I have Kenmore 3.5 super Capacity, PART # 48102.
It no longer goes full cycle, stopping during or just before the rinse cycle. It also no longer dispenses bleach or softner.
I dont know about it not going through the full cycle, but as for the bleach and softner dispenser problems, i had the same issue. About 7 months after i had this same machine,,, the softner would enter the cycle during the first rinse, which i supose isnt a major problem, but it was quite annoying because by the time the 4th rinse was over,,, there was obviously no softner left on the clothes. It was still under warrenty so i had sears come over. They replaced the control board, thinking it was a timing problem, but it didnt solve the problem. They scheduled me for another time, and again sent over a repairman who didnt know what he was doing. I being 20, like to take things apart and see why they broke or how they work, so i pretty much knew what the problem was. I told this second guy what i thought and he ordered the part, 2 weeks later came back after i had recieved the part, installed it, and PROBLEM SOLVED. So im thinkingthis could be the same problem your having. If you take out the detergent draw to clean it or for whatever reason, if u look inside, and up,,, you can see holes where the water drops from,,, and that is the part you probably need fixed. I really cant remember what the part is called,,, but im assuming its something like Detergent Dispenser Asembly or somethng like that.
Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since top load and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
