This problem should be removed because:
Problem with KitchenAid 325 Watts KSM150PS Artisan Series Stand Mixer
vibrates and beater hits bottom of bowl
I've tried to tighten screws with no results
Solutions (1)
Best Solution
Try adjusting the height of the head by turning screw #36 counterclockwise a turn or so. This will raise the mixing head so the beaters no longer hit the bottom of the bowl. Refer to parts list:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
If the pivot pin #18 is not centered and secured then center the pin and turn the mixer on its side to tighten screw #31 from underneath the mixer to secure the pivot pin.
beaters hitting the bottom of the bowl, and...
beaters hitting the bottom of the bowl, and can't tighten the screw at the base of the arm any tighter. what to do?
Kitchenaid Mixer head wobbles bad
HI, I am getting a kitchenaid from someone and they said they bought a new one cause the mixer head wobbles. They said kitchenaid said it...
KitchenAid 2671 Mixer always wiggling
I open the top cover and tighten three screws to hold the top. About 3 or 4 times of using, it's wiggling again. Anybody know how to...
mixer head loose
I have the Kitchenaid Professional 600 stand mixer. It's about 3 years old. I tried mixing pasta dough and notice the mixer head loose....
Add Your Solution
Mixer stuck on slow speed
My KitchenAid KSM150PSPK mixer will only run on slow speed. I have tried changing the speed setting, but it remains at...
KitchenAid Artisan Stand Mixer won't stay...
Almost every time I use my mixer, the locking switch on the side will vibrate back to the "unlock" position....
when using the grinder attachment, made a loud...
Metal shavings were in the shaft after I removed the grinder
See all KitchenAid 325 Watts KSM150PS Artisan Series Stand Problems
Fix-O-Meter
1,903
1,903 people viewed this problem
- 14 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top KitchenAid Mixer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Mine has the droopy head, I tried playing with the screws with no results. Sadly the link above seems to be dead.
