Question about Dishwashers
Washer keeps stopping mid cycle
For a while now, my candy non-built in CS455M washer keeps stopping itself mid-cycle. I have checkecd all the water inlets and outlets, and those are alright. The problem just came about suddenly, and has gone on for a while. Can anyone please help? Thanks Timer seems to stop working just after starting on my candy cdw 254 dishwasher
  • 979 Answers
Bad timer motor or mechanism...accordianman
Posted on Mar 21, 2008
  • prem mathew Jan 09, 2014
    The mechanical timer has a very small motor attached to it. In most cases it is this small motor which is 'shot'. It could save you a pile if you just check this out and replace it. Easily available at spares, thru the net
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
Candy cs455m programe stops at about 3oclock on the dial
Yes heatr should be submerged in the water. Not expose to free air.Check the water level float switch or the pressure switch.
The replace timer should be identical in design. If there is a mismatch it will not function as designed.
If it is elctronic micro controller type the same part no and soft ware version should be used.
May 25, 2010 | Candy 17 in. CS455 Built-in Dishwasher
CANDY cs455M DISHWASHER
Hello penny123
Welcome to fixya.
My name is Huuum at your service.
You said, " YOU HAVE NO MANUAL AND NOT SURE WHAT THE SETTINGS ARE FOR."
I found the site where you can read or download your proper User manual for the
Candy CS455M Dishwasher.
Below is the site that will take you directly to the Candy online Manual search.
When there, Manually start typing in the sc455 and a few model choices will pop up.Choose your cs455m and when it opens , you may print it or just read it to acquire the information you need.
http://service.candy-domestic.co.uk/manuals/Manuals.aspx?Section=3
Please Remember to leave a solved rating for me, before you leave our fixya site.
Thank You Huuum
Sep 30, 2008 | Candy 17 in. CS455 Built-in Dishwasher
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Sep 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Hotpoint sdw dishwasher
It is possible drain pump blocked, you need to empty d/washer manually, check inside drain pump which is at end of drain hose, always isolate d/washer from power before attempting any work on it.
Aug 14, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Candy cs455m
Welcome to fixya.
I'm Huuum at your service.
You said, The dial goes through one cycle but it stops when it gets into another cycle and there seems to be no heat because when you stop the cycle and open the door the plates are cold and the water has not been dried off
I believe your timer may be bad and in need of replacement.
But before you do this, you should read the report I pasted below.
Especially because this model is an inexpensive model!
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old Appliance
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your appliance,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your appliance is under warranty or less than four years old
paying for a repair makes sense.
Note that appliances under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your appliance is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new appliance.
Data also shows that it doesn't pay to fix a less-expensive applaince
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a appliances you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave a rating before you sign off!
Thank You, HUUUM
Jun 03, 2008 | Candy 17 in. CS455 Built-in Dishwasher
Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Oct 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
Candy Dishwasher CS455M
i have just bought a candy dishwasher cs455 and have no manual can you tell me the best wash and what to set it on thanks
Aug 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
Dishwashers Logo
744 people viewed this question
Top Dishwashers Experts
