Question about Panasonic CT-32G22 32" TV
Pip won't turn off
My remote control quit functioning except for volume and channels. I purchased a generic remote and when I set up the remote the pip came on the screen and now I can't get it turned off. Any suggestions?
  • 55 Answers
How did you explain the problem you have to reach the correct code
from remote to turn off or on of the pip circuit - i can suggest to
use the original remote control or somethig else delfo
Posted on Mar 21, 2008
SOURCE:
RUNNING CHANNEL SCAN WITHOUT A REMOTE CONTROL
You should have a remote control to start a channel scan. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Aug 03, 2016 | Televison & Video
Hitachi 55vf820 problem
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Mar 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
How to get this remote control to turn the 2004 Sylvania TV on/off
There is a fault with the remote control and it is not worth trying to fix it and not worth replacing the stock remote control unit even if the manufacturer could still supply one for that TV.
The best option is to just buy a very basic generic remote control (quite inexpensive) from an electronics store which will work with many TVs and use that remote to turn the TV on and off. Use your stock remote for all other functions if it is still working well on those functions.
I had a friend with the exact same problem with her stock remote a while back. I purchased a simple generic remote control on special for around $20 which she now uses to turn the TV on and off. .
Nov 21, 2015 | Sylvania Televison & Video
I purchased "One for all-
Hello
With some of the universal control models, all the functions of a TV cannot be controlled, especially with Loewe. The functions now works perfectly will. That is all. Sometimes the functions and buttons will not coincide. For example, if we press volume UP channel will change , if we press digit '1' set will switch off and so. OK
Jul 07, 2011 | One For All URC4220 Remote Control
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Will not turn on. TV is pluged in its almost like a power surge. The power bar is lit so for some reason the tv is not getting power.
Problem with PIP Function
To turn off PIP. Use tv menu and auto set channels, once searching for channels, turn off and PIP will be gone. If you can't access auto program tune tv to channel 3 and try again.
Nov 24, 2007 | Sony KP-53V75 53" Rear Projection...
Televison & Video Logo
150 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
