Question about ASUS P4S800D-X Motherboard
Do I really need a floppy disk to do an upgrade bios?
Hi everyone I'm a newbie and I have a question. In order to do an upgrade bios I got to have an floppy disk right? I have a Asus p4s800d-x and it been given me problems. Everytime I start up my computer it give me a screen says Overclocking Failed! Please enter Setup to re-configure your system.Press F1 to Run SETUP Press F2 to load default values and continue.
Right now I"m thinking about doing upgrade bios but my question is do I need a floppy disk in order to do it?
  • dragon512 Mar 21, 2008
    Hey guys thankyou for responding to my thread. I'm using window xp pro and had downloaded every update there is and I still gettin overclocking failed. My version of bios is Bios V1009 Version 4.34.20.69.00b. When I check in the Asus website it didn't have my version and the highest I see is v1006. What should I do? Should I call to the company and get upgrade?
    One more thing about the restart. I have check on bios in the power section and everything is disable and also I check in window and I don't see an option to turn off or maybe I look in the wrong section. I went to start, control panel, performance and maintenance, power option, then it give me turn off monitor, turn off hard disk and standby, but it didn't give me any option to turn off. What can I do? Also thankyou for responding.
    President:
  • 2,351 Answers
Hi dragon512,
mewms & I both know you are a bit green. Doing a flash on your board will most likely kill your bios. Only people with a bit more technical know how attempt flashing a bios.
Neither of us knows, at the moment if your bios even needs to be flashed.
So before you jump lets walk a little...........
If you have windows XP home installed & it is not completly updated when you press the reset button on your case there is a good chance your PC will not shut down or restart like a WinXP Pro system will. Win XP Pro will shut down window correctly.
XP Home will cut windows off & restart your PC. That is why you are getting;
I'll bet you when you press F1 windows run's checkdisk every time!
If you want to restart your computer you click the Start button, than click shut down. A pop-up loads in the center of your desktop & you click what you want your PC to do.
Shut Down or Restart or Standby. Than you click on it.
I promise if you stop touching the reset button on your PC and let windows do the work for you.
Your PC will run just fine.
A bit of information about Asus. A new (updated) bios cost $5.00.
The call to Asus to order the new bios will cost less than $3.00.
Shipping will cost you about $1.50. Far less than a floppy drive or a USB drive.
Asus number for a new bios: 510-739-3777
Turn on your monitor, than turn on your PC. As soon as you see video display press the Pause/Break key on your keyboard. That will freeze your system so you can look at your screen. Listed there is the bios version. Write is down on paper.
Than go to Asus for your board. Click the link I have posted:
http://support.asus.com/download/download.aspx?modelname=P4S800D-X&SLanguage=en-us
Click the + sign to the left of BIOS. Check what you have written down to what is on Asus web site. It is recommended never to flash a bios unless there is something a new bios will fix. Keep that in mind.
If you have more questions feel free to ask.
Good Luck & Kind Regards.
Posted on Mar 21, 2008
    Genius:
  • 1,027 Answers
Of course floppy is the easiest but if you configure a flash drive with flash drive utilities to be bootable, and the BIOS will support it you can flash from the USB flash drive.
Will a sequencer malfunction cause my floppy disk not to load.
You may have to ENABLE floppy disk in BIOS, you can also change boot order there if you need to boot from floppy. They are obsolete now, so many set BIOS floppy to OFF {some do not not even connect the cables, floppy just plugs the hole in the case) . I use an external USB floppy for emergency access to old floppies. (ahh, memories !)
Sep 26, 2014 | Computers & Internet
Tip
FLASHING BIOS - THE PROCEDURE
BIOS Update Procedure
All latest Motherboards today,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With
FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about
this.
Please read the following instructions in full before starting a Flash BIOS upgrade:
A. Create a Bootable Floppy (in DOS)
•With a non-formatted disk, type the following:
format a:/s
•If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you
are flashing the new BIOS.
B. Download the BIOS file
•Download the correct BIOS file by clicking on
the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip from www.winzip.com or www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•You should have extracted two files:
Flash BIOS utility eg: flash7265.exe (for example)
BIOS eg: 6152J900.bin (example)
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file). This information is usually provided.
C. Upgrade the System BIOS
During boot up, write down the old BIOS version because you will need to use it for the BIOS backup file name.Place the bootable floppy disk containing the BIOS file and the Flash Utility in drive a, and reboot the system in MS-DOS, preferably Version 6.22
•At the A:> prompt, type the corresponding Flash
BIOS utility and the BIOS file with its extension.
For example:
flash625 615j900.bin
•From the Flash Memory Writer menu, select "Y" to
"Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE:
eg: a:\613J900.bin
Alternatively select "N" if you don't want to save your current BIOS. Beware, though, that you won't be able to recover from a possible failure.
•Select "Y" to "Are you sure to program?"
•Wait until it displays "Message: Power Off or
Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete theprocedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
Make sure the new BIOS version has been loaded properly by taking note of the BIOS identifier as the system is rebooting.
For AMI BIOS
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips
Note:
1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to.
(This option is not available when flashing an AMI BIOS).
2. If you have problems installing your new BIOS please check the following:
Have you done a clean boot?
In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a
BIOS.If you have not used a bootable floppy, insure a clean boot either
a) pressing F5 during bootup
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by
using the EDIT command.
Have you booted up under DOS?
Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers.
Important:
Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above
procedure (format a: /s and rebooting from a:\).Have you entered the full file name of the flash utility and the BIOS plus its extension?
Do not forget that often you will need to add a drive letter (a:\) before flashing the BIOS.
Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c:\ your will need to type
a:\615j900.bin, rather than 615j900.bin only.
on Dec 30, 2009 | Computers & Internet
Tip
BIOS Update Procedure...
All latest Motherboards today, 486/ pentium/ Pentium Pro etc., ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With FLASH BIOS, there is no need to replace an EPROM BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about this.
* With a non-formatted disk, type the following:
format a:/s
*If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you are flashing the New BIOS.
* Download the correct BIOS file by clicking on the file name of the BIOS file you wish to download.
* Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the Winzip for windows shareware/ evaluation copy for that one time use from _www.winzip.com or _www.pkware.com. Most CD Roms found in computer magazines, have a shareware version of winzip on them.
* You should have extracted two files:
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file. This information is usually provided.
C. Upgrade the System BIOS,
Place the bootab le floppy disk containing the BIOS file and the flash utility in drive a, and reboot the system in MS-DOS, preferably version 6.22.
* At the A:> prompt, type the corresponding Flash BIOS utility and the BIOS file with its extension.
For example:
* From the Flash Memory Writer menu, select "Y" to "Do you want to save BIOS?" If you want to save (back up) your current BIOS (strong recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE: eg: a:\613J900.bin
* Select "Y" to "Are you sure to program?"
* Wait until it displays "Message: Power Off or Reset the system"
Once he BIOS has been succesfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete the procedure, do not switch off, because the computer will not able to boo, and you will not be given another chance to flash. in this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
For AMI BIOS
Once the BIOS has been successfully leaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips
Note:
1. Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to. (This option is not available when flashing an AMI BIOS).
In other words, did you the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS.
If you have not used a bootable floppy, insure a clean boot either by
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by using the EDIT command.
Booting in windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers.
Important: Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the abovr procedure (format a: /s and rebooting from a:\).
Have you entered the full file name of the flash utility and the BIOS plus its extension? Do not forget that often you will need to add a drive letter (a:\) before flashing the BIOS. Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c:\ your will need to type a:\615j900.bin, rather tham 615j900.bin only.
on Dec 26, 2009 | Computers & Internet
I can't find the bios flash instructions .how do you flash the bios on my toshiba a35s159
You should check the Toshiba WEB site for instructions to how to upgrade (flash) your BIOS, if you make a mistake you may not be able to repair or recover from your mistake.
I have done BIOS upgrades on a few computers.
If your Toshiba has a floppy drive and you can boot up from this floppy drive then the BIOS upgrade needs to be downloaded to a boot floppy. Then boot up from this floppy and run the BIOS upgrade program. When completed, remove the floppy disk and boot up your laptop.
YOU MUST CHECK THE TOSHIBA WEB SITE AS THESE INSTRUCTION MAY NOT BE APPLICABLE FOR YOUR TOSHIBA LAPTOP.
Jun 02, 2012 | Toshiba Computers & Internet
Hello I am looking for XP drivers for a "fujitsu lifebook E series 6555" laptop. I would also like to update the BIOS. Fujitsu's website doesn't even list my model...? Any help is...
hi
i have two links for you .. read and review carefully. you will get the drivers you need
http://support.fujitsupc.com/CS/Portal/supportsearch.do
FAQ, http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=FAQ
How do I upgrade the Bios for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks?
NOTE: This BIOS upgrade is for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks. The upgrade fixes an issue with the Full Dock II/LAN Dock II/Port Replicator II.
Instructions on Upgrading the BIOS.
Step 1: Create a bootable BIOS upgrade disk
This step can be performed on any system (desktop/notebook computer) running a Microsoft Operating system.
  1. Place the BIOS upgrade disk in the floppy drive of your pc/notebook.
  2. Copy the system files onto the BIOS upgrade disk to make it bootable.
  3. For example:
    MS DOS prompt: type 'sys A:'
    MS Windows:
  4. Double click "My computer" on the desktop.
  5. Right click the floppy drive icon.
  6. Select "Format?"
  7. Select the "copy system files only" option
Step 2: Upgrading the BIOS
  1. Attach a floppy disk drive to the LifeBook to be upgraded.
  2. Place the BIOS upgrade disk (created in Step 1) in the floppy drive of that LifeBook.
  3. Reboot the system. Boot from the floppy.
  4. At the command prompt, type:
    phlash /mode=3 filename.rom (put a space after "phlash" and after "3". Filename is the name of the BIOS.)
  5. Allow the system to reboot.
Step 3: Change BIOS settings (For users upgrading from Windows 9x to Windows 2000).
To allow Windows 2000 to better manage your system, change the following settings in your BIOS:
a) Boot the notebook and press F2 to enter BIOS setup.
b) Set Power Management to Disabled
b) Set Plug and Play OS to NO
Consult your user's guide on how to change BIOS settings.
Jan 09, 2011 | Computers & Internet
Ho can i upgrade bios of my compaq pc having intel 815e desktop board and intel processor of 933 GHZ inorder to get boot from usb option
Mostly the BIOS updates/upgrades are available in compressed form and when expanded they reuire a floppy disk to extract the files. Try using floppies. (ehteshamhusain@gmail.com)
May 03, 2009 | Computers & Internet
All latest Motherboards today, 486/ Pentium / Pentium Pro etc.,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Please read the following instructions in full before starting a Flash BIOS upgrade: A. Create a Bootable Floppy (in DOS)
format a:/s
sys a:
This procedure will ensure a clean boot when you are flashing the new BIOS.
•Download the correct BIOS file by clicking on the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip for Windows 95 shareware/ evaluation copy for that one time use from _www.winzip.com or _www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•At the A:> prompt, type the corresponding Flash BIOS utility and the BIOS file with its extension.
For example:
•From the Flash Memory Writer menu, select "Y" to "Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE: eg: a:13J900.bin
•Wait until it displays "Message: Power Off or Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete the procedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
For AMI BIOS Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips note: 1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to. (This option is not available when flashing an AMI BIOS).
Have you done a clean boot? In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS.
Have you booted up under DOS? Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers. Important: Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above procedure (format a: /s and rebooting from a:).
Have you entered the full file name of the flash utility and the BIOS plus its extension? Do not forget that often you will need to add a drive letter (a:) before flashing the BIOS. Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c: your will need to type a:15j900.bin, rather than 615j900.bin only.
Oct 19, 2008 | Computers & Internet
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    Do I really need a floppy disk to do an upgrade bios? I don't have a floppy disk, can I use a cd rom?
    The real question is why and truly if you need to upgrade your BIOS. You should avoid unless you have a specific reason to do so. Secondly you can use alternate methods to upgrade such as a bootable CD, which you can use several programs to create. UltraISO is one and a free trial is available.. The resulting disk will start on boot the same as the OS disk would self start. You should also check your Boot sequence to ensure the read of the bootable CD as priority 1. The bios update needs to occur in Dos, rather than through Windows. Look here for exact instructions fron ASUS:
    http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
    And look here for Bios update files:
    http://support.asus.com/download/download.aspx?SLanguage=en-us. Good Luck!
    Mar 21, 2008 | ASUS P4S800D-X Motherboard
    UPDATING BIOS FOR ASROCK M266 A MAINBOARD
    In order to update your Bios, you need to have a bootable diskette.
    First make sure your 1st boot sequence is Floppy Disc. Place a bootable floppy, if you don't have one just do it by using unused floppy. Right click on 31/2 Floppy (A:), choose Format, then tick the box "Create an MS-DOS Startup Disk". Once finished use this disk to boot your system. After the system completed the boot process, replace your boot disk with your upgrade disk. Type the require command to update your bios.
    Good Luck
    Feb 09, 2008 | Asrock M266A Motherboard
    ASUS P4S800D-X Motherboard Logo
    247 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
