Question about LG Electronics HTW316 5.1 Channel Wireless 350W HTiB System (-HTW316, LGHTW316) System
LG wireless dvd reciever system
Hi
Can someone please help me,just installed new LG wireless speaker system.
Have problems as follows wireless speaker only stays on for 5 minutes and than red light comes on also the reciever turns off.
Have checked all connections (many times) but nothing seems to work .
After 5 minutes each time all turns off.
Can someone please help.
Regards
Bill
Hi, I had the same problem, it seems to be a design error of LG or a typical problem with some component in the wireless transmitter. It is basically caused by the transmitter heating up, leading to a clock drift with the result of the receiver losing the signal. I tried to cool the transmitter in the fridge before using so it will run for about half an hour before producing this error (depends on the room temperature as well). My solution is to remove the plastic case of the transmitter unit and place it in a cool place where it does not catch heat from other devices. Without the case it does not overheat and also takes less space, just be careful if you have children. I placed the naked Tx unit behind the TV so it does not matter. Hope this works for you as well.
Posted on Aug 31, 2009
Try positioning the dvd unit away from other sources of heat, i.e. decoder / vcr, etc. It may just be overheating.
Posted on Aug 02, 2008
SOURCE:
I want to add external speakers. How do I do it and what speakers do you reccomend
Hello jazzolino,
there any several ways you can go about this and they can range in quite bit in your budget. Anywhere from $60 to $5000 or more. The $60 one's im talking about are just small computer speakers that you could connect to your tv. Or a home theater in a box (HTIB's), or buying every speaker individually. The last choice is the best way to go but will be the highest budget.
First off figure out how many speakers you would like. You can go all the way up to a 7.2 channel. 7 means 7 speakers and 2 means 2 subwoofers. Some people dont like speakers everywhere and want very simple speakers. You can get a soundbar. Its one speaker that may or may not come with a subwoofer (usually wireless subwoofer) depending on your selection. They can have excellenet audio but it will not give you the full surround sound experience if that is what you are looking for. If you do want that, you can look for a 5.1, 7.1, or 7.2 surround sound. Some HTIB's can come with dvd player or a blu-ray player. They usually are lower cost in budget wise but I usually don't recommend this people just because if the dvd player goes wrong, you may lose everything. But again they can give you the surround sound experience and has excellent audio. The other one's do not have a dvd player but just a reciever. I recommended getting one with a reciever (onkyo is my favourite but a beast looking one for sure). Harmon/Kardons have excellent design on them and are just as great. Most of the speakers are use speaker wires and need to be powered by the reciever. There are speakers out there that are powered by the subwoofer. Generally these are 2.1. (If you want 2.1, I suggest the bose speakers GS series II or series II).
The other option is to get everything individually. If you do this keep in mind of the power that you are looking for. Some have 200 watts and some have 1000 watts. For example for a 5.1, if you get a reciever that powers 1000 watts and you get speakers that can only 50watts per channel (per speaker), the receiver can potentialy over power the speakers and lead to distored audio or speakers blown up. Since this speakers only need a total for 250 watts (50 watts x 5 speakers), you only need like a 300 to a 500 watts reciever. Keep in mind the subwoofer is powered by itself.
Once you get the sound system, I suggest you plug all your cables, like dvd player, satellite or cable, game systems all on to your reciever and then one cable to your tv. This is because tv's usually dont have enough inputs in the back and you could run out quick, that is one of the reasons why I recommended a reciever. Reciever's have lot of input on the back so most likely you will not run out. I suggest plugging in an HDMI cable from your reciever to your TV. HDMI will give you both audio and video from one cable. This way when you have your dvd player plugged into your reciever, you will get picture to the tv. There aren't many wireless home theater systems but there are wireless system to make the back two speakers wireless. Generally, having wires running along the length of your place seems to be the biggest inconvience. They can cost about $200.
Brand name speakers JBL, Harmon/Kardons, Onkyo, and Klipsch. Now other people will recommend something else, so look into it. See which is best suitable for you.
I know this is only a quick run down and I could keep going but it would be pages and you would lose interest. I hope this helps. Good luck.
-Joe
Aug 29, 2011 | LG 32LG30 32 in. LCD HDTV
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
I bought a new Samsung home theatre system with wireless rear speakers and followed the directions to hook them up, but the reciever flashes rear check. this has been going on for 4 hours
HI,
SPEAKER SYSTEM HAS TWO MAIN UNITS ONE IS ADD ON UNIT AND INTEGRATED WIRELESS SYSTEM.TRY TO MATCH THE POWER HANDLING OF ADAPTER WITH THAT ON YOUR REAR SPEAKER OUTPUT.
TNKS RABBANEES
Nov 04, 2009 | Audio Players & Recorders
Have new LG 42" LCD and no sound on the 5.1 Surround Sound
Try running a set of audio cables(Red/white) from your audio out jacks on the back of your TV to your reciever's audio in?
Feb 01, 2009 | LG 42LC2D 42 in. LCD HDTV
How to connect dvd player to AV reciever
S-Video is a media type that only carries video. Unfortunately the LG unit was designed only to be a self contained surround sound unit. There are only video outputs to the television on this unit. Because of the unit having surround sound capabilities, LG felt that their wasn't a need for audio output. You would need to buy a new DVD player to allow audio from the DVD to your new Yamaha unit. Good Luck!
Jan 22, 2009 | Audio Players & Recorders
Wireless speakers
You should have two pieces for your wireless rear speakers setup. A. a wireless card inserted behind the all in one receiver. B. the receiving box that will connect to the 2 rear speakers.Also,you should not have any obstacles to block off the line of site for the rear speaker receiving box to the wireless card.
Best way to test it is too simply leave the rear speakers connected to the rear speakers receiving box on the floor near the a/v receiver with dvd player built in.Play a dvd and see if you have sound coming out from the rear.
solutiondoct
Nov 01, 2008 | Panasonic Home Theater System System
I have a problem with my speakers..
Hi Crixxe
You must have recieved the asrock chipset or motherboard driver cd,
1) Insert the asrock driver CD in CD/DVD rom drive.
2) Go through the automated installation of all the drivers.
3) Connect your speakers properly with computer. Make sure that the volume is on.
4)Restart the computer after installing drivers.
5) Now you should be able to play the sounds on your computer,
Regards
TheAssembler
Jun 06, 2008 | Microsoft Windows XP Home Edition
Is it possible to use the speaker system on a different DVD player?
I believe I understand what you're asking here. To the best of my knowledge sony puts a special type of connector on the reciever end of the speaker wire which will probably not be compatible with any other reciever brand. Depending on the age of your system, the speakers may not even be compatible with the new Sony models. Wait...there's good news though. Whatever reciever/DVD player you decide on, there will surely be speaker outputs and if you snip of the Sony connector and strip the wire a bit, you shouldn't have a problem. A couple of other things to consider though... A conventional standalone DVD player may not have outputs for five speakers and a sub. That sounds more like a dedicated reciever. I have a crazy suggestion but you might save yourself some money and trouble. -If you are satisfied with the speaker portion of your current system, buy a cheap DVD player, run the video out to the TV, the audio out to the AUX audio in on your current system and use it for sound only. Hope something in here helps.
May 29, 2007 | Sony DAV-BC150 System
Feedback from spekers
suggest,checking pwr point earth,power leads, try a different antenna,unplug any external connections not needed to recieve broardcast,shift position of tv by 3 mtrs. Regards Chook.
Apr 01, 2007 | LG DVD 5253 DVD Player
My panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Jan 20, 2007 | Panasonic DMR-E50 DVD Recorder
611 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
patseamur
Level 1 Expert
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
