Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne Logo
Posted on Apr 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can the battery be replaced?
Can the battery be replaced in the electrolux pronto 2 in 1 model 1000
eVacuumStore.com
Level 2:
New Friend:
  • Expert 47 Answers
  • Posted on May 01, 2010
eVacuumStore.com
Expert
Level 2:
New Friend:
Answers
47
Questions
0
Helped
28115
Points
115
No but there was a recall on the battries, so try calling electrolux usa and they should replace it for free.
Vacuum battery replacement
There is no battery replacement for this model. You can try buying a new machine from evacuumstore.com Vacuum Cleaners Parts and Accessories
3helpful
2answers
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
I just purchased the pronto 2 in 1 stick vac, however the instructon manual was not included, how do i change the battery?
When opening the pronto, make sure that you check close to the motor for more cells, depending on the model and voltage you may have a few more away from the ones in the handle...
Mine has 6 cells, 4 in the handle and 2 on the sides of the motor. I'm not certain, but I don't believe there is a model with only 4 cells. Replacing only a few cells would help, but isn't a long term fix
16helpful
2answers
21helpful
4answers
Batteries are not recharging. Where can I get replacements for Model EL1000 Pronto Vac?
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
1helpful
Is it possible to replace the battery (loosing charge fast, weak power) for Electrolux stick vac EL 1000? Wher to buy the battery an dhow much cost? Thanks LJ
13helpful
Electrolux 2-in-1 Pronto does not hold charge, I believe it's a battery problem. How do I get then replace the battery, since it is located in the hand vac part of the vacumn?
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, I just replaced the 4 original EMX1600sS batteries by anotther model with the same specs and my PRONTO is working fine now. The battery model is
There are other similar models available that could be used but have in mind the limitations for the dimensions and capacity in mAh.
The dimensions of the original cylindrical batteries are aprox. 33 mm (1 1/4") X 22mm (7/8").
Good luck.
50helpful
5answers
Battery for electrolux pronto stick vac 2 in 1
This battery works perfect too (for your model), take a look on amazon: Amazon com tenergy 2 3a 1600mah nimh. Cheers
9helpful
Battery needs to be replaced in eletrolux pronto 2 in 1 stick vacum,can i order one
Good luck.
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
