Question about Linksys (WMP54GS) 802.11g/b Wireless Adapter
Linksys wireless card driver is corrupted
I need to uninstall the old driver but nothing is working, can you assist?
Gwen
  • Anonymous Jan 28, 2009
    I have the same problem however, trying to reinstall software and since driver is already installed, the installation will not work
  • Anonymous Apr 13, 2009
    I have the same problem. I get the message must remove driver. I can't find the driver.
  • 689 Answers
Posted on Apr 14, 2008
Wa some linksys wirless adpter are not working with windows vsta
Posted on Mar 25, 2008
Exception GIFException in module aviWUSB54Gv4.dll at 00025168 this msg keeps coming up on my screen
It's a corrupt GIF file used by your linksys application.
1. Delete all files in ..Windows/Temp File folder or have a disk clean-up (check on Temporary files). 2. restart your pc.
hope this solved your problem :)
Sep 20, 2009 | Linksys Computers & Internet
Having trouble with linksys wireless usb 54 gc. I
Linksys wireless card mosly gives this type of error and not work with its own driver. Try uninstalling the drivers completely , reboot your systems then plug in the Usb adapter so that it uses the windows default drivers. that will resolve your issue.
Sep 04, 2009 | Linksys Computers & Internet
Cannot reinstall the linksys wireless-g notebook adapter srx400
Usually a new driver will replace the old driver but it may have been corrupted, depending on how you uninstalled it. Did you uninstalled it from the device manager ? For linksys driver issues check out this link: http://www.linksysbycisco.com/US/en/support
Jan 18, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Driver is loaded but installer say cant find driver
just uninstall the driver and remove card. reboot reinstall driver then reboot and insert card should work now ./RICHARDM69
Jan 12, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Need XP Driver for Linksys wireless adapter, Model:WMP54G I have downloaded driver from linksys site (Ver 4 and 4.1) it is not working. I think i need earlier driver version. Can u help me? Serial no of my...
Uninstall the driver you are using, and install the one from here:
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/Linksys-Wireless-G-PCI-WMP54G-101.shtml
That'll work in XP and if you want to see if a newer version is available that is compatible with XP, you can Update Driver from the Device Manager and that'll find and install the latest one that still has XP support.
Hope this helps
Chris (ziraffa)
Dec 27, 2008 | Computers & Internet
I installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Dec 16, 2008 | Computers & Internet
Can't uninstall drivers for Linksys WUSB54GSC Compact Wireless-G USB Adapter
You can go to Control Panle then Add/remove program double click on it then look for the Linksys software there then just remove it , that will remove the software on your computer and you need to restart teh computer to complete the uninstallation..
Hope that helps.........
Oct 05, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys WPC54GS wireless adapter installation issue
There's a possibility that the adapter is defective. However, you may still try the following:
1. Make sure to uninstall the software if you still have it installed. Remove it from the Programs list or under Add/Remove Programs.
2. Check Device Manager and make sure adapter is not under Network Adapters nor Other Devices. It might be called Network Controller if driver is not installed correctly.
3. Unplug card, shutdown computer and when PC is powered off, plug card back and restart computer.You may insert the CD on this process, but do not run/continue the CD setup wizard.
4. When computer is back on, you should get a Found New Hardware bubble message or wizard.
Just finish the wizard and tell me how it went. Goodluck!
Jul 08, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Linksys WUSB300N, cannot install driver
are you followin THESE instructions?
have you uninstalled the software that came with card?
With the card installed, go to device manager and expand the Universal Serial Bus Controllers tree and see if there are any ? or ! devices listed there
Also check under the network adaptors tree for same thing.
If there are any devices with either ! or ? highlight them and in the menu across the top select "action" and uninstall.
Do you hear the "ding" that usually occurs whemn a USB device is plugged in? if not this may indicate a connection issue
Try all USB ports on PC. Perhaps there is either a bad USB port or the connection is not good. Try connecting card via a USB extention cable (male to female) as it is possible that the shape of the card or the PC case means that the USB is not incerting far enough for good connection.
please post back results so I may assist further if required
Jul 08, 2008 | Linksys WUSB300N Wireless Adapter
It sounds like you may have a band PCMCIA slot. Have you attempted to use any other expansion cards in it to test this theory?
May 10, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Open Questions:
See all Linksys (WMP54GS) 802.11g/b Wireless Adapter Questions
Linksys (WMP54GS) 802.11g/b Wireless Adapter Logo
302 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
