Question about Sony CDX-GT100 CD Player
Loose front AUX
I have the same problem. my Front AUX plug in is loose i cannot listen to my ipod what is the solution? is there a plug directly behind the radio?
  • chickendi531 Mar 06, 2009
    How did you know which wires went where? I have the exact same problem and I have a white wire, red wire and a black one. On the auxillary input there are three little spots labeled R, G, and L. I'm assuming this means right, left and ground...maybe?
The wires on the plug. Red, goes to the R terminal. Black goes to the one marked G. And the White goes to L.
Red - R
Black- G
White-L
Posted on Sep 19, 2009
Mine did the same thing. I had to take off the detachable face, disassemble it and re-solder the electrical connections for the jack. this solved the problem for me.
Posted on Mar 30, 2008
I have a jvc kw-avx706...is there any way i can hook my iphone up to it so i can listen to my ipod?? if so let me know please thank you
Hello, there are two options. You could use a mini jack and plug it into your headphone jack on your Ipod and plug the other end into the aux jack on the front of your JVC unit. However you would have to have access to the ipod to control tracks and it will not charge the ipod. Or you could purchase a ipod cable that would not only charge but you would be able to control the ipod from the JVC unit. The part # KSU30 Crutchfield.com sells it for 39.99.
May 15, 2011 | JVC KW-AVX706 Car DVD Player
Tip
How do i connect my iPod to a Pioneer Car Stereo
<p>It is advisable to listen to your iPod through headphones while driving in the car. Not only is it dangerous to completely cancel the sounds of the road as it is often illegal in many cities across the country. There is an alternative, however. In just a few steps you can use your iPod to your car stereo speakers and use the car to listen to your music, podcasts and audiobooks. No brand car stereo makes it easier to connect these beautiful than Pioneer. <br /> <p><br /> <p>1. Connect one end of the mini-jack on your iPod headphone jack. Once done, set your iPod or on your dashboard or your car seat so that it will not tip over while driving. <br /> <p><br /> <p>2. Find your sound system's auxiliary input Pioneer. It is often located in front of the front panel stereo, but can also open the front or back of the unit completely. If the extra connector on the back of the stereo itself, then you remove the panel. When it comes to this, see the instructions that came with your sound system is provided for further guidance. <br /> <p><br /> <p>3. Connect the other end of the cable mini-jack for stereo aux port. This will allow your iPod to the audio signal through the cable to the stereo and the stereo signal will pass to the car speakers. Most often, when something is plugged into the stereo aux jack will work in stereo. In some models a setting to select the additional connection. Whatever the case, now you can sit and enjoy your iPod for that long car ride. <br />
on Aug 09, 2011 | Apple iPod touch
I was wondering how do I play music through my iPhone with this cd player. I have a direct cable but I'm not sure what to press to make it play through my cd player. Thank you.
Once you plug in your iphone and set it to play your song(s). Set your car player for AUX this will then pick up the device playing into the direct port. Hope this helps Fix ya up.
May 12, 2011 | Power Acoustik PTID7002NR Car DVD Player
I have a BOSS BV9970 stereo. the usb will not let me play my ipod, it starts to load it but stops halfway through. and when i try to use the aux, my right rear and right front speakers will not play.
sounds like a loose connection on the aux input. boss has a pretty bad reputation for there usb / aux connections inside the unit. also if your right rear and right dont play on anything its bc you have them turned down. or if this is recently installed they got mixed up. please let me know more details so i can better help you
Mar 20, 2011 | BOSS AUDIO SYSTEMS BV9970 Car Video Player
Can I plug an Ipod directly in to this amp?
You can plug the I-Pod into the amp by using one of these cables. It fits into the headphone socket of the I-Pod and the two RCA's go into an aux imput (perhaps the front one?).
May 10, 2010 | Sony STR-DE595 5-Channel Amplifier
How do i connect an aux cord to my head unit
do you have an aux on the front of the unit or the rear??
if on the front, just plug the lead into the head unit, then into your ipod,mp3 player or whatever. then set the unit to read aux on the front, then simply play your device through the head unit
Apr 05, 2010 | Pioneer DEH-P6800MP CD Player
When I plug my iPod into my car stereo, it's a Kenwood KDC-W3041, sound only comes out of the speakers in one door, but when I play a CD, sound comes from speakers in both doors. What's wrong?
If your using the aux plug in the front make sure the plug is fully inserted into the ipod and the stereo. then make sure all audio settings are set correctly. If you are using any other type of connection for your ipod ensure the connection is not loose.
Dec 10, 2009 | Car Audio & Video
Hi do you know if the wharfedale ics 182 can play an ipod
You need to plug the iPod into the Aux socket, its on the front bottom right corner. Then you can switch by pressing "Mode" between playing either the CS - USB - SD - AUX.
To play iPod, select the "AUX" option.
Nov 03, 2009 | Bang and Olufsen BeoSound 2 Companion MP3...
Aux jack no longer works
Forget and use a cheap FM transmitter for your device with a 3.5 mm plug
Nov 02, 2017 | 2007 Dodge Caliber SRT4 Hatchback
Ipod plugged in front RCA
Please first check whether Sub Woofer works independently?
check whether SW is "on"in AUX mode.
Apr 12, 2007 | Pioneer DEH-P5800MP CD Player
Sony CDX-GT100 CD Player Logo
357 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
