Question about Singer 3962 Mechanical Sewing Machine
Bobbin thread getting caught
I have a Singer 3962 sewing machine and the bobbin thread has started catching on a little metal piece inside the bobbin compartment. The metal piece is very thin and flexible and is connected to a little metal plate with a screw in it. The thread catches between this metal piece and the black plastic bobbin encasement. What can I do?
Check your Instruction manual - if you have taken the bobbin case apart to clean it, the shuttle must be reinserted with the little tab pressing against the piece you mention. It is under page 45 - "Caring for your machine" in my book. I missed it the first time I cleaned and oild mine.
Posted on Apr 05, 2008
Singer sewing machine bobbin case keeps moving causing the needle to break.
Is this a front loading bobbin or top? If it is a vertical front loader with the little metal bobbin case, the metal case has to be lined up and snapped firmly into place. You should hear it snap and lock into place.
If it\'s a horizontal or top loading bobbin, and the plastic bobbin "tray" is rotating, then it may not have been nested in properly, before replacing the plate, or may be "jagged" somewhere... If there is a burr on the casing, or as in the case of one machine I worked on, still have a piece of needle stuck in it, the thread will snag on it before it finishes rotating and the rotating motion catches half way and will jerk the case right around and the next stitch will break the new needle.. Those plastic bobbin "trays" are usually easy to find and replace if they have become too burred to use. I have also sanded them smooth again as well though.
To test it, unplug the machine, thread your machine on top, but leave off your bobbin lid and leave out your bobbin, hold the top thread (like when you are about to crank to pull up a bobbin loop) and hand crank toward you, or counter-clockwise one complete rotation. Watch to see if the top thread is caught by the rotation hook and slips all the way around and back over the top of the bobbin tray, or if it snags on it somewhere.... Good luck!
Jan 15, 2014 | Singer Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
When I push the needle up / down button, it does not work., and the machine just squeeks.
Hello
some thread might have caught in the metal case on which the bobbin rests. There is a tiny hook in the center that the thread travels around before being picked up by the needle thread to form the stitch. Also, check your bobbin itself. Feel around the outside. If you feel any nicks or burrs, throw that bobbin away and get a new one as the thread is catching on the bobbin itself and throwing the timing off.
Check your needle to be sure there are no burrs or nicks on it. Always use a new needle with each project and if the project is a large one, you will have to change your needle a few times. Needles are not that expensive and make a world of difference in sewing.
One more thing. If your machine manual shows a small "arm" that fits over the bobbin to hold it in place, and that you can remove for cleaning, be sure that it is inserted all the way in and holds the bobbin securely as this will cause the bobbin to "bounce" inside its metal bed and cause the thread to tangle up in the machine.
Jul 20, 2011 | Singer Quantum 9910 Computerized Sewing...
Hello. I am working with a Singer 6083C. When I turn the wheel, the thing in the bobbin goes around but the thread doesn't catch. I'm wondering if this is because I've put the bobbin in...
Have you recently changed the needle? If so, please check if it is in the right way, flat shank to the back. This is easy to get wrong and will prevent stitch formation as the scarf at the back of the needle (scooped out area) is where the rotary hook goes to catch the thread during stitching.
Jul 13, 2011 | Singer 6038 Mechanical Sewing Machine
I cannot get the bobbin thread to catch and pull through the footer wen trying to thread the machine?
Make sure your bobbin is placed in correctly. Thread is counterclockwise as you place bobbin in the metal piece. Pull thread end through sliver in metal piece. Hold on to movable metal latch then lock the bobbin in place. Bobbin should not fall out but is able to rotate. Rotate the wheel on the furthest right of your Singer 1507 machine towards you to move the needle downward. The top thread should then be able to catch and pull up the bobbin thread.
Dec 02, 2010 | Singer 1507
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Singer 9410 Bobbin
Update:  Today I took my machine in to get serviced - they replaced the metal bobbin I was using with a plastic one, that was a little less rattley inside the bobbin case, replaced the needle with a new, universal one, and changed out the thread with something a little higher quality.  They also adjusted the spring holding the bobbin case slightly, and now it seems to work fine.  I'm not sure how long it will last, but for now I'm good.
Oct 02, 2008 | Sewing Machines
Thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Nov 12, 2007 | Sewing Machines
Singer 3962 Mechanical Sewing Machine Logo
257 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
