Question about E-Machines W3410 PC Desktop
Lan problem E-Machines T3406 PC Desktop, i could not connect to the internet my internet provider told me that my LAN is not working, he told me to install the LAN Software but were could i find it? THANK YOU!!!!
    President:
  • 2,351 Answers
Hi ramlance,
click the link I have posted below. This is the download page for your E-machine W3410 PC desktop.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W-Series&model=W3410
Click the + sign next to Downloads. Scroll down till you see Network.
Realtek RTL8139/810x Family Fast Ethernet NIC Network Driver.
Click, Download (106.00 KB). File name, D00328-001-001.exe
Creat a folder on your desktop & call it Lan Driver. Save the driver into this folder. Suggest you save this web site in your Favorites. Never know when you'll need to come back here.
Run the the file D00328-001-001.exe
When finished re-start the PC even if windows does not ask you too. When windows finishes loading lets check if windows see's your network card. Click the start button & open control panel. Double click the system icon, click the hardware tab, click the device manager button. Scroll down to Network Adapters, click the + sign to open. Do you see a lan card that reads Realtek bla, bla, bla? Do you see a yellow ! point? If you do not your lan card is installed correctly.
Lets test your lan card now.
Close all opend windows. Click the start button, click run, in the window type command & press the enter key. A window will open & it will read like this:
C:\Docume~1\Your name>
type this command:
C:\Docume~1\Your name>ping www.yahoo.com
There is 1 space between g & the first w
Press the enter key.
This is what your PC will list after you press enter:
Pinging www.yahoo-ht3.akadns.net [69.147.11.210] with 32 bytes of data:
Reply from 69.147.114.210: bytes=32 time=22ms TTL=50
Reply from 69.147.114.210: bytes=32 time=23ms TTL=50
Reply from 69.147.114.210: bytes=32 time=21ms TTL=50
Ping statistics for 69.147.114.210:
Packets: Sent = 4, Received = 4, Lost = 0 <0% loss>
There is a wee bit more but we do not need it. If you see the above your network card is hualing ****.
Type the word exit & press enter to leave this window & return to windows.
If you see the word failed than there is could be a problem with your network card.
Suggest you make sure your connection from your DSL or cable box is running correctly. Each has a reset button on the back side of their box. Shut down your PC. Unplug the power from the DSL or Cable box. Using a pen press the reset button & hold for about 10 seconds. Plug the power cord back in & start your PC.
Try the command key again. If this still says Failed than you may need to buy a PCI lan card & install it into the PC.
The odds of two lan cards not working is not likely.
This is what must be done to prove your ISP is full of s***!
I hope this has helped you.
If you have another question feel free to ask.
Just in case you need a lan card I'll post a link for one.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=252202
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=32195&CatId=587
Good Luck & Kind Regards.
Posted on Mar 21, 2008
2 Suggested Answers
  • 103 Answers
SOURCE: lan problem
Go to the e-machine's amin website and go to help and support. enter your system model and download the network adapter driver for that specific model. if it dosen't work let me know.
Jamiell S.Joseph
Please rate me. Thank You.
Posted on May 18, 2008
No internet connection
For you to have internet access on your desktop, must be connected to a Local Area Network (LAN) that has internet access or use a USB dongle.
If you have problems with your LAN on USB Dongle contact your Network Administrator or service Provider.
Jul 06, 2012 | HP PAVILION A6230N DESKTOP PC
My cable internet provider has provided me with an Ethernet cable which connects directly to my PC. My PC's MAC address is registered with the ISP. I use a PPPoE connection to access the internet with a...
put another lan card in pc
share your connection using ICS from network properties from first one
put a straight cable from pc to router
give the gateway of router to laptop
remember!! the class of ip's should be the same
you are done
Feb 04, 2011 | D-Link DIR-600 Router
My computer ideapad lenova,i am not able to connect to internet,one IT specialist told me that my slot for inserting cable is bad what to do i am now in china Ghanzhou city
Do you mean the slot?
Is it the cable that goes into the LAN port?
If so you can use a LAN PCMCIA card and connect the LAN cable into this card.
OR
You can connect to the Internet using a USB 3G adapter which uses the cell phone network with a cell phone provider.
Aug 05, 2010 | Lenovo 3000 Y410 Laptop
I have a problem with a internet connectivity in the task bar its showing aquiring network address
Acquiring network address (Limited or no connectivity)
1.Check whether you are typing the correct key
2.Remove the preferred networks
3.Disable WLAN/LAN and Enable it
4.Assign static IP address in the range of modem
5.Add the network manually with the security settings
Apr 04, 2010 | Lenovo ThinkCentre® A51 PC Desktop
Access my lan from the WAN
I assume you want to log into your pc from another pc outside your lan. To do this you need to forward port 3389 to your pc.
  1. Make sure your pc (the one you want to connect to) has a static ip address. Also, it should have a password on the windows account you use.
  2. In the router, forward port 3389 (tcp) to the ip address of the pc.
  3. If you do this correctly, you can go to any pc outside your lan, and use remote desktop connection to connect. When you start the remote desktop connection, put in the wan ip address of your lan. If you did the port forwarding correctly, you will be asked for a user name and password. Put in the username and password for your user account on the lan pc and voila! - you are logged into your lan pc remotely.
Let me know if this works, or if you need some more help.
Aug 08, 2009 | Zhone 6211-I3-200 Router
D-Link DES1008D 8 port fast ethernet desktop switch
By using it, of course you have this items to connect it with internet:
  1. UTP Wire with Connectors at end each PC or Client Workstation.
  2. Make sure every PC or Client Workstation have its own LAN Card.
  3. To connect on the internet is to know what is IP Address, Gateway Address & DNS Server Address settings on your LAN connection.
  4. Lastly, It should have internet provider in your place.
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
HP pavilion(a220n) no connect to internet
Use the setup wizard in the internet optins and be sure that the box at the bottom of the LAN settings is UNCHECKED.
Nov 05, 2008 | HP Pavilion a1220n (A1220NED904AA) PC...
Lan problem
Jamiell S.Joseph
May 17, 2008 | E-Machines eMachines Desktop PC
Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Dec 24, 2007 | Computers & Internet
E-Machines W3410 PC Desktop Logo
167 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
