Question about Intel Motherboard
Vista Install Issue
Gigabyte GA-MA790FX-DS5 (rev. 1.0)
How to Configure bios setting to create and format a sata raid that vista can recognise
Issues:
-Cannot Use DOS.. Made A Boot Disk.. Cannot Use DOS Commands In DOS .. For Some Reason, DOS Wont Recognise The Command.com
-Cant Update The BIOS - See Cannot Use DOS
-Cannot Install The RAID Controller Drivers In An XP Install.. Cause It Says They Are Corrupted
-Vista Install hangs instantly after the files are copied
-Cant Download the drivers from the Gigabythe site, As There In An .Exe File.. That Wont Run On 64 bit (Only System I Have Acess To)
    Genius:
  • 1,027 Answers
This link has at the bottom of the page a bootable cd .iso to download.Burn this iso on cd and boot from it. or download GParted bootable ISO download and burn on cd and boot from there. Its like running FDISK on steroids.
You should configure sata in the bios boot options etc.
Posted on Mar 21, 2008
I can't get Vista Ultimate set up to recognize my WD 1TB HDD in a new build. Is this a software problem or problem with the HDD. I get the short beep at BIOS start up so I don't think its with the...
Few steps to check your harddisk status on the motherboard would resolve this issue. Checkin to the cmos setup and look for the detection of the HDD and the size it shows once you have done a formating.
Vista 64 bit shows issues at times while installing a new SATA 1TB HDD. Check if the 1TB HDD is installed on to SATA 0.
Use a WD Disk Manager and format the HDD initially and then try install Vista on to it. Else if this doesnt work on the system, Put the HD on to another working system and Format it with NTFS File system and try installing Vista.. You will be successful. Good Luck.
Feb 13, 2010 | Gigabyte GA-MA785GPMT-UD2H AM3 AMD 785G...
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
Compaq CQ40-108TU unable to install XP OS
Prepare a Bootable XP Disc installer.
At first go to BIOS Setup to Boot First Priority the CD/DVD Rom Drive.
After that disabled SATA or RAID Configuration. The Bootable XP Disc Installer could not go on when you don't disable the SATA or RAID Connection.
Don't worry that you are thinking it would not detected the SATA HDD by Bootable Disc but it is. Then follow the instruction.
If i am helpful to you please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | Compaq Presario Notebook
Unable to complete full boot with SATA Blu-Ray Player installed
Try reducing the size of the raid to under 2TB. If the system install, then try expanding the raid.
Jul 10, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
SATA RAID Controller Card Problem?
You are almost there. Go into your BIOS and enable RAID. Then your raid bios should show up on next boot.
Feb 15, 2009 | Intel Motherboard
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
SATA hard drive issue
Try changing the SATA controller to run as IDE. I can not advise anthing other because you have not listed the model of the gigabyte board, therefor I can't download the manual to advise the correct setting.
Jul 07, 2008 | Gigabyte Motherboard, GeForce 7100, Core 2...
Windows Vista
If you are having trouble installing the drivers from the Gigabyte CD, than go to Gigabyte's web site for the GA-M61SME-S2 motherboard & download the Vista driver's you need. The web site has some newer drivers. Click on this link to go to the driver site.
http://tw.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2507
If you are still having trouble. List what is not installing here.
Same for error messages.
Mike
Jun 26, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Cannot load windows
hi cpfish,plz do let me know what kind of error message do you get when you are doing the setup so i can get you the best solution.
raj..
May 12, 2008 | Gigabyte GA-8KNXP Motherboard
Two problems:1) Audio2) Freezing when running AMD Overdrive
format your hdd fat32 with xp geneuin. then setup motherboard driver...
Jan 08, 2008 | Gigabyte GA-K8N51GMF Motherboard
Intel Motherboard Logo
59 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
