Question about ASUS P4S800D-X Motherboard
Can't restart I forgot to add another problem, I can't restart on my computer. When I press restart my monitor is off but my computer still running. Is there a fix to this? Thankyou in advance.
  • 883 Answers
Try disabling all power saving features in BIOS . then do same in windows if no change.
Posted on Mar 21, 2008
Cannot remove novo vision from flashing on my monitor
Press the power button of the monitor for a few second in 'of' mode then 'on', the popping add on the windows will just disappear.
This help solve my problem.
Jan 22, 2013 | Computers & Internet
The screen says no signal
If you have already verified the connection between your computer and the monitor you can try these steps to attempt to get an image on your monitor.
First, check your monitor for a button that says "source" or a button that has a square with an arrow pointing to the center. This will switch where your monitor looks for the signal.
A good rule to follow is if your monitor is connected to the computer by a cable with white ends, you should select "Digital", and if it is connected with a cable with blue ends, you should select "Analog" or "VGA". It is possible, but unlikely that your monitor is connected in any other way.
If these steps still do not work, follow these steps exactly:
  1. Press the windows logo key 220px-ctl_wndws_alt.jpg and "R" (This opens the "Run" window.
  2. Type this command: "shutdown /s /t 0" without the quotes. The shutdown command with the "/r" and "/t 0" switches tell shutdown to restart the computer at "time 0" which is immediately
  3. Wait for the computer to restart and it should automatically detect the correct display to use.
  4. If all else fails and you cannot get the display to connect, restart the computer and press "F8" until the computer comes up into safe mode. From there you can verify whether or not the monitor is actually functional, as driver incompatibility issues are not a problem when running in safe mode.
Nov 25, 2010 | Gateway FPD1975W 19" LCD Monitor
When i start a installed game on my PC the game Crash my screen IS black and i Saw "monitor Going to Sleep" help me please
The game you are trying to install is not compatible with your operating system. Do not install it again.
The way to fix your computer is that
(1)restart your computer and and start pressing F8 continuously
(2)You will be presented with a menu.
(3)Select "Restart your computer in safe mode"
(4)After you enter your computer in safe mode
(5) Go to control panel and then to Add/Remove Programs and uninstall the game.
(6)Restart the computer.
Good Luck!
Oct 05, 2010 | Computers & Internet
When I try to use my 17'' Soyo monitor with Windows 7 program the screen turns black and then ''out of range'' wording is all I get on the monitor. I have tried booting in safe mode, set the resolution to...
When you power up the compute press F8 key then enter in :"Enable vga mode" then go to display property and set screen resolution to 1024*768.
Then check .
If still same then enter in safe mode and uninstall graphic driver then start computer normal mode then install graphic driver.
Also in safe mode go to start->run type in run "chkdsk /r" then press ok then press "y" then restart computer then it fix and recovers error on harddrive.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 23, 2010 | Soyo Dymond DYLM017A 17" LCD Monitor
I get a message, "Frequency out of range. Nothibng else. The menue and other buttons don't do anything. Nothing else shows. I swapped out the monitor and the new one works.
This problem arise when your computer AGP driver not adjust monitor frequency.you fix it restart your computer and run safe mode settings resolution area(must be choice less area)or select 1024X768 pixel monitor frequency 60Hz press apply set OK.restart your computer.Run again normal mode.May be fix your problem.
Dec 27, 2009 | Princeton Digital VL1916 19" LCD Monitor
No picture, the power LED alternating between
please your pc in cpu is open and smps power suply in mother board in socket is check and in board in out of rem and cleaning and restore
in press in this plase and monitor cable to cpu add socket is press
and monitor power cable is con't luse and so the restart pc.
other main problem then you go service centre and service currently ok.
Oct 21, 2009 | Computers & Internet
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
My computer password protected
go to Start/Run and type "control userpasswords2" minus the quotes. You can also use "control userpasswords" to bring up the user accounts menu thats found in control panel.
If you are using a standerd account go onto this website and consider what they offer: http://www.password-changer.com/
Aug 01, 2008 | HP Compaq WF1907 Monitor
Uninstall problem
Restart your system and press F8 .Run window in safe mode .Then do this by add remove option
Mar 02, 2008 | LG Studioworks 45 14" CRT Monitor
ASUS P4S800D-X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
