Question about RCA BD20TF10 20 in. TV/DVD Combo
Need DVD gear part number
I bought this tv with dvd not working. It is missing the gear that slides the DVD tray in and out. Can someone look up this part and see what the part number is and where can I order it? Thanks.
RCA BD20TF10
  • Anonymous Nov 07, 2008
    my dvd tray is stuck in the open position and will not close no matter what i do
  • 979 Answers
That gear is part of the carriage assembly and is not available by itself...accordianman
Posted on Mar 21, 2008
Dvd tray will not open
Had same problem. Unscrew back TV. Unscrew 2 screws connecting VCR/DVD from TV Base. Unscrew DVD housing on all sides (approx 6 screws). At this point you can see the detached DVD unit. Facing the draw. look under it for a white plastic piece that you can slide to the right that should disengage the DVD's circular rotator from the dvd and slide the door open.
If that does not work disconnect the DVD from the 2 wire connector at the TV motherboard and dissassemble the black plastic DVD unit. Flip it over and manipulate the white plastic gear which will disengage the center rotator.
Sep 08, 2010 | Toshiba MW24FN1 24 in. TV/VCR/DVD Combo
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Unable to load DVD and mechanism makes noise like gears slipping
I think that ;
somehow someone bumped the unit and dislodged a DVD from the tray..
thus impeding the opening mechanism as well as the turntable (the unmeshing gears).
I would unplug the unit and remove the screws holding the top cover on , and take a look at the tray .
once thats done , let us know how this is going.
Aug 01, 2010 | Panasonic SC-PT460 Theater System
Dvd stuck in player
Is there a small "pin hole" located near the DVD slot, this used to be pretty common. That hole is to allow for you to push a long needle, staightned out paper clip, etc through to puch the gears that the dvd tray slides on.
Be careful, you don't want to hit random things in the dvd mechanisms.
Sep 11, 2009 | Philips Magnavox 20MT133S 20" TV
JVC dvd player try is brand new but the tray won't open.
Okay i just bought a new dvd player and the tray won't open and hitting it won't work! can someone help please?
Mar 28, 2009 | JVC XV-N370B DVD Player
Jvc dr-mv78 -- dvd tray keeps coming out
Try this: unplug for 1 hour. push in tray and unplug for 1 hour. No help then your timing is off internally, decks use rubber pulleys or fixed gears. Fixed gears slip because someone shoved the drawer closed, pulleys because they are old! There is no harm at this point to open it up and see what you can do ? Other wise PRO shop. Or toss and get another, Panasonic. Please rate..
Mar 16, 2009 | JVC DR-MV7 DVD Recorder/VCR
DVD Player tray Door Continues to Open
I had this problem and it turned out to be the gears on the door drive. There are two gears, one that engages the rack on the tray and one that has a slot that drives the clamping action to hold the DVD. These two gears were misaligned by one tooth. This prevented the gear with the slot from turning freely after the door was closed.
To fix it I had to take out the tray assembly, disasemble it, and reassemble it with the gears properly aligned. You need to remove the top and back of the case. Then take out two screws at the rear of the tray assembly and three screws on the circuit board attached to the tray assembly. Unplug the connections to that board. Slide out the tray assembly. Now you can pop the top off of the tray assembly by pulling out two tabs and sliding the top toward the rear. Now you can get to the gears to adjust them. The slotted gear should be able to turn freely for about 1/4 turn when the tray is closed. Make sure the pin on the clamping part is in the slot when you reassemble it.
Jan 06, 2009 | Panasonic DVD-S35S DVD Player
DVD tray wont close.
You probably striped the gears in the tray mechanics. New gears at a TV shop is your only hope.
May 06, 2008 | Disney DTD1363-CAR 13" TV/DVD
Toshiba tv/ dvd /won't open
Unplug the TV ...wait 30 seconds then plug back in. Worked fine.
Nov 28, 2007 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Broksonic DVD/VCR
First of all if it's just the fact that your DVD players tray won't open on your tv then you'll have to manually open it. Before you even attempt to try and pry the player open you would (the next time you can) find out where the tray gear is that opens and closes it. It would be the big black gear I assume. Once, you find that then you'd have to use a flat ridged object (like say a plastic knife) and slide it in and push on the gear until it opens. But, if you're having problems with playing the disc that's a whole different story. Other than that you could just buy a different TV. This time with a seperate dvd player. Those are easier to fix.
Nov 18, 2007 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
RCA BD20TF10 20 in. TV/DVD Combo Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
