Question about AKG K 240 Studio Professional Headphones
Right side gone dead.
Purchase time: 2006
When did the problem appear: 8 months later
Type of use: 80% loud live performance, 10% recording, 10% mixing
Detail of problem: First there was sudden loss in the high end and then the right side has gone completely dead. There is sound in the left with weak high frequency. It happened in the span of 3 or 4 days.
I also have a pair of K66 which was put into similar usage. It's still working fine.
    Novelist:
  • 155 Answers
It's difficult to say exactly what the problem is without being able to actually test them with a meter.
Unlike speakers (where you have a separate woofer & tweeter) the headphones only have a single driver per ear, so the loss of high frequency is unlikely to be a driver problem.
The place I would start looking at is the lead. Damage to the lead (or rather the internal conductor) or the plug can often result in a drop out of high frequncies.
The K240's are not discontinued, but you might be able to still pick up a replacement lead.
Hope this helps,
Matt
Posted on Mar 21, 2008
SOURCE:
Bosch logixx 8 error code 80
Unplug the unit from the wall for 5 minutes and see if it clears, if not call service.
Jul 21, 2012 | Washing Machines
Tip
How to Test Your Webcam Frames Per Second Performance
Have you ever wondered how many frames per second yourwebcam is sending? Choppy video, with out-of-sync audio, is typicallydue to low fps. Anything less than 8-10 fps is going to be noticeable.Now there is a free service that allows anyone to test their webcam fps. You don't have to download anything and you don't even have to register for an account. The service is called mailVU.com, and here's how to use it to measure your webcam performance.
Open any browser (Firefox, Chrome, IE, Safari, etc.) and go to http://mailVU.com. You will be prompted to allow access to your webcam. Select Allow.
You can now see yourself on the left side under LiveCamera. If you don't see yourself click on the drop down list ofcameras and select the one that works for you. On the Mac it istypically called USB Webcam.
Click the red Record buttonabove your image to start the recording session. After you click it thebutton will change to Stop and a notification will appear thatrecording is in process. When done click the red Stop button. To view your message simply click the green Play buttonabove your image. Your recording will now play in the right side windowwhile you still see yourself live in the left side Live Camera window.
Look under the Playback window and you will see your webcam fps performance!You can try this test as often as you like, from multiple locations,and with multiple webcams. Try it with different lighting and differentInternet connections (wired/wireless) to determine the best for yoursituation.
By using mailVU.com anyone can quickly and easily test their webcam fps performance. And asan added bonus it also tests your webcam video and audio quality. Ifyou like, you can also record and send free video mail right from thesite. Try it today for free!
on Jun 22, 2010 | Computers & Internet
2006 Toyota Corolla LE. Loud squeaking coming from serpentine belt area after I start the engine cold. Changed the belt recently but still noice persist. Loud squeaking goes away after driving for 3-5...
It is probably the tensioner pulley that's gone bad. It can be replaced separately, if you can purchase the pulley separately. As to how to go about changing it in such a small space, it's definitely possible, with the right type of tools. That's why mechanics have so many different shapes and lengths of the same size tools.
Jan 12, 2011 | 2006 Toyota Corolla
My xbox360 was working fine yesterday, i was trying to download a game but it wouldn't down load then this morning it quit working, saying i was out of memory. Should i reformat? if i reformat and it...
  1. Go to the "system" blade
  2. Select "memory"
  3. Press Y on the HD symbol
  4. Press X,X, Left Bumper, Right Bumper, X,X
  5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
  6. Select Yes
this will be slightly different on the NXE dashboard
this shouldnt format your entire drive but it will likely get rid of some stuff you wanted to keep. its better than completely formating.
as far as xbox live account goes. there is a relatively quick tool to recover your GT. if you go to the xbox live blade you should be able to locate it easily
May 06, 2010 | Microsoft Xbox 360 Console
Sony Vaio fan making noise
Hi:
Not sure of a user cause for the fan to run full speed, unless you are using the laptop in a high heat environment, or setting it on a bed or other area where it is not getting adequet cooling air. If it does it right away, when you turn it on , cold, then there might be a laptop hardware problem. If you leave your laptop on all the time, then you might be inducing the problem. I had a HP high performance laptop, that the fans would not turn on at all till it ran an hour or so, then they would stay on loud for 10 or 15 minutes, then shut off, then cycle.
Nov 10, 2009 | Sony VAIO VGN-N130G/W Notebook
Jaguar x type 2004 2.5 petrol V6, 38500 miles, codes P0171, P0174
Have exactly the same issue on 04 jag x type 2.5. So far have replaced fuel filter, air filter k&n, plugs ngk. Codes cleared, same issue. Seems to appear when air temp is cold and eng is warm.
Am replacing upstream O2 sensors and cleaning MAF next. Will keep you posted if it clears up. Did you ever find the cause?
Aug 25, 2009 | 2002 Jaguar X-Type
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Rear Upper strut bushing problem
go to some one different sounds like the struts are gone like mine was at one time.
May 11, 2009 | 1995 Buick LeSabre
Just bought it but threw the box away because it worked right the first time!
Caution - some manufacturers recommend a specific type of CD for recording, otherwise the unit may not record properly. Was the CD a CD-R? CD-RW? 74 minute? 80 minute? See if there are any specific requirements first.
Mar 13, 2008 | Audio Players & Recorders
Sound Problem when recording
Your digital camera is not a professional recording device. A live gig, especially indoors, or if you're close to the stage, means very high decibels, and you need something more serious if you really want to hear it later. You should get a recording device that can tune to different sensitivities. My old mini disc was great for this before it died. You also need a decent mic. Better luck next time! who was performing btw?
Jun 09, 2006 | Vivitar ViviCam 4100 Digital Camera
AKG K 240 Studio Professional Headphones Logo
968 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Ben Armstrong
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
