Question about Umax Mirage II Flatbed Scanner
UMAX Mirage II Scanner
I can't seem to get the button to press down in order to turn it on? It originally was jammed in the down position, and on all the time. It seems as though it is a spring loaded button mechanism with some kind of resistance? This is not a "normal" on off switch, that would be normal?  I'd love to thank the GENIUS who designed this. Now it won't turn on at all. Has anyone out there experience this?
Driver and progam of UMAX Mirege IIse
Posted on May 17, 2009
I have this scanner.... I had to take the scanner apart(take the cover off) very simple to do. This is a very simple fix. Obvious fix. You will see when you open it where the switch is. Mine was not making contact. You might be stuck with it in the on position once you fix it.
Posted on Sep 01, 2008
SOURCE:
Magicscan not working with umax scanner II .
Magician 4.5 is available at UMAX Official Site.I recommend that you visit Umax site and download the latest available drivers/software and install them. Also, there is a registry fix available, which may solve the issue.
Good Luck!
Hope this helps!
CreativeTECH
Dec 22, 2010 | Umax PowerLook 1100 Flatbed Scanner
I have umax powerlook II pre-press scanner flat bed model. Now i want to connect with pc. So, i need scsi card for this connection where i can bought that card. If that is available in india please give...
Below given is the link of Umax India with the contacts available in india. Call your nearest dealer so that you could purchase the SCSI card for your flatbed scanner.
http://www.umaxindia.in/contactus.html
Regards
Rudra
Oct 11, 2010 | Umax PowerLook II Flatbed Scanner
UMAX ASTRA 1220P SCANNER DRIVER SENT
I down load the Umax Astra 1200p and it tells me to restart my computer then it starts install all over again. It shows in my progams and when I click on it, a box pops up and says Device not found. Error code 00140e05h[00000000h] It was originally installed on 10-10-97.
Feb 12, 2010 | Umax Astra 1220P Flatbed Scanner
Umax astra 1200s with windows XP
This particular scanner is a nightmare to get working with XP
When it does work it is also prone to random errors.
On the UMAX australia site I found the information I needed to make it actually waok at all.
Below is part of a very old email that I went through with Umax maybe that will help you ?
It is quite an old scanner though.
Sorted out by steps as follows. Disconnect scanner usb lead from computer / hub 1. remove ALL umax software as issued on the cd and any upgrades 2. shut down restart 3. run norton (not the one button but the win doctor) to clean up any loose ends (important but dont know why ? does not work unless this has been done ??) 4. shut down restart. DO NOT connect scanner 5. Install software from original cd 6. do any umax software upgrades (ALSO IMPORTANT ) 7. shut down 8. plug scanner back in. 9. power everything back up 10. do new hardware wizard thing 11 swap driver to correct one as per instructions on your site somwhere ? all working I just did the norton one button on a second machine and it did not work so did all steps again but used norton win doctor as per step 3 and all good it worked a treat on two machine so it appears repeatable.
Sep 11, 2009 | Umax Astra 1200S Flatbed Scanner
Is a Windows Vista driver available for Mirage II?
apparently no,but you can download the driver from here:
http://www.umax.com/download/index.jsp
let me know if it's working
Jul 07, 2009 | Umax Mirage II Flatbed Scanner
Umax Mirage II Flatbed scanner,3 flashing lights
Could be a SCSI termination issue. Try changing the SCSI address number on the scanner to a different one and make sure the chain is terminated properly. If there are multiple SCSI devices in the chain, disconnect all the others until you are sure the scanner is working then slowly add the other devices to the chain making sure everything works as each device is added. SCSI voodoo!
Jun 26, 2009 | Office Equipment & Supplies
3 lights were flashing, now no lights flashing & not on
it is always handy to state the brand and the type of connection when referring a fault.
if its USB the check in ctrl panel DEVICE MANAGER if there is a yellow exclamation mark.
same for serial ...against the scanner
if this exclamation is there it means that it does not recognise the scanner and will need to be reinstalled.
check that the serial plug is on firmly, both at scanner and computer, dont just look... undo and reseat on both. Ensure the POWER plug is connected firmly and that it IS switched on.. try something else in that plug and see if it works.
simple things are often overlooked and users thinking technicians are just stupid to ask these questions, but 9/10 it is the simple thing that causes the problem.
Jun 22, 2009 | Umax Mirage II Flatbed Scanner
UMAX Scanner Astra 5600/5650 Driver
I am in need of driver for my UMAX Scanner Astra 5600 ...Please post me a valid link
we have lost the original cd containing driver, and the scanner has been uninstalled hence, we want to download umax astra 5600 driver, modelno. umax, astra 5600 s.no.
Feb 10, 2009 | Office Equipment & Supplies
UMAX Mirage IIse Running on MAC OS
I had the same problem. I turned off the scanner and unplugged the transparency unit from the back of the scanner and restarted and it is working fine now. Hopefully this works for you as well.
Sep 22, 2007 | Umax Mirage II Flatbed Scanner
Open Questions:
See all Umax Mirage II Flatbed Scanner Questions
Umax Mirage II Flatbed Scanner Logo
160 people viewed this question
Top Umax Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
