Question about Universal Remote Control DIRECTV Universal Remote Control
Remote codes I have the same problem but I have a samsung TV and can not find the right codes.
    Genius:
  • 1,027 Answers
Samsung tv codes.0019, 0030, 0032, 0039, 0056, 0060, 0178, 0329, 0427, 0482, 0154, 0165, 0180, 0183,0185,0216,0006,0011,0014,0015,0019,0027,0036,0037
0105,0077,0076,0109,0007,0009,0004,0005,0085,0172,0942,0358
0012,0080,0104,0106
Posted on Mar 21, 2008
SOURCE:
Need to program samsung tv universal remote. How do I do it?
For my universal remote control's manual, all of the Samsung codes are:
12051
10178
Also, remember that you can have the remote scan for codes on its own. On the remote just hold the "TV" control button (should be at the top near the power button) and the power button turns on. Then hold the power button too, and it shuts back off; keep holding until it turns back on and then it will stay on. Then, point the remote at the TV (it should be on) and press the power button every three seconds. It will test a code every two or three seconds. When your TV finally shuts itself off in response, you've got the right code and the remote should work.
Jan 18, 2018 | Samsung Televison & Video
Need Samsung code that works
Try this link http://downloadcenter.samsung.com/c...984_BN68-00998A-01.pdf
Dec 07, 2007 | Samsung AH5900092W Remote Control
Samsung codes
Four digit universal remote codes for Samsung brand TVs are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
To know more about 3 digit codes, and the setup proceedings to synchronize a remote control with TV, check this link.
Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, by brand name at first.
Dec 21, 2012 | Sony Rm Vz220 - Universal Remote Control
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
Samsung TV Universal Codes
  • Turn TV on. 2Press the "Code Search" button until the indicator light comes on, then release the button.3Press the "TV" button. After you press and release the TV button on the remote, the light should blink once and then stay lit.4Enter a three-digit code. The remote code for Samsung will be 004, 005, 006, 011, 012, 013, 014, 015, 017, 09, 027, 036, 037, 077, 082, 104, 105, 106, 171, 172, 196, 201 or 204. The indicator light will turn off if the code is input correctly. If the light blinks rapidly, the wrong code was put into the controller. Go back to the Step 2 and repeat.5Point the control at the television and press the "On-Off" button. If your television turns off, you have used the right code. If nothing happens, put in a different code.Read more: How to Program a Samsung Universal Remote ' eHow.com http://www.ehow.com/how_4897139_program-samsung-universal-remote.html#ixzz1LpSdxIG1
  • May 09, 2011 | Televison & Video
    I have a Samsung Blu-ray remote (AK59-001041R). I need a programming code for a Westinghouse LED TV.
    I have a Westinghouse LTV-32w3 HD that I am able to operate with a Samsung AK59-00104R remote. To activate this, press and hold the TV Power button on the upper right of the remote while simultaneously typing "3" and then "5" in succession. This code (35) works for these Westinghouse TVs.
    Mar 07, 2011 | Samsung Ak59-00104l Remote Control
    I have a Insignia tv and I need the remote code for the bd-1600 remote. I want to use the bd-1600 remote to control my tv.
    Many remote control codes can be found at InsigniaProducts.com. Search for your Insignia product model number and click on the Support tab.
    Jan 02, 2010 | Samsung BD-P1600 Blu-ray Disc Player
    I need help programing my rca remote to a samsung television
    Hi
    Ideally I need you to clarify a few details on your exact RCA remote model and number and also whether this is a Samsung TV or other unit like a DVD etc.... that you wish to program
    However assuming it is a Samsung TV here is a list of the common RCA codes for this TV. You will need to go through each one individually until you find one that works.
    Code 1004 for Samsung TV Code 1005 for Samsung TV Code 1006 for Samsung TV Code 1012 for Samsung TV Code 1013 for Samsung TV Code 1015 for Samsung TV Code 1017 for Samsung TV Code 1019 for Samsung TV Code 1082 for Samsung TV Code 1104 for Samsung TV Code 1105 for Samsung TV Code 1106 for Samsung TV Code 1171 for Samsung TV Code 1172 for Samsung TV
    Hope this helps. If so please do rate my answer.
    Otherwise please post up additional details as outlined and I will see what I can find.
    Many Thanks.
    Sep 06, 2009 | RCA ACC-RCAURC Remote Control
    I need to find out how to program my samsung RS-105N remote control.
    The picture you have is a Directv universal remote.If that is correct.
    Turn your Tv on.
    Press and hold the TV and SET button until the TV button lights up. 4 seconds or so.
    Release the buttons.enter one of the 3 codes below.If the TV turns Off you have the right code,press the TV button to lock the code in.repeat if the code does not turn the TV off
    for Panasonic the codes are 034 or 080,056, 164
    Nov 01, 2007 | Samsung RS105N Remote Control
    Televison & Video Logo
    542 people viewed this question
    Top Universal Remote Control Televison & Video Experts
    Jaime Hernandez
    Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
