I seem to have a belt slipping maybe. Clothes are not wrung out as they usually are at the end of the cycle and there was a sort of burning rubber smell last time I used it. I looked at the belt under the machine and it is in good shape (I recently replaced it); I also took the agitator out and found alot of muck, hair and I shudder to admit a piece of ballet stocking from one of my daughters. Do you think it was this that was causing my problems? I'm not game to turn it on again. Thanks ... Sandra
    President:
  • 778 Answers
You may have cleared the problem when you cleaned under your agitator. The belt may still need replaced if it was glazed while it was slipping as the burning rubber smell you mention would suggest.
I would give it a light or no load try while standing by and check to see that it agitates, drains and spins ok as you advance the timer to test all functions, and of course turn it off if it acts up.
Good luck, and please update us on your results?
Posted on Mar 21, 2008
My Maytag washer model MAV208DAWWmakes a loud screech at the end of the spin cycle, and the clothes are sill wet
That is the brake. Your clutch maybe wearing out. Or the belt maybe slipping because the rollers for the motor maybe wearing out.
Jan 15, 2016 | Maytag Washing Machines
Eureka maxima vacuum smokes and smells like rubber burning..whats wrong with it..the brush turns but seems like its blowing outwards too
when you get a burning rubber smell, the drive belt is usually slipping on the motor due to friction on the brushes. Remove the belt and free all the tangled hair to allow the brushes to rotate very easily and then put a new belt on.
Jun 03, 2015 | Eureka Vacuums
I washed a load of clothes and the washer worked perfectly until the last 3 minutes where the washer does the final spin and all of sudden smoke pours out of the back of the washer and when I opened the...
well is it a smell of burning rubber? maybe the belt that turns the drum has got jammed. over time these belts get loose and when a full load of clothes are washed the belt slips creating heat hence the smoke..hope this helps..
Dec 04, 2013 | GE WSXH208A Front Load Washer
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Did not go into the spin cycle and smells like something burning
when m/c goto spin the motor load is maximum i hope no thing with your motor
also if you smell like rubber burning maybe the belt , you will surprise every thing you see come after heavy overload clothes
Jul 06, 2009 | Washing Machines
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Frigidare top loading washer 6 cycle - 10 years old
you may want to inspect the bottom part and see if it still uses fan belt. it could be that the belt is loose and the motor is spinning but can not drive the transmission. so the rubber burning smell is coming from the slipping belt.
the solution is to tighten the belt or replace it if necessary.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Water leaks and spin cycle not working properly
Water leaking from the bottom usually indicates either a bad hose , bad hose connection to the pump or a leaking pump. Also sounds like the machine is not spinning out. Is there water left in the tub at the end of the cycle?
Feb 28, 2008 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
