Question about Refrigerators
Replacing thermostat frig runs well and then stops cooling. i think the thermostat is bad. model sra0721 camper frig. it will start back up when you turn off and on again
  • 883 Answers
Try to determine if compressor is running when "stops cooling". then, if it is, look for frosted coils on back. if frost, then unit needs thorough cleaning with compressed air.
Posted on Mar 21, 2008
Emerson mini model cr501e frig and freezer both quit working what should I check No
check to see if the compressor in the back is running. This is not easy to hear has they are really quiet. If it running and its not cooling then it is low on refrigerant, if the compressor is not running then it could be a bad compressor, or the thermostat is not working or adjusted right. Thermostat is likely located inside the frig.
Sep 19, 2016 | Emerson Refrigerators
At 100 deg.it does not shutoff automatically
If your talking about a refrigerator, it never will as its goal is to try and cool, and its trying. It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your frig is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Kitchen Appliances - Others
Duo therm 57915.331 not cooling
make sure fan on auto and on cool if ok bad cooling unit
Jul 05, 2012 | Dometic Rooftop RV Air Conditioner
Frig stops cooling. freezer on bottom. frig is running just not cooling. made in 2008. we clean it let it set for 24 hr it cools again. is there a defrost heater that we can turn on, to solve this problem.
Hi, this model i believe has a calrod heater, and those usually dont go bad very often, its more than likely a bad defrost thermostat or control board, the thermostat is located in the freezer behind the back panel on the evaporator, the control board if it has one is going to be up in the control panel by the the thermostat, if it doesnt have a control board it will have a timer, I would change the timer and the thermostat in that case. It is also possible you have a bad heater which is also located in the freezer behind the back panel, under the evaporator, If you know how to use a meter you check this heater with an ohm meter. Let me know if you need further assistance.
Sean
Mar 26, 2011 | Whirlpool Refrigerators
Cools but constantly runs
you hit the nail on the head there,,,its the thermostat its dead!
change it they often stick in the on poshion when they stop working to save any food inside of the fridge
Jul 12, 2010 | Haier HSB03 Compact Refrigerator
Freezer has stopped
If it is a frost free side by side fridge/freezer, check evaporator fun in the freezer. While doing that, check is evaporator is full of ice.
if the evaporator is iced up and the fan can spin freely, you have a broken fan. Replace it.
If evaporator and the fan are iced up, you have a broken thermostat. Defrost ice with hot water.
Turn it on, if it starts to cool effectively, replace thermostat.
Oct 11, 2009 | Refrigerators
Hotpoint frig,top freezer motor runs contiunally, thermostat set in middle of temp. control. side of frig stays cool all time.[does not get warm as it used to] is defrost thermostat bad or timer?
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Jun 12, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Cooling and freezing problem
When the frig stops cooling properly, is it running at all? If the freezer fan is running and it is not cooling, you can rule out the thermostat and the defrost control. It would be a hard starting compressor or condenser fan. If the frig is not running, then it is likely the thermostat or your electronic defrost control. The defrost control is right behind the thermostat in the same housing. When you play with the Tstat, do it carefully as not to jar the defrost control. If the frig comes on, replace the thermostat.
Mar 23, 2009 | Kenmore Refrigerators
Frig not cooling
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 01, 2008 | Refrigerators
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
