Question about InFocus X1 Multimedia Projector
Con: Infocus x1 and infocus x1a projector
Hello, I would like to know if the infocus x1 and infocus x1a have the same internal components, minus the fajoudia processor the x1 has? I'd like to know if I could interchange parts. Please email me back.
[email protected]
  • 563 Answers
Hi there
You could most probably do that yes , it's normally only the Mainboard that is different.
Posted on Apr 03, 2008
SOURCE:
Lamp burned out on X1 infocus projector, Replaced lamp, new lamp stopped working in about 5 hours, got another new lamp and it does not light at all. Still blinking 3 red blinks(saying the bulb is bad)
make sure the colorwheel is spinning. if it is not, replace it. also, blow the dust out of it with canned air. excessive dust kills lamps quickly. you'll also need to reset the lamp timer. are you using an sp-lamp-009? the sp-lamp-018 looks exactly like it, but is used in th x1a and x2. the x1 only uses the sp-lamp-009. if all else fails, replace the power supply.
Jan 08, 2010 | InFocus X1 Multimedia Projector
Wer can i purchase an eca controller for an infocus x1
unfortunately, unless you find one on ebay, you're out of luck. infocus doesn't carry them anymore. sorry.
Oct 11, 2009 | InFocus X1A Multimedia Projector
Infocus X1a no picture, solid green LED
if the lamp is new, it could be the power supply (the ballast is built in to the ps). but make sure you have the right lamp. the X1 and X1a have an sp-lamp-019 and the similar X2 and X3 have an sp-lamp-018. the lamps are almost identical except for the wire configuration on the lamp plug. make sure the wires in the plug match the positions in the socket. also, when you turn it on, if you don't hear a high pitch squeal, the colorwheel is not working. and if that isn't working, the lamp won't either. also check to see if the lamp door is closing properly and hitting the switch at the top of the opening.
Jul 12, 2009 | InFocus X1a DLP Projector
Infocus x1a shuts down after 5 minutes
3 red flashing is a lamp error, not the fans. the lamp has a problem striking. make sure it's pushed in and plugged in all the way. if the lamp is not that old, the power supply needs replacing.
Feb 23, 2009 | InFocus X1 Multimedia Projector
Heyya got a infocus x1a ..im running it from vista...but there is no recognition--the projector is searching ..but what is it searching for..also there is a yellow blurring to the left of the projected...
the light tunnel is collapsing. that's causing the yellow bluring. as for the recognition, make sure that the resolution matches what the projector can handle (max 1024x768).
Apr 30, 2008 | InFocus X1 Multimedia Projector
PLEASE HELP!!
Hi there
I tend to agree with sheridan1952 , when buying a broken Projector for spares you never know ehat you're getting.
Feb 11, 2008 | InFocus X1 Multimedia Projector
InFocus X1 power problem
something blew the fuse the first time. if it blew again, the issue remains. something may be arcing. check near the plug, or if there is anything bouncing around in there or a crossed wire.
Nov 26, 2006 | InFocus X1A Multimedia Projector
InFocus X1 Multimedia Projector Logo
162 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
