine. You can either move all the information onto another hard drive with a pretty casing or you can leave it the way that it is. It will still work the same, just won't look as nice on your desk.
Posted on Dec 12, 2008
  • tobiagu Nov 30, 2010
    Hello, I'm not the expert on informatics and hardware, but I'm facing the same problems described above.
    My question about the SATA to USB 2.0 cable is, it should be a "SATA or IDE USB 2.0 Cable Converter with Power Supply" or just a "SATA to USB 2.0 cable"?
    Thanks in advance for the answer
Lots of posts on this on other boards -- I was looking for output voltage of AC adapters as they are not labeled WD and had mixed multiples from other devices in one box while moving-- -- found that answer -- BUT I also saw several people whose drive stopped working suddenly. One got a tip from WD support to unplug adaptor from power strip and into wall socket directly -- This seemed to have solved this for many. Being a study of electrical and electronics I have a suspicion that the current capacity of the strip plug cord wires or strip internals are being overloaded. This will cause a drop in voltage out of the power supply itself, thus low voltage to the drive. One individual re-created the problem by again going back to a loaded strip. No guarantees but worth a try!!
Posted on Nov 09, 2008
Okay i had my book completely malfunction i have the WD5000h1u-00
i use it as a back up but i recently downloaded too much and filled up my primary harddrive so i used it as my primary store for pictures etc...
well obviously it broke and i had no way to get my data.
after looking online and finding no real answer i tried a series of things whilst possibly co-incidental and maybe with redundant steps it still resulted in a fix.
basically i took apart the harddrive with this model there is no lock, no screw and no easy release but if you use a screwdrive and run it along the edge of the case you can pop all the glue and a bit of plastic but really do minimal damage, mine has no aestetic marks,
i then removed all the parts down to the board that needs the 6 pin screwdriver and put the thing back together being careful to ensure everything was connected.
then i plugged it in to the power and the usb and restarted my laptop
on the reboot it works, don't rely on the lights though as mine just had a solid blue bar until i transfered data.
i don't know how long this fix will last and i have ordered a new passport drive as a replacement but i have all my data if nothing else.
i hope someone else can benefit from this and i'm glad to have back my pictures
kevin
Posted on Jan 28, 2009
Mate this problem posted months ago.
And " Lol noob " doesn't seems to be a solution either.
If you have an idea to share with people or even any helpful solution will be great full to post them so you could help other peoples as well.
For the mean time. Go play Runescape and drink some milk and do some useful things.
The cause of this problem is that you're using an custom version of Windows OS.
Cause most of the custom OS deletes the drivers files and replace them with themes and useless stuffs so it could be burnt into CD since there isn't enough space for it.
Please try to re-install you're OS. or to make sure the External HDD working try to plug it into another PC before doing that.
Regards
-evo
Posted on Sep 11, 2008
SOURCE:
Hello, my name is Thomas, im not quite sure that matters but, i bought a new WD hard drive about 4 months ago, after i bought a 160 GB hard drive a few years back. I'm very pleased with WD hard drives and...
Externals can be a pain. Mainly because of their casings that can cause failures to happen for no apparent reason. If your warranty will be expired and/or the drive is not showing in "Computer Management - Disk Management" I would suggest removing the casing from the external and plugging the hard drive you've extracted from the case into a desktop.
If the drive is still not recognized after being installed into a desktop I would look into data recovery. My personal favorite data recovery software is Knoppix which is an OS(linux) booted from disk.
Sep 26, 2010 | Western Digital My Book Essential Edition...
Hi, I just bought a WD Hard disk with a WD Smartware software. I've been using it for almost 3 months and EVEN HAVE A PASSWORD for it. Just 2 days ago, my WD Hard disk was NO LONGER being recognized on my...
If zcomputerwiz solutions don't work, then remove the disk from the chassis, and install it into any desktop PC. It should show up as a regular harddisk, and you will be able to access your data. I have successfully done this with my WD MyBook Extreme Edition that had stopped being recognized by my desktop and laptop. Now its a regular drive in my desktop PC without the use of any special savior software. Good Fixin!!!
Feb 06, 2010 | Western Digital My Book Essential Edition...
I installed a new WD Cavier 500 Gb hasr drive ot
Your problem could be that the hard disk is not ACTIVE.
Boot up with a DOS disk (floppy or CD or USB) and run FDISK, select 4 to Display Partition Info. If the C drive does not have A under Status then press ESC and select 2 to Set active partition and then set Partition C to active.
Sep 06, 2009 | Western Digital Computers & Internet
WD HD Media player damaged my hard drive??
Hi Dear! This problem could be solved through a software. You should use Western Digital Disk Manager, your WD hard disk will work properly after using that your WD hard disk pass all test of the software. When it will pass all test it will work properly and in other condition if it will not pass then you should try again so that the software will fix the error and it will made workable.
Thank You
Jul 24, 2009 | Western Digital My Book Premium ES...
External hard drive not being read by media player
did you find an answer to your question? I am currently having the same problem. The USB LED flashes and takes a minute to scan, followed by a pop up on the tv saying unable to recognize hard drive. help?
May 14, 2009 | Western Digital My Book Premium ES...
My book home edition,in "my computer" "F" says disk not formated
The poewr supplies are horrible in this brand, I had to remove two WD drives from the external cases and install them internally to access the data, even when the fan and lights would come on. try to test the drive internally in a desktop, and then you can back up the contents as well
Mar 30, 2009 | Western Digital My Book Essential Edition...
MyBook not recognized by Mac
I am having the same problem!!!! I have my time machine backups on there and I cannot access them! Class action lawsuit???
Mar 09, 2009 | Western Digital 500GB My Book World...
Western Digital My Book  Premium ES Edition  WDG1SU5000 500 GB USB 2.0 Hard Drive Logo
20,332 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
