Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Problems with Singer CE-150... the LED light #19 keeps coming on, but I KNOW it isn't threaded incorrectly..
Hello!
I desperately need some help with my machine. I purchased a week ago and followed the manual exactly when threading. The machine's LED light #19 keeps coming on and won't let me do more than 10 stitches at a time. I have re-threaded, used different thread, different bobbins and re-read the manual 15 times to no avail. Have you heard of this problem before with other users? Should I contact Singer's help line? Please help me, I am ready to take this darn thing back to the store..
Thank you,
Gloria
  • 2 more comments
  • Anonymous Jun 06, 2008
    I just returned my Futura 150. I tried and tried -- I threaded according to instructions and over 40 needles broke. The thread was frayed and I purchased the highest quality polester 40 weight thread so it was not the thread. Something is wrong with that machine.
  • jjosey Oct 16, 2008
    I am having the same problem with my CE-150.. the LED light #19 keeps on coming on. Any suggestions would be great.
  • BabyBoutique Dec 10, 2008
    I am having the same problem. I am about to take it back. Also when I monogram names......it looks rough and rigid ! Not clean cut like my other machine which is a Brother
  • Anonymous Mar 29, 2014
    I need to know the correct way to thread my machine. I bought the manual fof $10 and could not see the diagram. Please direct me to a ibstruction video. Thank you
    New Friend:
  • 185 Answers
This machine uses a rotary thread break sensor. If you look at the top left of your machine when it is running the sensor (white dial) should be spinning. Threading around this part is critical. Make sure it spins when you pull thread through the needle. if it does not you have missed something in threading. If this is spinning and machine still stops it is likely the sensor is malfunctioning.
Posted on Apr 01, 2008
  • Apollonia Samaveld Nov 19, 2011
    try my method first, it was spinning..perhaps a tiny bit of fluf is just a problem, rewind what you have been doing last..
    Problem Solver:
  • 10 Answers
Use some thread, perhaps cotton knitting yarn? and pull gently through the path i.e like flossing every so gently... did the trick for me ;-)
Posted on Nov 19, 2011
We had a similar problem, the sensor wouldn't spin. Turns out we had a small bit of broken thread bunched up against the sensor dial. We picked it out carefully with a needle and it quit giving us the "thread breakage" error.
Posted on Mar 25, 2009
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
I have a Singer Futura CE-150 and it keeps stopping due to "Thread break error" but the thread and bobbin seem okay what could it be?
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
Dec 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Can't thread the bobbin on a singer futura CE 150
Be sure the bobbin thread is coming off from the left. There is a picture on my Futura bed that shows the correct way to insert the bobbin. If the thread is comming off from the right you will have the problem you described.
Good luck,
Beth
Jun 29, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer Ce-150 Error 19
The top little circle you think you're supposed to wrap your string around - the one that you wrap the thread around to fill the bobbin -- thats not what you're supposed to wrap it around. Im an idiot, and thats what I was using. My friend Amanda showed me what I did wrong.. LOL
Apr 28, 2009 | Singer CE-200 Quantum Futura Computerized...
Bobbin/threading
Could be acouple of things. The tension on the thread or the bobbin. The needle not in all the way. Wrong type of needle for the thickness of the material. My problem was always trying to pull or push the fabric with the needle in the material - cause a bend, then the tip snags the side of the bobbin hole. Snap it's gone.
As your friend suggested, check the threading of the bobbin, the click she/he might be talking about it the first rotation of the bobbin, then being snagged by the needle thread. Good luck!
Jan 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Thread breakage sensor
Select in the main Futura menu Help->Machine setup Tutorial, lesson 10b, the balloon shows the proper position of the upper thread inside sensor checked area.
Sep 24, 2008 | Singer CE-100 Futura Computerized Sewing...
Sewing straight stich
I had the same problem and it turned out the tension was too tight. I had the thread spool holder too tight against the thread spool.
Aug 25, 2008 | Singer CE-100 Futura Computerized Sewing...
SINGER CE-150
reduce the upper tension until the thread doesn't show on top anymore. This will probably solve both problems.The problem you describe is mechanical not computer related.
sewman7
May 19, 2008 | Singer CE-100 Futura Computerized Sewing...
KEEPS SHOWING A BROKEN TREAD ERROR MESSAGE. I CANOT FINISH A PROJECT! SINGER FURURA CE-150
I have a CE-250 and I was having problems getting this message. After doing some research, I discovered that it was the thread sensor not sensing the thread. Try rethreading it or cleaning out your sensor area. It works for me when I get this message
Apr 23, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
397 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
