Question about Lexmark X7350 All-In-One InkJet Printer
AM/PM firmware problem on X7350 printer
I received a new X7350 printer for my birthday 2 weeks ago, and found that when I selected the 12 hr mode to set the time with, that when the time changed from 11:59PM to the next day, my date advanced by 1 day, BUT the time displayed was 12:00"PM" instead of 12:00:AM" as it should have been. Nothing I could do with Lexmark phone support could fix this problem including going into the Manufacturing menu by holding down the number 5 button and power button at the same time, and then selecting option #11 on the fax menu which cannot be accessed except with this method that Lexmark had me do. In option 11, I then selected "Clean NVRAM, what ever that is, and tried everything again, and the error was still there. Lexmark sent me a brand new replacement X7350, unopened, in it6's original box as a replacement, and believe it or not, this printer does the same exact thing. When the time changes from 11:59PM to the next day, the date changes correctly, but the time shows 12:00pm instead of the correct time of 12:am. Is this a known firmware error in all X7350 printers? I find it hard to believe that noone else has ever noticed this error. Does everyone out there use military time on there printers which seems to run ok on the X7350? Please give me some feedback here. Thanks
    Genius:
  • 3,587 Answers
Here's an idea..the printer doesn't know what time it is, so maybe it's Hawaiian...just kidding...do you have the user manual on this puppy?
Posted on Mar 21, 2008
6ya staff
SOURCE:
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How to set the time
How to set the time on what make and model device?
Mar 01, 2013 | GPS
I need to know how to set the clock on a 2002 xtype jaquar
Press and hold the MODE button until TA VOLUME is displayed
Repeatedly press MODE button until CLOCK SET is displayed
Seek up/ seek down keys select 12 or 24 hr mode
Press MODE Button
If 12 hr mode is selected use # button to selected Am or PM
Use keypad to enter time .... four digits
Press and hold MODE key to exit
Hope this helps!
Aug 11, 2011 | 2002 Jaguar X-Type
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
I wrote a few days ago and did not get a response. Please, how do I change my bose raio/cd time back to regular time. It just went to military time. I do have grandchildren maybe they did something. ...
To set AM/PM (12 hour) or Military (24 hour) time
- Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Jan 24, 2011 | Bose Wave Radio
Unable to choose "pm" when setting time
Good question! There seems to be a little confusion over this. It appears that some firmware updates leave you with an option to select AM or PM hours from the System Options-->Set Time on the remote. The most recent firmware update seems to have removed this ability, so only a 12hr clock is shown, but there is no option to set AM or PM. The clock will always default to AM. So, one workaround is to simply set the time before noon! Also, the remote will pick up the correct time when connected to the computer (assuming your system clock is correct) and you update the remote.
Sep 09, 2009 | Logitech Harmony 880 LCD Remote Control
Fails to connect during receipt of fax
You may have to decrease the transmission speed and turn off the ECM using the steps given below:
1. From the control panel, press Fax Mode.
2. Press "Menu."
3. Press "Up" or "Down" repeatedly until "Send Setup" appears.
4. Press "Select."
5. Press "Up" or "Down" repeatedly until "Max Speed" appears.
6. Press "Select."
7. Press "Up" or "Down" to select a "9600 bps."
8. Press "Select" to save the setting.
9. Press "Up" or "Down" repeatedly until "Send Setup" appears.
10. Press "Select."
11. Press "Up" or "Down" repeatedly until "Error correction" appears.
12. Press "Select."
13. Press "Up" or "Down" repeatedly until "OFF" appears.
14. Press "Select" to save the setting.
Apr 21, 2009 | Lexmark X7350 All-In-One InkJet Printer
Date setting of Frederique constant
hi
never change week or date when day is on "sun" or "mon" also never change date or week or day when time is between 9 pm and 5 am.
to change day, move time back and forth between 10 pm and 2 am.
moon will change only after 24 hr round (not during quick day change)
hope this helps
eli
Oct 17, 2008 | Watches
Aquatech watch
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
hope this helps
jeff
Jul 23, 2008 | Watches
Lexmark X7350 All-In-One InkJet Printer Logo
145 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
