Question about ASUS P4S800D-X Motherboard
Do I really need a floppy disk to do an upgrade bios? I don't have a floppy disk, can I use a cd rom?
    Sergeant:
  • 201 Answers
The real question is why and truly if you need to upgrade your BIOS. You should avoid unless you have a specific reason to do so. Secondly you can use alternate methods to upgrade such as a bootable CD, which you can use several programs to create. UltraISO is one and a free trial is available.. The resulting disk will start on boot the same as the OS disk would self start. You should also check your Boot sequence to ensure the read of the bootable CD as priority 1. The bios update needs to occur in Dos, rather than through Windows. Look here for exact instructions fron ASUS:
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
And look here for Bios update files:
http://support.asus.com/download/download.aspx?SLanguage=en-us. Good Luck!
Posted on Mar 24, 2008
I can't find the bios flash instructions .how do you flash the bios on my toshiba a35s159
You should check the Toshiba WEB site for instructions to how to upgrade (flash) your BIOS, if you make a mistake you may not be able to repair or recover from your mistake.
I have done BIOS upgrades on a few computers.
If your Toshiba has a floppy drive and you can boot up from this floppy drive then the BIOS upgrade needs to be downloaded to a boot floppy. Then boot up from this floppy and run the BIOS upgrade program. When completed, remove the floppy disk and boot up your laptop.
YOU MUST CHECK THE TOSHIBA WEB SITE AS THESE INSTRUCTION MAY NOT BE APPLICABLE FOR YOUR TOSHIBA LAPTOP.
Jun 02, 2012 | Toshiba Computers & Internet
How should the BIOS be set up?
This is the recommended way to do it.Turn on your computer and press F2 to enter the system setup. If you have problems with the Bios you have to get a Bios upgrade by getting software from dell then you can do the following.Reset the boot sequence to boot first from the floppy drive or the CD drive (depending on whether your flash BIOS update is supplied on floppy disk or CD).Insert the flash BIOS update floppy disk or CD, and reboot the computer. The computer updates the BIOS and then automatically reboots. mmediately press F2 to enter the system setup program, and reset the boot sequence to the normal setting. Then exit the system setup program.
Jan 09, 2012 | Dell Latitude C640 Notebook
Hello I am looking for XP drivers for a "fujitsu lifebook E series 6555" laptop. I would also like to update the BIOS. Fujitsu's website doesn't even list my model...? Any help is...
hi
i have two links for you .. read and review carefully. you will get the drivers you need
http://support.fujitsupc.com/CS/Portal/supportsearch.do
FAQ, http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=FAQ
How do I upgrade the Bios for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks?
NOTE: This BIOS upgrade is for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks. The upgrade fixes an issue with the Full Dock II/LAN Dock II/Port Replicator II.
Instructions on Upgrading the BIOS.
Step 1: Create a bootable BIOS upgrade disk
This step can be performed on any system (desktop/notebook computer) running a Microsoft Operating system.
  1. Place the BIOS upgrade disk in the floppy drive of your pc/notebook.
  2. Copy the system files onto the BIOS upgrade disk to make it bootable.
  3. For example:
    MS DOS prompt: type 'sys A:'
    MS Windows:
  4. Double click "My computer" on the desktop.
  5. Right click the floppy drive icon.
  6. Select "Format?"
  7. Select the "copy system files only" option
Step 2: Upgrading the BIOS
  1. Attach a floppy disk drive to the LifeBook to be upgraded.
  2. Place the BIOS upgrade disk (created in Step 1) in the floppy drive of that LifeBook.
  3. Reboot the system. Boot from the floppy.
  4. At the command prompt, type:
    phlash /mode=3 filename.rom (put a space after "phlash" and after "3". Filename is the name of the BIOS.)
  5. Allow the system to reboot.
Step 3: Change BIOS settings (For users upgrading from Windows 9x to Windows 2000).
To allow Windows 2000 to better manage your system, change the following settings in your BIOS:
a) Boot the notebook and press F2 to enter BIOS setup.
b) Set Power Management to Disabled
b) Set Plug and Play OS to NO
Consult your user's guide on how to change BIOS settings.
Jan 09, 2011 | Computers & Internet
How to format acer one laptop without cd-rom?
Use an external CD rom or sometimes there is a petition file in the Hard drive to format.
Oct 19, 2010 | Acer Aspire One PC Notebook
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
Recover from failed bios upgrade
Sounds rather serious, I’m afraid. Depending on your motherboard and BIOS type, that error message indicates either a failure to initialise the Display Card, or a failure to complete the memory check. Have a look at your motherboard manual and follow the instructions to ‘reset CMOS’. That may correct the problem if you’re lucky, but I’m doubtful it will.
If your motherboard has the BIOS chip inserted into a socket you should contact the motherboard manufacturer and see if a replacement chip is available. If not, you are probably confronted with a ‘dead’ motherboard. I wish I could offer a happier message, but BIOS upgrades are always a risk.
For the benefit of any readers thinking about upgrading their BIOS, here’re a few tips:
If your computer is operating smoothly, don’t do it. The main two reasons for performing a BIOS upgrade are
  1. To enable support for a new processor that wasn’t available when the motherboard was manufactured..
  2. To correct a ‘known issue’ with the BIOS for your motherboard that causes your computer to function incorrectly.
Don’t do a BIOS upgrade during inclement weather periods, when your electricity supply may be subjected to ‘flicks’ or ‘spikes’.
Try to avoid ‘Live Update’ functions for upgrading your BIOS – you’re at the mercy of your internet connection if you use them.
For preference, update from floppy disk. But be sure to use a new floppy, format it and add system files, and then perform a ScanDisk on the floppy, enabling the ‘Thorough’ option to ensure that a surface scan is conducted. Only trust your BIOS update files to the floppy after you’re sure it’s a reliable one.
Please let me know if you have any further questions or concerns.
Thanks.
May 01, 2010 | HP Pavilion dv9700t 2.1GHz Core 2 DUO...
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
Reset bios without running hard disk first
2 options:
  1. create a bootable cd with the bios rom file, and a dos based flash utility (included with bios download). Boot to cd and flash.
  2. Connect a usb floppy drive and create bootable floppy. Copy rom file and flash utility to floppy, boot to floppy and flash......option 2 may be easier if you are not familiar with creating bootable cd's.......Let me know if this helps or not.
Jul 31, 2009 | Acer Aspire 5610-4648 Notebook
Bad bios checksum
You need to go to the website of whoever made the motherboard and get the BIOS flash utility and the BIOS binary file to update your BIOS. Make sure you get the right one, as using the wrong one can render your motherboard worthless. The BIOS file has to be the exact match. There is no such thing as close in this situation.
If you are not sure of the exact make and model, get te free Belarc Advisor from http://www.belarc.com
The BIOS chip holds information about your motherboard hardware. It is reprogrammable. It uses what is known electrically erasable read only memory. This is also called Flash memory. Reprogramming is called flashing. When you flash the BIOS, all data is erased, then the new data is written. The flash utility will most likely allow you to save the old contents, but you might have an extremely tough time recovering from an improper flash. You'll also probably need a couple of floppy disks, one of which may have to be bootable. If you need a bootable floppy disk, you can get an image file from http://www.bootdisk.com.
Jan 23, 2009 | Intel Motherboard
ASUS P4S800D-X Motherboard Logo
128 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
