Question about Lexmark Z1300 InkJet Photo Printer
Making labels I want to make labels. I have purchased the "avery quick peel sheets" I need to know how to put them in the printer.
    Scholar:
  • 79 Answers
There are software templates on the avery website. Maybe you can find the specific product you bought on the website and download a template that will help you print labels.
Posted on May 01, 2008
SOURCE:
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
Oct 15, 2014 | Avery 8168 Inkjet Labels Shipping...
How to make address labels
Get the Avery plug in for word from the Avery web site. It makes things so easy if you do.
Aug 18, 2014 | Avery 5160/8160 compatible (100 White...
Avery label printer 9100 won't print
I have the same printer and usually when this happens I am able to flip the lever on the side to put it into auto peel mode and push the feed button on the front and that usually works and makes the light go green. It was explained to me that if the label stock is old it will have a hard time recognizing it. Sometimes I have to pull out the labels and re-insert the labels to get them to work properly. I hope this helps.
May 30, 2009 | Avery AVE09000 Automatic Lbl...
Want to know if this printer can print address labels (Avery peel and stick). Thanks.
Yes you can print Address but to print that you have to use MS word, to create it first
May 19, 2009 | Brother MFC 490cw Color Inkjet...
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
AVery 9100
Also, what I did was to first back all of the labels out and back into the reel. Turn machine off, then back on. With the peel lever down, as mentioned above, begin to load the labels as shown. The light will blink and it will make a noise as it senses the label. It will begin to draw the label in and you need to make sure you create tension on the labels as they are being pulled in. I accidentally did this by holding pressure against the reel, and sure enough, the thing pulled the first label into place and quit frickin blinking!!! Labels printed fine afterwards!
Dec 31, 2008 | Avery 9100 Thermal Printer
Printer Jam - when i put a sheet of Avery labels, printer jams
When you say TOP TRAY, do you mean a paper drawer, or the BYPASS TRAY? If the labels won't feed into the bypass but bond paper does, check to see if your labels are made for inkjet printers. Go to www.avery.com and contact Avery customer support to see what product they recommend for your MFC. Labels made for plain paper printers sometimes do not work for inkjets, and vice-a-versa.
Aug 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Feb 04, 2008 | Avery DesignPro Deluxe CD-ROM...
Lexmark Z1300 InkJet Photo Printer Logo
158 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
