Question about Nokia 3100
Ringer doesnt work Nokia 3120
The keys tones works, but the ringer on incoming calls and the alarm doesn't work.
  • 1 more comment
  • 4891 May 07, 2008
    trytr
  • Anonymous Dec 25, 2008
    I have Nokia 6030, there is ringging problem, even i have done all best setting, but it's not working. can any one know the solutaion to fix the problem.
  • Anonymous Mar 30, 2014
    Ringer not coming on for incoming calls on my I phone
Have just fixed this problem on my 3120 everything else was working on it except this. If you take apart the phone starting with removing battery, then the face plate and touchpad, then using a T6 screwdriver remove the 6 screws holding motherboard to the chassis and remove motherboard. Then remove silver metal base plate to expose the Antenna Assembly, very gently remove this part as this is where the ringer is. When you are looking at this you will see two little spring loaded balls on the left hand side, you should be able to put your finger on one of these to get a clicking sound. Both of these should be in the up position if not do this, with a very thin blade gently go into the seam nearest the spring loaded balls and cutting thru the glue go along edge of seam until they pop up. Then put it all back together again and hopefully this has sovled your problem. My phone was out of warranty and i had 3 quotes of $70-$90 to fix so i had nothing to loseby doing this.
Posted on Jan 16, 2009
  • 4,102 Answers
Hi follow these instructions
1 menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
once you have done them settings try your phone and see if it works if not then follow these instructions
1. menu
2 settings
3. profiles
4 general then personalise
the set like this
Incoming call alert (ringing)
ringing tone (choose ringtone)
ringing volume (level 5 )
message alert tone (choose tone)
Keypad tones (on)
warning tones (on)
once you have changed the last setting press back then select activate your phone should be now be working if not let me know ok
Posted on Mar 31, 2008
    New Friend:
And 6 years later... so I found this web page after Googling the problem of my Nokia 3120 not ringing after I dropped it.
Roxydog1's reply about the two little spring loaded balls made me think that maybe I could make them get back to their correct position by banging the phone against a hard surface.
So I did that several times and eventually it worked. After banging the top right edge of the phone against my desk, the ringing started working again.
Where the "A" of Nokia is on the front of the phone, hit the edge of the phone (not the back or front or top or bottom) near the very top of the edge against a wooden surface, like a desk top.
If at first it doesn't work, hit it a bit harder, but use your common sense! Don't hit it so hard something breaks - you just need to shock those balls back into the correct position.
Worth a try if all else fails.
Posted on Feb 14, 2014
SOURCE:
No sound on incomming calls
Hi,why it does not ring out is because,the ringer is damaged..and it needs replacement. Before you replace it,you can clean up where the ringer is,there might be dirt stopping it to work.But you have to unscrew the phone to see where the ringer is.
Please if you have no knowledge about the phone,you can contact a skillful personnel for assistance.
Before that you can trythe below step,might just be a setting problem.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Have a nice day.
Sep 19, 2011 | Nokia C3 Cell Phone
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
NOK 5130 MUSIC EXPRESS, I M NOT RESET WITH DEFOULT RING TONE AND THEME.
I have a Nokia XpressMusic 5130c2 phone. When someone calls me there is music that they are hearing instead of a ringer tone. How can I remove this & just for my incoming callers to get a normal ringer tone? Thanks
Sep 17, 2010 | Nokia 5130 Cellular Phone
Nokia 1110i incoming call is not ringing
Your Phone Ringer Default So Please change Ringer And Problem will solved .
thanks.
Jul 20, 2010 | Nokia 1110 Cellular Phone
No ring tone for incoming calls
If in settings, ringer is set on, then either your ringer is faulty and needs replacement or the ringer line is broken, check here.
and please dont forget to say thanks
May 21, 2010 | Nokia 1112 Cellular Phone
My handset ringers are ''off''. How do I turn them on again? Uniden TRU4985
Hi there try this,
When the phone is in the standby mode, press menu/mute.
2) Press select/ch.
3) Press + or - to move the pointer through the ringer
settings (Ringer Off, Ringer Low, or Ringer High).
You will hear a ringer or melody at the selected volume.
4) Press select/ch, you will hear a confirmation tone.
Ringer Mute (temporarily)
You can temporarily mute the ringer tone. When the handset is off the base and the
phone is ringing, press end. The ringer tone will return to the previous setting starting
[ 20 ] BASICS
• If you select “Ringer
Off”, “Ringer Off”
appears on the display
when you make or
receive calls, or
charge the handset.
Ringer Volume Setup
1) When the phone is in the standby mode, press menu/mute.
2) Press - to move the pointer to “Ringer Tones”, then
press select/ch.
You can choose from 6 ringers or 4 melodies:
- Ringer [Flicker, Clatter, Leap Frog, Ping Ball, Reminder,
Soft Alert]
- Melodies [Beethovens9, For Elise (Elise), Merry Christmas
(Merry-Xmas), Home Sweet Home (Hm Swt Hm)]
3) Press + or - to move the pointer. You will hear the ringer or
the melody as you scroll through the options.
4) Press select/ch and you will hear a confirmation tone.
Ringer Tone Setting
• If
Sep 27, 2009 | Lands Phones
Not working ringer
menu
2 settings
3 tones
keypad tones (on)
Jul 03, 2009 | Nokia 3100
Nokia 1100 incoming call is not ringtone but vibration is ok
Dear anusv99
You need to changed u r phone ringer, but somtimes it start by some claning, open ur mobile cover & clean the speaker area with the help of tooth brush gently,if it doesnt work change ringer
Regards
Please let me know ur comment
Feb 26, 2009 | Nokia 1100
Ringer not work
try to check the buzzer,if ok,go to check the buzzer lone...
Jul 17, 2007 | Nokia 3120 Cellular Phone
Nokia 3100 Logo
1,050 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
