When I connect my dvd player to my new lcd flat panel tv using component cables (pr, pb & y) all I get is my picture in red
  • 979 Answers
Defective cabling or bad processor preamp on LCD unit. Could also be a bad buffer/driver on the DVD outputs as this feature is not used on composite hookups...accordianman
Posted on Mar 21, 2008
6ya staff
SOURCE:
DVD player is 12 years old is it compatible with hisense tv
Your TV has and component video input. Your DVD should have this output. You will need a component video cable (Pr, Pb,Y) and an audio cable (L&R)
Sep 21, 2013 | Hisense LHDN32V66AUS 32 in. LCD TV
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Only get black and white picture using vcr/dvd why picture
Hi There,
The most likely reason for this is that your connections between the DVD player are incorrect. This usually happens when a Composite cable is connected to one the Component input sockets on the back of the TV.
If you are are using a composite cable (red, white, yellow plugs), please make sure the yellow plug is not connected to a socket labelled Y, Pb/Cb, or Pr/Cr on the back of the TV or the DVD/VCR. The yellow plug needs to be connected to a VIDEO OUT socket on the back of the DVD/VCR and a VIDEO IN socket on the back of the TV.
Do not use sockets labelled Y, Pb/Cb, or Pr/Cr on either of them.
If you are unable to determine which sockets to use, please let me know the brand and model number of your VCR/DVD and confirm the model number of your TV is GV42L. I will then be able to draw you a diagram showing the correct connections to use.
Hope this helps.
Regards,
BElectric
Feb 26, 2011 | Vizio GV42L 42 in. LCD Television
How to connect a dvd player to lcd tv
Your DVD player's output is Composite Video (the yellow connector) plus stereo audio (the red and white connectors, for right and left audio)
The inputs on your TV are for Component Video, which splits the video signal into three cables (Y for brightness, Pb and Pr for blue and red, respectively)
Check your TV to see if it has a composite input (single yellow connector, labeled "video" or "composite")
And be sure to let me know if this helps!
Oct 24, 2009 | Televison & Video
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
Which component cables to use
the cables are fine labeled as they are you notice cr =pr, cb=pb and y is still y
the cables are fine and will deliver up to 1080I capabilities
Dec 09, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Yellowish color from DVD
Hello Tsmith4,
Have you tried another source such as a HD cable box on the same component input (Y Pr Pb) By doing this you will eliminate the TV or the DVD player. If the picture shows great using the cable box on that same input then we will assume that the TV is ok for now. You may want to also check the DVD menu under progressive scan that it is set to progressive scan. if the picture is still not good, we would want to look at the I/O board on the TV. The red path after the Video switch maybe open. If this is the case we will have to go to board replacement. I will tell you what board to change.
Best regards
circuitcity
May 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Open Questions:
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
