Question about iLO (2 GB) MP3 Player
USB Write Protection Hi, I am trying to copy/delet files from/to a USB stick. window says: " The disk cannot be written to because it is write protected. Please remove the write protection from volume USB disk in Drive \Device\Harddisk1\DR4". The stick does`nt have a switch to lock or unlock the write protection. Please help me. My email, mykhel_zuniga@yahoo.com Thanks
  • 5 more comments
  • sayoteboy Apr 12, 2008
    My usb 2.0 cannot be copied to because it is write protected and even though i try to reformat it the same prompt is shown. please help.
  • pmcc Apr 15, 2008
    Hi, my Olympus fe-280 has developed a problem, saying write protect on a blue screen, as far as i am awhere i have tried everything to fix this problem, but no luck, could you please advise me on what i need to do to fix this problem
    mccullagh_paul@yahoo.co.uk
  • dazpat Jul 04, 2008
    same problem as above
  • nag_raju53 Jan 19, 2009
    hi iam fasing below given problem in pendrive
    the disk cannot be written to because it is write protected. Please remove the write protection from the volume in driveDeviceHarddisk1DR4.
  • anand10fores Feb 25, 2009
    yes
  • rima_sunset_ Apr 03, 2009
    error message :please remove write protection from the volume in drive\device\harddisk1\dr9
  • aswin
    aswin Jun 15, 2014
    me to had this error how to remove
    President:
  • 1,257 Answers
As you said that there is no switch to lock and unlock usb stick so if this is the case than download the file below
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
This will solve the write protect error definitely
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 16, 2008
I have a 16gb usb and i have this problem please remove write protection from the volume in drive\device\harddisk1\dr9...help
Posted on Jun 04, 2009
NO its not helping
Posted on Jul 01, 2008
Hi I am jahid. i can't open my memory stick. while i want to open it windows says to format it.but while I click on format, windows says it's write protected. please help me. and send me a solution on my E- mail address.
Posted on Nov 17, 2008
4 Suggested Answers
SOURCE: REMOVING WRITE PROTECTION FROM MY USB 2 FLASH DRIVE
Hi, I am having problem copying or deleting from my Kingston Flash USB 4 flash drive. suddenly I could not delete or even copy anything into the drive. It keeps on indicating your disk is write protected. I have not secured the disk with a password, even then I have this problem....
How can i recover in this problem.
Posted on Sep 16, 2008
SOURCE: removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Posted on Feb 05, 2009
SOURCE: how to remove write protection from usb device
i have genx 4 gb usb 2.0 how can i format this drive...i will try for formating but showing write protect message,,,
please give me the solution
from bijoy dubai
Posted on Jul 28, 2009
Mi HP compaq laptop does not read the stik,any idea how to solve it?
Have you tried the stick in a different computer?
Where was the stick written to?
The first thing to do is see if you can read it elsewhere, copy the files off it if you can, format the drive using windows, check if you can read/write in your computer and copy the files back to it, leaving them as a backup on the other computer in case the stick is faulty
How to Format Flash Drive
OR
There are programs which can sometimes rescue usb stick data but your computer has to recognise that the stick is there. Look in disk management to see if it knows the stick is there. If it is you can use software such as
How to do data recovery from RAW usb drive may cost but is good
Data Recovery Software by ADRC is free
May 07, 2014 | HP Compaq DVD Drive
When trying to format,copy files into flash,deletinf files,i get the message "remove write protection". so how can i remeve it?
One of two things:
Either your flash drive/card has a hardware copy protect on it (usually in the form of a little tab) Just be sure that it is turned off.
Or
You've somehow managed to tick the "read only" box on your files. Highlight the files, right click, go to properties, and unclick the checkbox for "read only". This may have to be done as administrator.
I'm really opting for the first one, Most people don't realize that their card or stick has copy protection on it and wonder why they can't delete files.
If nothing else works, you can always use a software program called unlocker - http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
It integrates into windows explorer and allows you to delete files in use, locked files, etc, etc.
May 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
USB Write Protection Hi, I am trying to copy/delet files from/to a USB stick. window says: " The disk cannot be written to because it is write protected. Please remove the write protection from volume USB...
Put the memory card into the SD adaptor and turn the white switch on the left of the card in the opposite direction.
See if that will work.
You may have to turn your phone off and back on again as well after reinserting the card back into the phone.
Nov 19, 2008 | SanDisk 2GB microSD Memory Card
Hi, I have a Jetflash USB 2.0. I am unable to copy or delete files on the stick. When I try to it comes up with a message:'The disk is write-protected, Remove the write protection or use another disk. What...
improper removing may have caused the problem format the usb by right-clicking on the usb drive and format don't change anything just start the format and i almost forgot to tell you when removing a usb drive use the safely remove hardware method see the green arrow icon in the lower right of your screen? right click on it and click safely remove then stop to avoid problems
thanks for posting
Oct 17, 2008 | Computers & Internet
Jul 04, 2008 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
6,126 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
