Question about Nikon COOLPIX S5 Digital Camera
Side silver part
The side silver part of my black nikon S50 has came "unglued"
do you think it would be harmful to super glue the edges back down?
    Problem Solver:
  • 29 Answers
Is your warranty up?
Posted on May 27, 2008
Need help fixing my suwoofer kicker L5
I have 6-10's and 4-12 L7's in around the same condition with the solo "S" blown out of the cones, its amazing what 20kw does to them in the right box..lol.
you could try sanding around the hole than c.a. (black rubber toughened super glue) a patch of thin cotton fabric, tack down the edge with glue, than saturate the cotton with glue and spray with accellerator, it should last quite a while before it flies apart.
Apr 07, 2014 | Car Audio & Video
2004 back window heat cord came unglued
Ask a windscreen replacing shop for ideas and failing that very careful use of Loctite 401 may fix the problem It is a super glue made for the purpose of fixing rear vision mirrors to windscreens. Ensure you have acetone or nail polish remover on hand in case you stick your fingers together.
Mar 05, 2014 | Cars & Trucks
My Jenn Air microwave model JMC8130DDS door panel has come unglued...what do I use to reattach it?
Super glue, hot glue, or J. B. Weld would all work, if applied neatly in minimal quantities to squeaky clean, dry surfaces which are then clamp lightly until the glue sets.
Jan 05, 2014 | Microwave Ovens
2004 Beetle Convertible, rear window is getting unglued
I had the same problem with the window in my 2003 beetle convertible. I purchased 3m windo-weld super fast A10E2A and single step glass primer A13B5A also 3m. I ordered it online from Auto Body Toolmart. It was very easy to do and is in there really tight. Unlatch the top just enought to release the tension.
1. clean the window and remover any old glue with a razor blade
2. use acetone to make sure the rim around the glass is clean
3. apply thr gass primer and let dry
4. apply the glue which is black so put on a thin bead and I used gloves so I could make sure it was on both the window and also the fabric of the top. You must work fast because it sets up in 15 minutes.
5. Then take blue masking tape and secure the glass by taping all around the top. up and down and from side to side.
6. allow to dry for 6 to 12 hours. the clean off any extra glue with a razor.
The total cost was $39 dollars instead of having to buy a new tp
Oct 07, 2011 | 2003 Volkswagen New Beetle Convertible
My nikon coolpix s50 camera says...memory card is write protected and click pictures.. Need a solution for this ASAP!! Thanks Shweta
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 13, 2010 | Nikon Coolpix S50 Digital Camera
The window is unglued on the bottom and sides.
The dealer can fix virtually any problem with a late model car. But, if you use epoxy or trim adhesive, you may be able to do the repair yourself.
I once used 'gel' super glue to exactly meter and put glue where it belongs and get an instant bond on rubber to glass or rubber to metal bonding.
Jul 11, 2010 | 2005 Volkswagen New Beetle Convertible
SB-600 body is broken
Tape works better than glue . The black tape . Super glue will work if you use an accurator with the glue .
Jun 30, 2008 | Nikon Speedlight SB-600 TTL Flash
Fixing an Infocus X2 Light Tunnel Problem...
Hi JF1226
This quite a tricky job , but not impossible.
You will see once you've taken out the light tunnel ( also known as the packlight pipe module ) that there is one or two of the small mirrors that has come loose as a result of the lamp's heat.
Glue them back with Super Glue that dries very fast.
Do them one by one , always try to build them back in from edge to edge i.e. - If the top one and left side one is loose , do the side one first and then the top one - just makes it easier.
Remember you only have one shot at this , so do it carefully.
Good luck and thanks for using Fixya.
Apr 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
Nikon COOLPIX S5 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
