Question about Plantronics DSP-500 Headset
Software driver for plantronic dsp 500 usb
I can't install my dsp 500 headset although it works with the music but the microphone is not working. Could you help me how can I download the driver of my planronics 500 dsp usb headset please...
thanks
4 Suggested Answers
SOURCE:
  • 556 Answers
SOURCE: iTunes or sound card line in with my USB Plantronics DSP-500 headset
Recently on an HP desktop computer I found setting the device in the Sounds and Audio Device Control panel Voice Tab (and possibly Audio Tab) to reduce the issues with the device ceasing to work. Setting the device from the Sound Icon in the System tray recently only a very temporary fix where the settings reverted to the Sounds and Audio Device Control panel settings in at most minutes. This is at best an I hope it helps solution as I do not know your specific hardware and software configuration we cannot test a solution.
Posted on Dec 06, 2007
  • 70 Answers
SOURCE: Do I need a driver for plantronics USB DSP v4 audio interface
Yes you would need a driver for your Platronics headset if you intend to connect it to your PC
Could you please describe the model of your plantronic headset so that i can get the required drivers for you.
Thanks.
Posted on May 21, 2009
sams_trix
  • 93 Answers
SOURCE: Where can I download a driver for my plantronics
LJBENGE try to visit this site http://www.microsoft.com/windows/compatibility/windows-vista/Search.aspx?type=Hardware&s=Plantronics%20DSP%20500%20headset and try the drivers for vista... good luck!
Posted on Jan 19, 2010
Testimonial: "I did that before contacting you and they state Windows driver is compatible but Vista asks for driver. Headset older"
I have problem in plantronics dsp 400..regarding mike..i cab hear the incoming calls but i cant hav any conversation in mike..the end user cannot hear..so kindly rectify this problem..as it would be of...
<span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: navy; FONT-SIZE: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">The first thing you need to check is your audio settings and make sure that both sound recording and playback are set to the same device. If you
Aug 19, 2010 | Plantronics DSP-400 Headset
Where can I download a driver for my plantronics dsp 500 headset for Vista?
Jan 19, 2010 | Plantronics DSP-500 Headset
Does the plantronics dsp500 headset have a microphone?
Yes they do have.
Hope i helped you.
Thanks for using 'Fixya'.
Jun 23, 2009 | Plantronics DSP-500 Headset
Thanks.
May 21, 2009 | Plantronics DSP-400 Headset
My new headset
If you are using windows XP -- as unreal as it sounds just plug the device in and allow the Plut and Play installer to do it's thing -- it will appear as a device without a driver (in the device management list) but it will generally work. I have tried it on an HP machine and the control panel for sound and audio devices voice tab (as well as the audio tab) needs to be set to the plantronics device, too -- if you use the sound icon in the system tray the device seems to reset periodically to the one in the sound and audio control panel (just learned yesterday). The headset control on the wire -- the mute button (red illuminated button) has ceased to work for some time (possibly around the Service Pack 2 update) but the volume control does seem to work.
Nov 29, 2007 | Plantronics DSP-400 Headset
DSP 500
I have a dsp-400 and have had the same issue intermittently on a laptop. Recently on an HP desktop computer I found setting the device in the Sounds and Audio Device Control panel Voice Tab (and possibly Audio Tab) to reduce the issues with the device ceasing to work. Setting the device from the Sound Icon in the System tray recently only a very temporary fix where the settings reverted to the Sounds and Audio Device Control panel settings in minutes. This is at best an I hope it helps solution as I do not know your specific hardware and software configuration we cannot test a solution.
Aug 25, 2007 | Plantronics DSP-500 Headset
Sound distortion
I too had this problem. I fixed it by removing a Audio driver from K-lite codec pack. I just uninstalled the whole pack from add remove programs and the headphones work fine now.
Jul 07, 2007 | Plantronics DSP-500 Headset
ITunes or sound card line in with my USB Plantronics DSP-500 headset
Jan 04, 2007 | Plantronics DSP-500 Headset
Plantronics DSP-500 Headset Logo
2,316 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
