Question about Sony Xplod 240 Watt 6" x 9" 4-Way Speaker Car Speaker
Making boxes for 6 by 9 speakers
How do i make a box for my 6 by 9 speakers?
  • 27 Answers
Easiest solution for this would be to buy a pair of enclosures that are already made, the same as you would a subwoofer enclosure. You can get them anywhere you'd look for stereo gear. I like to to run a bead of liquid nails construction adhesive around the inside were the panels join together. This works better than a regular caulk as it helps make the box stronger. If you really want to make them yourself then you'll need 5/8" medium density fiberboard, liquid nails,carpeting, terminal cups....and some patience to put it all together...
Posted on Mar 22, 2008
Box specs for 10d2
this a a impedance-2 ohms speaker sealed box 0.54 cu.ft. and a ported box 1.04 cu.ft. top mountdepth 5 9/16in bottom mount depth 6 5/16" cut out dia. 9 1/16"
Nov 21, 2013 | Car Audio & Video
My one kickers car speaker won't turn on, i replaced the old speakers and put these new kickers 6" speakers. One speakers works but other one doesn't?
try bridging them , first check wires from amp to box or boxes connectors , then check wires inside the box or boxes , then check fuses on amp !
Sep 18, 2013 | Kicker Car Audio & Video
What is the size of the speaker box that suites an 8inch stereo speaker
This is a perfect box for a single 8" sub
Height 11-1/4"
Width 16-15/16"
Depth 4" (top); 6-5/8" (bottom)
Apr 02, 2013 | Car Audio & Video
Pull out the grill buy using a paperclip with a short 90* bend on
on one end. Place it through one of the grill holes in the corners and gently tug. Work your way around the edge of the grill until it comes out. Be careful not to bend it. Unscrew the 6 phillips screws on the speaker panel. Then use a thick bladed putty knife on the groove that surrounds the whole box. Twist the putty knife handle a little at time, work your way around the whole box. It will eventually come off. Just be slow and careful to avoid nicking up the box.
May 11, 2011 | Niles OS10 Speaker
6 ohn wharfedale speakers on an 8 ohm TEAC amp (both old) - will that work
Yes. Most if not all speakers have impedances which vary with frequency and are rated at a nominal or average impedance. So a manufacturer who rates their speakers at 6 ohms may be more honest or chooses to quote it at a specific frequency. So a nominal 8 ohm speaker may actually measure 4 ohms at 100Hz and 12 ohms at 500Hz but averages somewhere nearer 8 ohms. It is normal for most speaker manufacturers to simplify their ratings so speakers which average at say 6 ohms would be categorised as 8 ohm, and 4.9 ohm averaged speakers as 4 ohms.
As a point of interest - some amplifiers are specified as providing their maximum power at impedances of 6 ohms, and there fore some speaker makers (including those made by same manufacurer as amplifier) will rate their speakers at 6 ohms so they appear more compatible.
Mar 05, 2010 | Audio Players & Recorders
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
i doubt that they all blew, i would check the wires where the go into the radio to be sure the connection is good there first and also that you are getting power to the radio.If that dont help let me know and we will go deeper into the problem.
Jan 17, 2009 | 1981 Chevrolet Corvette
Volume very low won't go up
After I posted my problem, I browsed a bit further through the other posts and solutions, until I came across the solution of TrickyTrev34 and gave it a try. However, I did not slice the cable, but did it as follows: 1. Switch off power of the sound system on the subwoofer box. Disconnect the Front Right (FR) speaker box (the one with the volume control) from the subwoofer box.
2. Remove the silver coloured metal oval on which the speaker box stands. Now you'll see a small screw at the bottom of the speaker box. remove it. 3. Carefully remove the silver coloured metal protection plate (with all the little holes) from the front of the FR speaker box by wedging it from the top with a flathead screwdriver or other thin blunt object. Now you'll see the speaker and 4 holes with screws inside. Remove screws and speaker box opens up. 4. Inside you should see six wires (Red, Blue, Yellow, White, Green & Black). Carefully cut the GREEN wire only.
Insulate the both ends of the GREEN wire with electrical tape or heatshrink or similar.
5. Put the FR speaker box back together in reversed order. 6. Connect FR speaker back to the subwoofer box. Make sure the volume setting on your PC is very low, because when you switch back on the power of the subwoofer, you should be blasting again. As TrickyTrev34 already mentioned, the only downside of this procedure is that it will disable the volume control on the FR speaker, but who cares, your sound system works again, and you can still control the volume via the PC playback control panel and/or the multi-media keyboard if you have one.
Aug 08, 2008 | Altec Lansing Multimedia Computer Speakers
Hey merrybell;
So, you have a flat panel with no sound?
Well, with out Brand or Model let me start here:
1. Unplug 'flat panel',cable box or sat. box from the power source, a/c cord from wall, for at least 4-5 minutes, plug back into wall.
2. Make sure volume level on TV and boxes are turned up, some cable boxes have volume controls.
3. Ensure that speakers are turned on, some 'flat panel's' have options of turning speakers off. Check
4. Double check all cables from 'flat panel' to "boxes", make sure they are secure.
5. Try different inputs and devices (dvd) on 'flat panel' or cables.
6. If still no audio, one the boards may be defective.
If so make sure you call a factory authorized service dealer to service your 'flat panel.
Good Luck, Big Irish, get back if have any more info.
Jun 20, 2008 | Televison & Video
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Sony Xplod 240 Watt 6" x 9" 4-Way Speaker Car Speaker Logo
157 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
