Help For Project
Hi...Could anyone tell me how to send emails from asp.net v1.1?
  • 31 Answers
The entire procedure Here
Posted on Mar 28, 2008
SOURCE:
Inventory Management System
i have a project. tell me ur mail id i will mail u.
Aug 08, 2009 | Microsoft Designing ASP.NET Applications...
Suggest me project(mca 6th sem)live provide companies
THE BEST DO'NT FIND THE PROJECT CENTERS IN ANY CITY THIS IS TELL FROM MY EXPERIENCE TRY TO FIND U R EX-SENIORS WHO ARE WORKING IN JAVA OR J2EE BECAUSE THEY CAN PROVIDE THE BEST PROJECT FOR U .IF U R INTERESTED IN ASP.NET I CAN HELP U
email: [email protected]
Jul 14, 2009 | Computers & Internet
Java source code for hospital management system
Sir,
I need a project of Hospital management system. Since client needs project in very sort time so plz send same type of project at my email id that can help me out in database design or full code in a professional way .. Please be in touch with me.
regards Varun kumar
email : [email protected]
Apr 18, 2009 | Computers & Internet
Source code for Inventory management system in ASP.Net
hey mail me also please i need it urgent for my final year project pls pls [email protected]
Mar 28, 2009 | Microsoft Designing ASP.NET Applications...
Please i want source code calculator using asp.net
i want the source code for simple calculater in asp.net
Mar 17, 2009 | Microsoft Computers & Internet
How to manage login data in asp.net?
how can i donload n73 3gpconventer
Jan 23, 2009 | Computers & Internet
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
CAUSE
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
WORKAROUND
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
Dec 10, 2008 | Acer Aspire 5610 Notebook
Problem of creating the master page in asp.net vb
Hi galondhe
I'm sorry It's not that clear what your problem is.
In Dreamweaver you save the page as a template which you can then apply to subsequent pages. Are you creating the asp.net page with all the data in it, then saving as a template?
Visual web developer uses master pages. You can always create the page in Dreamweaver and then take it into VWD to create your master.
I need a little more info to be able to help you.
Apr 02, 2008 | Macromedia Dreamweaver MX 2004 for PC, Mac
Help for project
Saang,
It is a really bad idea to use Office Automation on a web server, your application will not be scalable and will be full of problems. Trust me, I have already spent hundreds of dollars with Microsoft Tech support for this very thing. I code commercial applications for a living, best thing to do is buy an application that creates office documents for you easily through asp.net. I have used a product from Aspose and it has done great. You can download a free trial to check it out.
http://www.aspose.com/categories/ssrs-rendering-extensions/aspose.words-for-reporting-services/default.aspx
It will save you lots of time coding as well, because they make it very easy to customize your documents.
Hope this helps!
Mar 18, 2008 | Microsoft Word 2000 for PC
Open Questions:
Computers & Internet Logo
758 people viewed this question
Ekse
Alun Cox
