Question about Cameras
Balancing my Telescope
I'm trying to balance my Celestron AstroMaster 70 EQ refractor telescope, but the manual is confusing. This is the first telescope I've owned, and could really use some help.
Hi Twiggie,
You will find good advice here:
http://starizona.com/acb/basics/using_balancing_gem.aspx
Good luck,
Clive.
Posted on Mar 21, 2008
WHEN I LOOK AT A DIFFERENT OBJECT THEY ALL LOOK THE SAME
  1. Get Stellarium or another fine astronomy program
  2. During the day, point the telescope at a part of the landscape about 100 yards away.
  3. Use the lowest power eyepiece (highest number) in the focal tube.
  4. Center the landscape object in the telescope.
  5. Align the finder scope so that it points exactly where the main telescope is.
  6. At night, leave the scope out to reach thermal equilibrium (about an hour for small reflectors and refractors)
  7. If the scope is on a EQ mount, polar align.
  8. Point the finder at the moon. The moon should be in the main scope also.
  9. Practice finding the moon before you start on the planets
  10. Once you are comfortable with the moon and planets, you can go for the deep sky objects
Dec 30, 2011 | Celestron AstroMaster 70 AZ (160 x 70mm)...
Celestron astromaster 114eq see only pitch black
Dec 27, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
Not able to see anything would like how to use cerlestron EQ 114
This is a small reflector style telescope on an equatorial mount. The mount and tripod must be polar aligned in order to be used. Read this:
http://arnholm.org/astro/polar_alignment/index.html
Simply pt the eyepiece with the largest number written on it into the telescope, take the scope outside during the day time and practice focusing on a distant object like a building.
Celestron's manuals are located on this web site-- find your scope and download one for free:
http://www.celestron.com/c3/downloads.php
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Aug 13, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
Need manual
Please go through www.celestron.com Than you check Powerseeker 60 or 79AZ or Astromaster 60/70/70.You will find menual & download.
Jul 11, 2011 | Meade 60AZ-M Jupiter Telescope 60mm...
How to use the celestron Astromaster 114EQ
This is an EQ mount which must be polar aligned in order to be used:
Read This:
http://www.optcorp.com/product.aspx?pid=3050
Dec 26, 2010 | Celestron AstroMaster 114EQ (100 x 114mm)...
Hi where can I find a manual for the Celestron 130 EQ
All of Celestron's manuals are here:
Your scope is on an equatorial mount which must be polar aligned in order to be used. Read this:
Dec 24, 2010 | Celestron AstroMaster 130 EQ Reflector (65...
Latittude adjustment bolt jammed tight on Celestron 130 EQ, I am thinking of taking it to a repair shop, so I don't damage it in attempting to loosen it (its very jammed)
A machine shop should be able to remove the bolt and re-tap the hole if needed if it is stripped.
OR- you can improve this telescope by improving the MOUNT to something like this.
http://www.telescope.com/control/accessories/mounts-and-tripods/orion-skyview-pro-equatorial-telescope-mount
Jan 11, 2010 | Celestron AstroMaster 130EQ Telescope
Problem focusing on distant objects
collimate your mirror.
sky and telescope shows you how to do it.
it's under 'Do-It-Yourself' section.
hope this helps :D
Aug 26, 2009 | Celestron AstroMaster 114 AZ (50 x 114mm)...
Celestron telescope
Eyepieces are readilly available: www.telescopes.com has a huge selection in many styles and price ranges.
May 27, 2008 | Celestron Optics
Cameras Logo
126 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
