Stuck dvd on top of other in player - need help!!!
I have a samsung dvd 4300 and I accidentally stuck a dvd on top of one in there already...of course it will not eject. How do I get it out? I live in Mexico, so sending it in is not that easy.
  • 168 Answers
If you are comfortable taking the cover off, you can try removing the cover and then try and remove the DVD by yourself.
IF you are not comfortable removing the cover then, you can try to take a credit card trick that has worked for me.(Actually, if you have any of those JUNK credit cards that the CC companies send out as trial offers, those work the best, and who cares if you bend those, they get tossed anyway) and bend an edge at a 90 degree.. (about 1/8" of the edge) so it makes like a small ledge. Try to fit it inbetween the top of the door, and then see if you can open it up. Some players have a seperate door, and some trays are attached to the door. You might be able to help it out or unjam the tray this way.
And in the Future, with any other CD/DVD Players, use your remote control or the open and close button to open and close the tray, and NEVER Push on the tray itself. If I had a dollar for every dvd player tray that Ive fixed because of this, I would be buying bill gates dinner. (not really, but you get my point)
Good luck.
Mac =)
Please remember to leave a feedback and or rating if I have helped you with your problem.
Posted on Mar 21, 2008
Dvd stuck in Samsung bluray
Have you tried pulling the plug for a minute? Also try the eject button directly from standby.
Nov 26, 2013 | Samsung BD-F5100 - Blu-ray disc player
Our Samsung DVD-H1080 DVD Player wont open, we've had it for a while, but the place where it opens is stuck, help??
Are you using the remote or touch button on case to eject tray?
Sometimes the top lid gets warped and prevents the tray from opening. Press eject and lift the front part of the lid at the same time.
Aug 17, 2010 | Samsung DVD-H1080 DVD Player
My DVD player stays stuck on loading. How can I
If all DVD's you try act the same, I would clean the read head. If that doesn't work, then drive needs to be serviced. Hopefully nobody smked cigarettes near the unit as that coats the optics. Clean the read head VERY carefully with a Q tip and 99% isoprophyl alcohol. Ensure that no fibers get stuck around the read head... it is VERY fragile.
If only one disk won't finish loading, then the disk itself is probably bad and the drive is OK.
Jan 03, 2010 | Samsung DVD-V5500 DVD Player/VCR
Stuck in
Defective board (main causes this) i got part numbers if needed give me actual model
Oct 01, 2009 | Televison & Video
DVD will not Eject
answer - had the same issue turned out to be 3 dvds in it, Remove the 4 screws holding the dvd player to the roof. wire harness will hold it up. There is an fm transmitter on top held on by three screws. remove the little screws and push the transmitter to the side. you winn now see the stuck dvds. push the extras out with a small screw driver. once they are out the eject button will eject the last dvd.
just worked for me hope this helps.
Jul 04, 2009 | Jensen 8.5'' Overhead DVD Player Package...
DVD stuck in player
make sure that the dvd is unplugged from the outlet and remove the screws of the cover, you should be able to access the dvd from inside the player without the cover on.
I hope this helps
Jun 28, 2009 | RCA DRC225N
Samsung BD-up5000 stuck on slideshow
there is no present fix for this if i remember the hulk has this too the only way around this is to go into menu and turn off the on screen display messages
May 12, 2009 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Displays no disc
I had the exact same problem. When I finally opened the top there was another disk already in there. I guess if the unit shuts off and you leave aa disk in it will stay in the player even though when you open the door to place another disk in the tray will be empty. All you have to do is unscrew the cover aand then you will see a crossbar held in with two screws where the disks are. unscrew them and take out the two disks thay are stuck togeather. Replace eveything and rescrew and enjoy the movie!! Hope this helps!
Sep 18, 2008 | Philips DVP3982 DVD Player
Stuck dvd in the machine on top of one in there already - cannot eject - help
If you are comfortable taking the cover off, you can try removing the cover and remove the dvd's yourself.
IF you are not comfortable removing the cover then, you can try to take a credit card (Actually, if you have any of those JUNK credit cards that the CC companies send out as trial offers, those work the best, and who cares if you bend those, they get tossed anyway) and bend an edge at a 90 degree.. (about 1/8" of the edge) so it makes like a small ledge. try to fit it inbetween the top of the door, and then see if you can open it up. Some players have a seperate door, and some trays are attached to the door. You might be able to help it out or unjam the tray this way.
Good luck.
Mac =)
Please post a rating or feedback if I have answered your question.
Mar 21, 2008 | Televison & Video
DVD stuck in player
take top piece of the dvd player. there are about 7 screws.  5 min fix
Aug 11, 2007 | Samsung HT-DB600 System
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
