Question about Logitech Harmony 670 LCD Remote Control
Problem with a screen display
A box appears in the middle of the tv which has a lower case i on the left upper side. The error message says "not available". We can't get rid of that error box! help. TK
  • 97 Answers
This seems like it would be more appropriate for the TV area as its not likely a remote issue. It sounds like you've accidentally changed source inputs to one that not there or the source you were on lost connection, if so check your cables if it HDMI unplug with everything off and reconnect.
Posted on Mar 21, 2008
I can't find my manual. I have model #kfis25xvms2 and I replaced the water filter and I need to know how to vlear message to replace H2O filter. Thank you
On the front of the refrigerator is located the electronic controls, just above the ice dispenser. There is a white box in the middle and four black boxes (buttons), 2 on each side. Press the upper left button which will activate the display. Press the lower right button - options - several times until it says "Replace H20 Filter", and presents a yes/no option. If you have replaced the filter, say Yes. The reminder will turn off.
Sep 14, 2011 | KitchenAid Refrigerators
Error 12 appears on display? What do I do?
Precor Error 12, Watchdog (Lower PCA) Probable Cause 1. A failure in the lower PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the low voltage power supply of the lower PCA to be too low.
3. A failure in the upper PCA that overloads the lower PCA low voltage power supply causing it to be too low.
Corrective Action
  1. If the error message is continually displayed when the unit is powered up, the upper PCA needs replaced.
    External causes may make the error appear intermittently.
    1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
    2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittently.
  2. Determine if the interconnect cable is the cause by substituting a know good cable in place of the current cable. For test purposes, the substitute cable needs to be connected directly between the upper and lower PCA's, without routing the cable internally.
  3. Determine if the upper PCA is the cause by substituting a know good upper PCA for the existing upper PCA.
Precor Error Code 12 12 Watchdog Lower PCA
Jul 12, 2011 | Precor EFX 546i Elliptical Version 4
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
LG Secret touch screen, can not use left upper, middle & right upper touch screen pad .... cannot add contacts, back space or forward a message .... When the phone is hot - the touch screen does not...
I have the same problem sometimes, when it happen I press the touch media key in the middle right side of the phone, and enter to the pictures aplication and exit touching the screen, this appear to recalibrate the touch pad most of the times.
Jun 06, 2009 | LG Secret ? KF750 Cellular Phone
Loss Sync
According to SharpUSA the problem with the "Loss of Sync" error message is that (most probably) the cables (between the box and the display) are not connected properly (so remove and reconnect them carefully, on both units) or a cable is defective.
Also, after you reconnect the cables try turning on the unit, if no success then depress the "clear" button on the external box (under the door on the front and on the bottom left and try turning on the TV again).
It is, most likely, that the cables are not seated properly. Reseat the cables on both the display and the external box.
Hopefully, this will clear the problem
if still does not solves your problem just replace all the cables connected between .u can get the new cables at radioshack web site.just place an order they will provide you. thanks.
Dec 14, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Big grey/black spot
Is it a fuzzy spot or an actual hard edged black spot?LCD televisions can have a loss of pixel display- most very small. Was the TV hit with something or dropped against something (the screen)?
OR Try this first:
Black box appears on the screen
• Closed-captioning might be on. Check the Analog or Digital Caption option in the Setup menu.
Please let me know if your problem is solved. Thank You.
Aug 15, 2008 | RCA LCDX2722W 27 in. Television
HOW DO I TURN OFF PREDICTIVE TEXT
First, hit the 'Message' button in the upper-left -hand corner. Select 'New Message'. Select 'New Short Msg'. An empty screen for inserting text will now be displayed. At this point press the top middle button (the one with the line on it like this -). Now the 'Message Menu' should be displayed. Scroll down to 'Entry Setup' & select it. Press the 'Change' button in the upper-right-hand corner when 'Primary Setup' is highlighted. Scroll down to 'TAP English' and select it. Now you are done. ('I TAP English is the setting for predivtive'. 'TAP English is the setting for manual').
Apr 23, 2008 | Cell Phones
Canon cd-4050
On the main screen tap the "QUIT" in the upper right hand corner of the scrreen. This should bring up a smaller box asking "Are sure you want to quit?" with a "Cancel" and an "OK" tab. Do not select either tab, instead tap you finger on the left side of the small box twice, then on the right side once, then again on the left side (L L R L) in rapid manner. This should bring up a small box stating you are in "Service Mode", tap "OK". This should bring up a box with 3 tabs at the top. Tap the "Battery" tab. The next box will have a tab on the lower left side "Exchange Battery", tap it, then tap "OK" on the next screen. This should set the battery install date to the current date and the expiration date 2 years out. Back out and shut down and reboot. You should no longer get the "Replace battery" message. The screen should display the new dates for the battery.
Hope this helps.
Dec 28, 2007 | Canon CD-4050 Path-Through Scanner
Setting tha alarm
Press MODE (lower left) button until "ALARM" appears in the display. Then press SET (lower right) button. T1 should flash to indicate you are setting an alarm for Time 1. Press MODE to cycle through the alarm settings. Press ALARM (upper right) button to advance the hours, tens and minutes to the desired time. When the far right of the display is alternately flashing "T1" and then "AL" you can change the chime and alarm tones by pressing the ALARM (upper right) button. The alarm is on if the middle symbol (lines) on the left of the display is shown. The hourly chime is on if the lower symbol (bell) on the left of the display is shown. When you are done, hit MODE (lower left) again to return to normal time display.
Dec 21, 2007 | Timex Expedition 40141 Wristwatch
Logitech Harmony 670 LCD Remote Control Logo
174 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
