Question about Car Audio & Video
Kenwood KDC-MP202 sound turns off when headlights are turned on
Everytime i turn on my headlights at night, my system's sound turns off. its not the whole system, just the sound. i kno i blew a fuse when i first installed it, but it was replaced. CAN ANYONE HELP ME?
ps. during the day i have no problems with the system, and the sound is great, its just when i turn on my headlights is when the problems starts
  • Dremaniac Mar 21, 2008
    nope the brown wire is not connected to anything, and i dont have any amps or anything of that sort. i mean, could it be a fuse or sumthing?
  • Dremaniac Mar 22, 2008
    ok thnx for the info but it still doesnt work. i took off the red and yellow wires from the stereo and put them to the blue with yellow strip, which is the +12 volt battery wire. and i left the gray one from the stereo harness alone. and it doesnt do anything but let me play the system with the car off. but i have nboticed the when i turn my lights on, the clock light gets dimmer. should i try the fuses?
Just solved a similar problem on my car i bought a Cd/dvd player for my 2000 concord lxi i hooked it up and hooked a rear-view camera and it worked perfect but wen i turned the headlights on the cd player shuts of so i disconnected the orenge wire that came out of my cd player from the orange on the aftermarket harness then grounded the ping wire (rear con wire) it worked fine but i couldn't see any footage from the camera for that i bought a long red power wire and hooked it to the red camera power wire that hooked from camera to reverse light and took the other end of the new wire i bought and hooked it to the orange wire that came out of the cd player now every thing works fine. you probably dont have the right power to run both cd and head lights thats why you need constant power to run both just hook up an extra wire between a positive wire to the orange dimmer wire its simple;
ground to ground (black)
12+ positive to 12+ positive (red)
and an extra wire (usually a red 18 guage wire bought mine at walmart) to the dimmer wire from the back of the cd player (orange) kenwood KDC-MP202 sound turns off when headlights  - edit.gif
Posted on Feb 11, 2013
  • nir naor Feb 11, 2013
    just solved a similar problem on my car i
    Brigadier General:
  • 6,966 Answers
I am assuming that your power wiring is correct since it powers up,
Yellow - always on B+12 such as the + terminal of the battery
Red - switched on B+12 such as the ACC terminal of the IGN switch;
Black - chassis body ground (GND)
If everything works, then I can only suspect that you have also wired the brown wire. This is the telephone mute for use with some mobile phones. Removing its connection to anything (if wired) should correct your problem.
If you have an external amplifier, you may also want to check that the pink/black wire only goes to the remote trigger terminal of the external amp. and nowhere else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 21, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Mar 22, 2008
    Hi again,
    Appreciate the post back and additional information.
    That being the case, I then would venture that the switched B+12 is not getting enough "juice". It would seem that the headlights are consuming the lion's share of the power and little is left over for the radio. To verify this, temporarily remove the red and yellow wire from where they are currently connected and wire both of them directly to the +12 terminal of the battery. If stereo works even at night (with headlights on) then the connection points of either the red and/or the yellow are loose or not properly tightened.
    In some rare instances, it is the body ground/chassis. The same verification procedure could be performed,. Run a wire from the battery's - terminal to the chassis of the stereo.
    Pls post back for any development(s).
    Cheers.
  • Louie  Role
    Additionally, it could be the fuse holder, clamps or clips or those holding the fuse terminals.
  • Louie  Role
    Louie Role Mar 23, 2008
    Hi XX,
    Could you pls try a different wire preferably a new wire solely and exclusively to the yellow and red of the stereo straight from the battery's + terminal. Not the blue with yellow strip or any other wire from the car's harness. And pls to the terminal itself, not any of the wires connected likewise to the + terminal. You could simply insert it between the battery pole and clamp.
    I'm thinking, you're probably right about the fuses and/or possibly the fusible link.
I bought a car with a Kenwood KDC X 569 system and when I went to lay the remote down the system turned off I don't know if I hit a button or something but it wont turn back on please help
Kenwood Excelon KDC-X569 - Crutchfield
www.crutchfield.com > ... > All Car Stereos
Crutchfield CorporationThe Kenwood Excelon KDC-X569 CD receiver jumps out ahead of the pack, ... only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories ... HD Radio reception, and connections for building an audio system in your car. .... You can turn on/off this feature in the menu. ... Purchase accessories for this product.
Kenwood BT648U Car Audio How to reset a ... - YouTube
? 4:27
https://www.youtube.com/watch?v=NjzCs-WVPak
Feb 27, 2012 - Uploaded by Paul Tran
This is a video if you dont know how to reset a kenwood bt648u or any o... ... I was in dark ... what happened to ...
Dec 03, 2015 | Kenwood Car Audio & Video
Everytime I turn on the truck my kenwood kdc-138 goes into standby mode How can I get it to stop going into it
You need to wire in a constant power use your meter and turn the key off and look for constant 12v power with the key off that is the wire that runs your memory clock,presets etc..
Aug 27, 2012 | Kenwood KDC-138 FM / AM Receiver
How can i stop my kenwood kdc-3047a car radio asking me if i want demo mode turned on everytime i turn the unit on?
press and hold the menu button for a few seconds, the use the am/fm buttons to scroll through the menu. when you get to demo press the seek up or down button to turn it off. press the menu button again to exit menu mode.
Oct 28, 2010 | Kenwood Car Audio & Video
Hi i live in israel and i bought Kenwood KDC-MP202 , but the frequency searh is different. In israel like in europ the frequency searh is every 0.1 MGHz, how can i change this function
I don`t know the exact method for this Kenwood but on most radios there will be a MENU option ( usually an M button) and scrolling through that normally allows the settings to be changed from UK > Europe> Asia > /USA or similar options
Sep 01, 2010 | Kenwood KDC-MP202
Kenwoodkdc-mp202....how do you set the time? how do you change the display color? i was told it can be red or blue
CLICK HERE to view the manual in PDF format.
It has a 2 color display - but is not user selectable. Button background is red - display is blue.
Setting the clock is on Page 21 of the manual.
THanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 30, 2009 | Kenwood KDC-MP202
Problem w kenwood ipod
you might want to reset the the raido there is a little button on the bottom of the radio push it in
Aug 04, 2008 | Kenwood KDC-MP335 CD Player
When i turn my headlights on my stereo turns off
you problably hookied the Illumnation lead to the ground lead on the radio, it will appear as a ground with the lites off and go live 12v @ lights on.
Reground it :)
Jul 03, 2008 | Kenwood KDC-135 CD Player
Kenwood KDC-322 volume cutting out
there buggers rewire the earth/ground
Jun 19, 2008 | Kenwood KDC-322 CD Player
Protected code
this link will help u taking the protected code off good luck
http://inform3.kenwoodusa.com/manuals/KDCMP2032.pdf
Oct 28, 2007 | Kenwood KDC-MP202
Car Audio & Video Logo
1,007 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
