Receivers
Problem for Receivers
Generic problem for all Receivers
Substitute for Woofer p/n 141760
By lmlmrunner on Mar 21, 2008
I have a set of Pioneer SpeAkers Model CS-G201WAll and the woofers have dry rotted Foam around the Cone. Should I replace the Foam or both the Foam and Cone. Also, I have called Pioneer Corp. to see if they have a replacement Woofer for p/n 141760 and they said "no longer Available."
I checked for compatiable speaker sets and they listed model CSG201/CSB5000D. It doesn't say what the watts, ohms and frequency ranges are for this particluar item. Can you help me see if they are interchangeable?
Thank, Jeff
Solution #1
posted on Mar 21, 2008
Not Rated)
robotek
Rank: Guru
Rating: 91%, 1173 votes
Hi there
Replace the foam for sure. It is always better than looking for another original driver to fit to the box, as they often have foam deterioration happening as well(spares are the same age as the originals) . A great idea(once repaired) is to use an artists paintbrush to apply "Armoural" a polyvinyl protectant to the foam. It will extend the life of it by at least double. They rot in hot humidity and heat environments and there is not alot that works better than that foam. I have done hundreds of speakers here in Queensland Australia. If you live in a hot humid area, there is probably a HiFi shop near you that does repairs to surrounds also. Good Luck
Do you have a source and knowledge for replacement of foam surrounds. holler back and I can help:)
regards
Graeme
Was this helpful?
Yes
No
Popular Solutions for Receivers
Questions and Unsolved Problems for Receivers
Answer
hk avr 7000 no output to the speakers. unit lights up radio will tune to station but no sound will... (More)
Answer
Stero Tape deck D-90 play lever will not engage
Answer
I have a sanyo dcx 686 stereo I found and I don't know what the audio out putt power is per Chanel?... (More)
Answer
I have recently connect my speakers to my multi channel receiver but only one set of speakers are... (More)
Answer
My Yamaha RX-V596 Reciever is not video switching properly. It's stuck on cab/sat, which works fine,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Receivers Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
