FixYa.com
Tags:
Olevia LT27HVX 27 in. LCD Television
SAME PROBLEM WITH MY OLEVIA LCD (by 4 users)
posted by TUPIE on Mar 21, 2008
HAVE YOU FIGURED OUT WHAT IS WRONG WITH YOUR TV? OURS HAS THE BLUE POWER LIGHT ON AND WON'T TURN ON. WE HAVE HAD OURS FOR ABOUT 2 YEARS. PLEASE LET ME KNOW IF YOU CAN HELP.
THANKS
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on May 29, 2008
I have had my Olevia for 4 months and it will not turn on. The blue light is
lit but nothing happens. Is this Tv a Lemmon ? ? Help Laura
Comment by heyshay, posted on Apr 01, 2008
same thing here. i can't even get the menu to come up on the screen - it does show the white welcome screen with the brand name when 1st turned on, but then the screen goes black. any one know what to do??
Comment by Traylor9, posted on Apr 01, 2008
I have the exact same problem and my TV is only two years old. Light is on but TV will not come on.
Best Solution
posted on Mar 25, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This just happened to ours -- any solutions?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 09, 2008
Not Rated (0)
w2power
Rating: 88%, 5 votes
I think this model has a timer on it, it seems to go when the warranty runs out, not proven but Mine went out about a month ago. My only fix is to plug my tv (via the service port which is COVERED) to the usb port on my computer using my BlackBerry usb cable, in other words the Mini USB. Seemingly I must be logged on to do so and wait for the Chime form my pc, a balloon will pop up for new hardware not recognized (vista) then press the power button and then it turns on, unplug the usb cable and make sure the source is set to tv / video or else it will power back off and you will have to start all over. Theres NOT A PERMANENT fix yet but this is what I do every time I want to use the TV, I have a laptop so I use it as the Monitor just to watch movies. If you have a desktop I recommend keeping the cable handy BUT DO NOT LEAVE THE USB CABLE IN FOR LONG USES. THE SERVICE PORT IS COVERED FOR A REASON!!!
Can you Help with these Flat Panel Televisions problems?
says no signal when switched to...
I just hooked an hmdi cable to... Answer This...
Will not turn on
The power light is on, the... Answer This...
olevia 227-S11 driver for...
I have a lcd-tv olevia using... Answer This...
Olevia power problem
Just wondering where this... Answer This...
tv mode on the tv is acting up
the picture keeps running off... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
