Ghosting issue when I try to restore a ghost from ide drive to new sata drive using norton ghost 8 the system freezes and will not boot after power restart
  • Anonymous Mar 29, 2008
    thats strange ...
  • 13,434 Answers
Your going to have to reinstall your xp. If you don't have a cd you can take the laptop to a local pc repair / shop.
Posted on Mar 21, 2008
  • Ekse Mar 21, 2008
    I don't remember typeing that ansver for this problem and it aint even about a laptop!
SOURCE:
I hook up the sata bridge adaptor and my computer is not reconizing the the hard drive is even there i can hook it up to ide and it works fine just wont work with the bridge
The bridge has a jumper I believe next to where the powerplug is. This jumper must be pulled out and put on the A-B NOT the A-C if youare going to use the IDE ribbon cable. Another trick is do not use the IDEcable (extra) that you may have with or below or above your other harddrivesince bios will always keep trying to go to your SATA drive even when youchange your primary drive with working operating system to slave and changeboot order....will just show on screen something like no boot disc. The easiestway without messing with the bios and drivers and all is this....move jumper toA-C then use one of the IDE cables that you have (you should have 2) of youCD-ROM. If you are using 2 CD-ROM's remove one and plug this IDE cable intoyour SATA bridge. The computer will now find new hardware. Then right clickthat new found drive when you click "My Computer" from"Start" and "Format" it, just to make sure everything is off thedrive even if new it will not hurt. Not sure if you want your SATA to be yourprimary drive but if you do,you now can use Acronis Ghost software or other tomirror your primary drive onto your new SATA. Once done take out or dissconnectyour primary drive and install your SATA into that slot or above or below yourprimary drive if you have available room in your tower then hook that IDE cableto your SATA and hook power. BAM.. your computer will now use the SATA to bootup and all is fine. Remember SATA does not have slave/master jumpers like IDEdrives. Now if anything happens to that SATA you still have you disconnectedprimary drive to fall back on. If your concerned about wanting 2 drives you maybe able to take your original primary drive and change that jumper from Masterto Slave.Since bios will default to your new SATA drive now and use that hasyour master and boot up from that drive. If you do not want to use yourSATA as your primary without installing an operating system or usingghost/mirror software then to make life easier just use the IDE cable from oneof the CD-ROM's or get an extension IDE cable that will reach since your SATAdrive is smaller and most likely will not neatly fit into the CD-ROM slots. Youcan use the extra slot if you have one above or below your primary drive yourusing now, then plug your CD-ROM IDE cable (with extension if needed to reach)into SATA and then you can now use the SATA to send files and anything else youwant to store in that drive. Hope this helps.
Dec 29, 2010 | Kingwin SATA to IDE Bridge Board (ADP06)...
I have a XP desktop computer with SP3 upgrade. I want to replace the small IDE hard drive with an SATA 1GB drive. I can connect both drives to the motherboard. What is the easiest way to transfer the...
Well you can backup the system simply with the system state. However some files will be ignored. So what you have to do is to "Clone" the disk. That is the easiest way. Most of the Disk Cloning Software are commercial and not for free. But there are a few. You can use this product. This runs on Windows (win32). XX CLONE.
Download and install it. It has a Graphical User Interface with the necessary options. The image is bootable by default. It is fairly easy to get used with. Just plugin the HDD and back it up. Make sure you properly set the SATA as a slave. These settings can be accessed via boot options in BIOS. Use del,esc,F2 or F11 to jump in to BIOS settings before the system boots Windows. Hope you know the procedure. (Otherwise the System will be boot using the SATA drive instead of the IDE drive). Online manual for XXCLONE.
If you have any commercial product such as Norton Ghost or Acronis True Image you can use with a hassle. They are ideal for disk imaging. You have to purchase a key how ever. If you use a torrent downloader such as Utorrent, you can download with a key. But you cannot Register the key since they are used keys. So if you like to do that (we do not enforce piracy) download and use one of them. They are user friendly software and easy to coop with.
If you have any questions please feel free to ask. Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
Jul 09, 2010 | Microsoft Windows XP Professional SP2
I've connected my Samsung 250GB HD250HJ SATA drive (from a Linkstation) to my PC with a sata-ide adapter. It's recognised at boot time but I get the message 'primary master hard disk fail'. It isn't...
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
-Aaron
Dec 05, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
I've ms-7142 v:1 model mother board in this bios this not showing the sata option will u plz help me out of this...
go into the bois and make sure the sata raid or raid option is enabled, that should fix it
Oct 08, 2009 | MSI K8MM-V Motherboard
Don't know how to restore files from backup done with North Ghost
Using Norton Ghost 9.0 is very good program to backup your System & Documents.
You said the PC is dead then you want to restore back your System to a new PC.
All you have to do is that Norton Ghost 9.0 CD is Bootable.
Of course also your external hard drive are plug in it too.
Manually you're going to open that Sv2i file to restore back again your old system but there are some programs that are not going to use. Like for example: System Drivers (Motherboard Driver, LAN, SOUND, etc.) but at least you have the Documents and the rest of the programs run again.
I try it myself this kind of situation, I'm using Windows 2000 with Norton Ghost 9.0 version, and it's 100% works. Good luck!
Hope i might give you some tip & idea.
Tell me more about if you got a problem.
Please rate me.
Thank you.
Sep 04, 2009 | Symantec Norton Ghost 9.0 for PC
Ibm thinkpad T40 Hard Drive change out
After fdisk and format you need to ensure that operative system is installed into yor hard drive. Using ghost you restore the image disk by booting from ghost image CD if you made a bootable image disk. Ensure Bios is set up to boot from CD.
If you used Norton Ghost ensure you captured the image of full bootable original hard disk drive for same computer. If it does not boot after restoring ghosted image, than the image it is probably not complete. If hard disk image is not good, easiest thing to do is using Windows install CD to installl again operative system, then you eventually restore ghost image.
Aug 17, 2008 | IBM ThinkPad T40 2373 Notebook
RELOAD PROBLEMS
I'm not sure why they do the things they do, but they don't seem to put all the drivers on their restore disc. Here's what you should do. Since your old hard drive is still good, purchase a usb to ide/sata cable, ide or sata depending on which your hard drive is. This will allow you to hook up your old hard drive to your computer as a slave drive. This is going to help you in two ways 1- the drivers for your machine are still on that drive and you can have the hardware wizard find them there, and 2- you can use the old drive for storage, backup, or whatever.
Jul 24, 2008 | Gateway MX6025 Notebook
Duel boot system first xp then vista
Wow....
First I would check the BIOS settings. Make sure that the slave and master jumpers are correct on the drives.
Wouldn't it be easier to make one drive Windows XP on one drive while running Vista on the other?
It would make things easier to troubleshoot.
Jun 12, 2008 | Computers & Internet
Norton ghost 3 ide to sata
I face the same problem ,what i do is installing windows as a repaier copy for the system on new drive
Nov 17, 2007 | Computers & Internet
Sata Drive instalation
Hi, go into setup at boot [press delete key ] enable SATA drive here, this will set the Sata as primary master device, leave your old IDE drive as secondary master and I reccomend you set the 3rd drive as slave to your CD/DVD drive.
You may also like to clone the old IDE drive to the Sata drive, this way you will not need to reload all your programs and data, Acronis true image or norton ghost are both good programs are ideal for this.
Regards mistyman
Nov 01, 2007 | Syntax S845GE (SYS845GE) Motherboard
Open Questions:
Computers & Internet Logo
71 people viewed this question
Ekse
Alun Cox
