Question about TruTech TT320
Error message Every DVD I put in, the machine tries to load and then I get the message "Wrong Disk". I can take the disk and play it with no problems in any other disk player in my home. Help!
  • Luci of Oz Mar 24, 2008
    Thanks for your help. Unfortunately the answer isn't what I was hoping for! I appreciate you taking the time to let me know. It's time to buy a new DVD because this machine isn't worth putting a cent into.
  • Anonymous Mar 25, 2008
    will not play dvd I burn on my computer in Roxio, Will play on other DVD players
  • 979 Answers
Uh oh.. Time for a service visit as the optical assembly has stopped scanning properly...accordianman
Posted on Mar 21, 2008
jackboy
  • 2985 Answers
SOURCE: wrong disk
There are many chip sets for DVD machines and each has preferences for a range of disk types- most will play straight commercial discs- but things get a bit tricky with the many and various types of 'burned' disks from computers. The strange thing is - it seems the cheaper the player the more versatile they be whilst a Hi grade one can be a tad fussy about what it will and will not do. So what does this mean to you? Check the types of disk you have been playing on it and stick to it- come back with exactly what disks it don't like
Posted on Jul 11, 2007
SOURCE: Emerson EWR20V5 DVD Recorder/ VCR Combo
didn't realize had to finalise the disc after recording.
Posted on May 27, 2008
SOURCE: Insignia dvd player will not load. error messages:
could be dirty laser, try a laser cleaning cd,you should get a little bottle with alcohol in to put on the little brushes, if that doesn't work could be the laser has given up the ghost
Posted on Mar 20, 2009
SOURCE: Clear Play DVD player
I just encountered the same problem. We've had our player for quite a while, but it seems like there ought to be a way to fix it from home. I don't mind taking it apart if that is needed, but I'd can't just buy a new one each time!
Posted on Apr 13, 2010
SOURCE: get message This disk can not be played. Please ch...
Happening to me as well.. I have burned dvd-r that I made myself.. and it will not play.. I have all kinds of different dvd-r's and none of them worked.. ran the latest firmware.. nothing!
Posted on Jul 11, 2010
System will not play DVD's. Sometime it will play for about a minute or two and stop. Sometime it will play and the picture freezes. Sometime it act like it wants to play but never does. Can you tell me...
Troubleshooting Solution
  1. Lift disk changer doesn't work comes message "Disk Error"
  2. Lift disk changer work fine but doesn't load a DVD
  3. Power light is ON but doesn't want to Power UP
  4. From the beginning start DVD movie the picture distorted and freeze
available parts avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Feb 20, 2011 | LG LHT874 Theater System
I have a Panasonic VHS-DVD player/recorder model DMR-ES35V. I was recording and playing back at the same time using a DVD-RAM disk (using the time slip feature). After about an hour of viewing I got an...
FOR AL THOSE WHO HAVE A PANASONIC DMR-ES35VS THERE ARE MAJOUR PROBLEMS WITH THE RAM DRIVE WHEN IT IS DEFECTIVE THE DVD PLAYER WILL MAKE A SOUND LIKE IF ITS TRYING TO READ OR YOU WILL HERE A SORT OF SCRATCHING SOUND THIS MEANE YOUR RAM DRIVE IS DEFECT IT WILL COST 200 DOLLARS FOR THE PART
Oct 21, 2010 | Panasonic DMR-ES35VS
"wrong disk" message appears after load time
If this happens on more than one DVD, it might be necessary to clean the lens of the DVD player. Safe commercial products are available at local drug stores for around ten dollars.
The "wrong disk" message is usually associated with Data disks, i.e. those having computer files rather than DVD movie files.
If this is an older DVD player, the DVD may have been written on a high-speed DVD writer which creates smaller data spots which may not be read correctly on older DVD players.
Barring these problems, it is probably just broken. DVD players, although not having as many moving parts as VCRs, do not last indefinitely.
Oct 06, 2009 | Televison & Video
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Insignia dvd player will not load. error messages: NO Disk or Will Not Load. Disks play on other machines.
Mar 20, 2009 | Televison & Video
"Wrong Disk" error
I would assume that you finalized the disk after you burned them. THat being the case try the disk on another DVD player. If that does not work try burning another disk. Its possible that its either a failed burn, a picky DVD player or plain defective disc. So the only option left is to isolate the probelm.
Oct 04, 2008 | Memorex (3202-5639) (50 Pack) (32025639)...
Problem with reading and playing dvds
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 07, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Error message
i think your problem is that your lens( laser lens) that reads the disk is dirty. Try this get q-tip and put just little rubbing alcohol and clean the lens.
May 30, 2007 | Toshiba SD-K620 DVD Player
TruTech TT320 Logo
66 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
