Question about Frigidaire FEB24S2AB Single Oven
Frigidaire single oven broiling
How do you broil in this oven. I have the pan, what else is needed?
  • 53 Answers
The pan and it's grid is all you need, The broiler pan and it grid allow dripping grease to drain and be kept away from the high heat of the broiler. DO NOT use the pan without its grid. DO NOT cover the grid with foil. Some helpful info.. Preheating is suggested when searing rare steaks. Broil on side until the food is browned; turn and cook on the second side. Broiling times vary, so watch the food closely. Time not only depends on the distance from element, but on the thickness and aging of meat, fat content and doneness preferred. The first side usually requires a few minutes longer than second. BE SURE THE DOOR IS OPEN AN INCH OR TWO WHILE BROILING
Posted on Mar 21, 2008
SOURCE:
What does a broil pan do
The broil pan is used to broil meats such as steak or chops. the top part has slots that allow the grease to run into the lower part. they are usually under the burner in the lower door. but some ovens have the broil element in the oven proper. then the pan should be placed within a few inches of the broil element. You should monitor the cooking process because the broiler heats the food very quickly and could burn very fast.
Mar 15, 2014 | Ovens
Broil and range work but bake does not
check oven burner tubes and ignitor and flame sensor
Sep 19, 2017 | Frigidaire Ovens
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire DGES388DS2 electric single oven
Did you reset the house circuit breaker that supplies power to the oven?
Apr 24, 2012 | Frigidaire Ovens
Frigidaire GLEB30S8CSB- the broiler doesn't work, all other functions are normal. What do I need to look at? Many thanks...
Unplug the oven.
Remove the oven racks.
Remove the bake element.
Be careful and not let the wires fall back into the holes when you remove them from the element.
Use a volt/ohm meter set for ohms or continuity to check the broil element terminals.
No reading is a bad element. If no reading replace the element.
If the element is good the control panel will have to be opened to check for power from the electronic control to the element.
Re-attach the broil element.
Access the control module for testing.
At this point you will be working with live high voltage.
Turn the power back on.
If you are not comfortable with that please call a service technician.
If you want to do it,locate the broil out put wire and the neutral wire on the control. Set the control for broil,place your meter leads on broil and "N".
No reading is a bad control module.
A good voltage reading will be a bad wire to the broil element.
Mar 11, 2010 | Frigidaire GLEB30S8A Electric Single Oven
OVEN WILL NOT HEAT. EVERYTHING ELSE WORKS, BROIL,
look closley at teh bottom bake element possible it has broken, causing this problem
Feb 09, 2010 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire FES367ASE Slide in range
Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire FEB24S2AB Single Oven Logo
200 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Steve Allison
Steve Allison
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
