Question about Dishwashers
I have a Blanco Dishwasher and the water will not drain away from the machine after it has completed a cycle, how do I get it to drain?
  • steve821 Mar 23, 2008
    Thanks for the advise Skill Will, since posting my problem, I had a need (I was sick of doing the washing up by hand) to investigate the problem myself. I bought some "Draino Gel", did my sink and then placed about 1/4 of a bottle of the "Draino Gel" in the bottom of the dishwasher. I realised that there would need to have been a pump of some sort to extract the water out of the machine, I was hoping that this was not the problem I was facing. I left it in the machine for about 30 minutes then ran the dishwasher through 2 complete cycles. Fingers crossed and to my amazement it worked. It appears that it was a blocked pipe.
    Thanks again for your advice.
    Regards
    Steve
  • 53 Answers
Hi, there are 2 pumps on a dishwasher, it sounds like the drain pump on your unit is not working, it may need to be replaced. . if it is in warranty contact the manufacturer, if not contact a local appliance repair company. in the mean time you can use a wet/dry vac to get the remaining water out of the unit.
Posted on Mar 21, 2008
SOURCE:
My Tecnik SD13J1 dishwasher (E-Nr SF6 TIE1 GB/21) had water in the bottom of it this morning. As it ran during the night I'm unsure whether the cycle had completed or not. I have removed the lower arm and...
The water usually comes from under the sink it is a 3/8 line from the hot side. it sounds like you have a bad valve or stuck float. check for a small round device in the left or right front corner and makes sure it has nothing under it and is pushed down
Jun 28, 2014 | Dishwashers
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
Blanco dishwasher error d06 faulty motor.
I have a Blanco BFD10X Dishwasher which had the same D06 error, being a Electrician i investigated the fault which Blanco report as motor over current. After testing the motor, i tested the motor Run capacitor and found it to be faulty, these capacitors are common to failure and will cause the pump to draw more current than usual.
A genuine replacement 2.5uf capacitor was quoted at $120.00, however i purchased a equivalent from RS online for $14.30 + delivery. RS P/N 769-4267
Dishwasher working fine again.
Nov 15, 2011 | Dishwashers
After dishwasher completes cycle, it starts again. It will keep going unless we stop it.
If the cycle does not stop that is usually because of a faulty water level sensor. The floater that controls the water level in your appliance.The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely. Check if sensor is stuck or if switch is faulty.Some machine may use a membrane switch instead of a floater.
Mar 27, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher will not go through complete cycle it will not take water away
most washing machines nowadays have a electrically operated switch that will open to either drain or let in water if ur machine does not drain the water the machine will not go ahead in completing its cycle as the sensors sense that there is water in the drum so unless the water drains u will have this problem. Check for a click sound when the machine reaches a point to drain if that doesn't happen then it is this drain switch that isn't working
Jul 01, 2009 | Electrolux Dishwashers
Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Apr 14, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
739 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
